Problem with lights
Discussion in 'Lighting' started by txbp14, Feb 22, 2016.
  1. Feb 22, 2016 at 7:25 AM
    txbp14
    txbp14 [OP] New Member
    Jerry
    i went to the dealer for an oil change the other day and they let me know that when I lock my doors with the Fob the lights don't flash on. And yes, Instead of fixing the issue they just let me know. I was wondering if anyone else has had this issue/solution. It's a '14 without the factory alarm.
  2. Feb 22, 2016 at 7:39 AM
    are you able to change this in your settings? I know I can adjust mine via the settings on the dash...
  3. Feb 22, 2016 at 8:38 AM
    txbp14
    Jerry
    I didn't check that. But we are talking about when I lock my doors with the key fob right? I will check when I get off work today.
  4. Feb 22, 2016 at 8:41 AM
    Yep and if you don't haw that option, the dealer can fix that by plugging into your cpu and changing that setting.
  5. Feb 22, 2016 at 8:46 AM
    txbp14
    Jerry
    Thanks a bunch
