Pro skid plate squeak
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by warwickscout, Jun 16, 2017.
  1. Jun 16, 2017 at 8:30 AM
    warwickscout
    warwickscout [OP] New Member
    tommy
    warwick ny
    16 pro
    tint 295/70/18 terras iron cross hd steps.wheel spacers,nder seat storage,l.e.d lights cut into rear bumper,spacers,
    Has anybody brought their Pro in to Toyota for the skid plate squeak? Would that be a warranty fix?
  2. Jun 16, 2017 at 9:14 AM
    Don't have a Pro but i don't see why not it's under warranty? U pass the 36000 warranty? Still they should help ya out... maybe just some loose bolts need tightening down
    GNTundra, NewImprovedRon and Law323 like this.
  3. Jun 16, 2017 at 10:16 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    have you tried tightening down the bolts?
    Toyotoholic and (deleted member) like this.
  4. Jun 16, 2017 at 11:02 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Mine suffers from a squeak when I'm turning into and out of my uphill drive way. I always thought it was the suspension, but is this a common issue with the skid plate on the pro's?
  5. Jun 16, 2017 at 11:25 AM
    What about going local hardware store find some thin rubber or vinyl or hard plastic washers place in between wher it bolts to??? Jus an idea
    15whtrd, Law323 and Newm like this.
  6. Jun 16, 2017 at 11:26 AM
    It's the plate. Trim it down a tad
  7. Jun 16, 2017 at 11:34 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Can you elaborate on this a little?
  8. Jun 16, 2017 at 11:38 AM
    Trim down the skid plate. Use a grinder or cutters.
  9. Jun 17, 2017 at 7:49 AM
    comai8981
    comai8981 The payment is the cheap part!
    Joe
    Murrieta, CA
    2016 TRD PRO Crewmax
    Coach Builder .5" shim w/ +3 shackles K&N intake/filter
    What needs trimming? Mine is making the same noise.
  10. Jun 17, 2017 at 7:51 AM
    The corners of the skid plate. Maybe even some of the edges IIRC
  11. Jun 17, 2017 at 4:10 PM
    warwickscout
    tommy
    warwick ny
    16 pro
    if its covered under warranty then Toyota should fix it.why should i.I work on mods they work on covered sh*t
    TTund16 likes this.
  12. Jun 17, 2017 at 4:28 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have heard that most people with this squeak are fixing it with rubber or plastic washers. Mine doesn't make any noise.
    If there are any mods to the front suspension the dealer might say that is a factor, I don't know.
  13. Jun 17, 2017 at 4:33 PM
    Here is an idea that may help.
  14. Jun 17, 2017 at 4:37 PM
  15. Jun 17, 2017 at 5:09 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    T-Rex266[QUOTED] likes this.
  16. Jun 17, 2017 at 7:01 PM
    comai8981
    Joe
    Murrieta, CA
    Pictures > articles on hot days.
  17. Jun 17, 2017 at 7:56 PM
    comai8981
    Joe
    Murrieta, CA
    Like we say after a lot of beers, "Just Gollilla glue it!"
    Damn it, yoto, couldn't include some extra rubbers!?
    T-Rex266, gosolo and driverdog like this.
  18. Jun 17, 2017 at 8:10 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Believe mine has started to squeak.
    Had first thought it was CB steering kit, but now thinking skid.
    Prolly line-x it
  19. Jun 18, 2017 at 12:52 AM
    MotoTundra
    MotoTundra The Ocho
    Don
  20. Jun 18, 2017 at 7:39 AM
    comai8981
    Joe
    Murrieta, CA
    I am going to start by taking it off next weekend hoping that's where the sound is coming from and if it is I will see if it needs trimming or bushings.
    driverdog likes this.
  21. Jun 19, 2017 at 10:06 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    thank you! much appreciated. I will take it off and inspect this weekend
  22. Jun 22, 2017 at 2:34 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I have had no squeak but my truck is still basically new. A friend of mine has a 16 PRO and told me about a similar issue he had. It was caused by some idiot at his dealership using an impact on the skid plate bolts after an oil change. He brought it back and they fixed it for him.
  23. Jun 26, 2017 at 11:52 PM
    comai8981
    Joe
    Murrieta, CA
    Took mine off last weekend while installing my new coach builder shims :)benchpress:) and sure enough I had rub spots. Used sone duct tape and boom squeaky squeaky no more. All is better.
    driverdog and NewImprovedRon like this.
  24. Nov 4, 2017 at 1:10 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I did the nylon washer thing about 10,000 miles ago. Totally fixed it.
    NewImprovedRon and driverdog like this.
  25. Nov 4, 2017 at 8:08 PM
    Flip5ide
    Flip5ide New Member
    There’s a Parts kit to for it, It should be covered under warranty. Took mine in and filed a claim, got a letter a couple weeks later to come in and get it installed.
  26. Nov 5, 2017 at 4:20 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I would be really curious about what the silencer kit includes.this is the first I've heard of it.
  27. Nov 5, 2017 at 5:08 AM
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    sub’d :mudding:
  28. Nov 6, 2017 at 9:12 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Was it pretty easy to get Toyota to fix this? And can you confirmed it worked?
  29. Nov 6, 2017 at 5:12 PM
    TundraPro406
    TundraPro406 New Member
    Montana
    Had my done on my '17 Pro last week. No more popping noise with 200 miles since. Just print the attach pdf (Tech tip 0418-160418-16) and bring into your service advisor. Hope this help.
    JRPro and Wrongside like this.
  30. Nov 6, 2017 at 6:15 PM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    That would have been handy. Took my dealership 3 visits to figure out what it was and how to fix it. Even with me telling them what it was the first time... LOL
