Pro eagle jack
Discussion in 'General Tundra Discussion' started by Erichudgins, Jul 9, 2018.
  1. Jul 9, 2018 at 9:52 AM
    Erichudgins
    Erichudgins [OP] New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Best place to buy??
  2. Jul 9, 2018 at 10:48 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I haven't really seen any other offroad Jack's. Any suggestions??
  3. Jul 9, 2018 at 10:54 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I been using a 12 ton bottle jack from Walmart for 5 years now. I also carry a 60" hi lift, but I've never used it
    I've changed plenty of tires on the trail too
    Erichudgins[OP] likes this.
  4. Jul 9, 2018 at 11:00 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I've looked at them. Dont have anything at all against them. They just never looked sturdy.. but obviously with your rig, that's debunked... thanks bro
  5. Jul 9, 2018 at 11:08 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The thing is, when you get a flat on the side of the trail in the 90 degree desert sun, you don't want to climb into your bed and grab a heavy azz jack and set it up. The bottle jack has a nice little plastic case. Its small and light and I keep it next to my tool bag by the rear door. It's reliable and simple and you can place it anywhere.
    Last summer I had two flats from the same rock in Big Bear, 85 degrees and sunny. I timed myself; I changed both tires and was ready to roll in less than 20 minutes.
  6. Jul 9, 2018 at 11:22 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Lol nice. Ok well thanks for simplifying my situation for me bro. I was concerned the bottle Jack's wouldn't be tall enough. But apparently that's not an issue either. And a hell of alot cheaper!
    osidepunker[QUOTED] likes this.
  7. Jul 9, 2018 at 11:26 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    They have a 12 ton and a 20 ton. I think the stroke on both is similar to a regular floor jack. Plus the piston has a screw extension. Plus I carry 2x4s just in case, but I've never needed them. Blackjack is the brand I have
  8. Jul 9, 2018 at 11:51 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I have a 72" hi lift jack from Ebay that I use. Had a rear lower shock bolt come out and had to lift the body high enough to replace and I've used with tire straps to place small logs under to gain traction. They can work as a Come Along too.
  9. Jul 9, 2018 at 11:53 AM
    TheBeast The Beach
    SDHQ has them. I like the ones with the big wheels
  10. Jul 9, 2018 at 11:55 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    4WP also has them now. Send Proeagle a dm on instagram, they're always online.
  11. Jul 9, 2018 at 1:54 PM
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I got mine from SDHQ, their local to me. Always good to deal with
