Pro comp 6/7 stage 2 lift w 35/37's pics and Info
Discussion in '2.5 Gen Tundras (2014-2021)' started by Corr2626, May 23, 2018.
  1. May 23, 2018 at 6:54 PM
    Corr2626
    Corr2626 [OP] New Member
    Corey
    2014 Tundra Limited
    Does anybody have this lift and have pictures or advice??? Would love to see. Getting it done in a couple months. Also, doing Line X on all my chrome. Everything I've seen so far looks really clean.
  2. May 24, 2018 at 3:51 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I have a pro comp stage 2 and 37s on my gen 2. 0 degree offset wheels. Give me some time to find a pic or two.
    Corr2626[OP] likes this.
  3. May 24, 2018 at 4:17 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    6” w 35’s. I bought it with stage 1 and now looking at swapping front spacer with icon or king coilovers. If you can affoard I would get the stage 2 from the beginning to get coilovers. The swapping later is super expensive.
    I’m also looking at going 37’s and regear next year when I need new tires.
    Edit just saw your looking at stage 2.
  4. May 24, 2018 at 9:54 AM
    Corr2626
    Corey
    2014 Tundra Limited
    How tall is the back of your tailgate from the ground after the increase in size? Just curious
  5. May 24, 2018 at 9:55 AM
    Corr2626
    Corey
    2014 Tundra Limited
    CDMAC likes this.
  6. May 24, 2018 at 10:52 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I think @Jsena has a Procomp but his is 7" with 37" tires, ba!
  7. May 24, 2018 at 12:28 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I’m BDS 7 inch lift on 37’s -25 offset 34ABEFAF-FBE1-4861-901E-B04ECDBC9F52.jpg8CAC2BD6-8F32-4358-8767-8AEAABE00B29.jpg072B1B66-880D-411A-B0A3-52846DCDBAB5.jpg
  8. May 24, 2018 at 1:26 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I was close (not really) BDS /Procomp. Anyway
    Corr2626[OP] and Jsena[QUOTED] like this.
  9. May 24, 2018 at 2:49 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    The thought that counts bro.. nice one
  10. May 24, 2018 at 4:10 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    You can check out my build thread. Pro Comp 7 inch lift with custom length King shocks on 37's.
    Jsena likes this.
  11. May 24, 2018 at 4:30 PM
    Cfincke
    San Antonio
  12. May 24, 2018 at 5:29 PM
    Looking damn good BroSena!
    Jsena[QUOTED] likes this.
  13. May 24, 2018 at 5:57 PM
    Juanjoolio007
    Oregon
    I didn’t have a tape measure today at work and now I’m parked on a hill. I’ll measure tomorrow morning on flat ground for you.
    Corr2626[QUOTED][OP] likes this.
  14. May 24, 2018 at 6:14 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Coño,Muchas gracias
  15. May 24, 2018 at 9:39 PM
    Corr2626
    Corey
    2014 Tundra Limited
    How tall is the back of your tailgate from the ground after the increase in size? Just curious from stock vs 6/35 v 7/37
    TIA
  16. May 24, 2018 at 9:40 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Don’t knkw what it was from stock but I can measure it for you with how it is now
    Looks like 63 inches
  17. May 24, 2018 at 9:50 PM
    Corr2626
    Corey
    2014 Tundra Limited
    Just went and measured my stock and it was 56 inches. Interesting as it's only 7 total inches. Which for me would be great news as I'd be able to fit it in the garage still...... unless I'm doing something wrong
  18. May 24, 2018 at 9:58 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    We’ll lift only m
    my lift moved rear up 5 inches and tires another 3 inches
  19. May 25, 2018 at 4:41 AM
    Juanjoolio007
    Oregon
    So I forgot to grab the tape out of the garage before I went to the gym. So I measured in my driveway when I got back. Not sure it would change that much. I measured about 61 3/4”. Which sounds about right.
    If stock was 56 + 3 for block+1/2 for overload spring= 59.5”
    The various measurements will come in the tires. Stock I am assuming are between 31-32” and a 35 will be between 34-35.5 you are gaining 4.5” at most but split that in half and 2.25” is your increase in vehicle height. So 61 3/4.
  20. May 25, 2018 at 5:30 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    looks like that 4Runner photo bombed you
  21. May 29, 2018 at 7:56 AM
    Corr2626
    Corey
    2014 Tundra Limited
    Alright, so I'm probably better off asking what's everyone's height from floor to the top of wheel well on front and back. I will then compare with my current stock.
    I plan on doing either a 6" Pro comp with 35" TOYO OC R/T
    Or
    7" PC w/ 37" Toyo OC R/T's(Depending on how much underneath I'll have to trim)
    And yes, still trying to fit in garage is on my mind as I currently have around 10" to spare
    If anyone has that exact same hook up with some numbers that'd be huge in my decision making.
    Jsena likes this.
  22. May 29, 2018 at 9:22 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You want to get in garage then go 6 inch with 35’s. Done deal
  23. May 29, 2018 at 10:52 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    My truck is about 85-86 inches. About an inch to tall to fit in my garage . And any garage parking garage that’s 7 feet and under... needs to be 7’ 2 inches or more
    Most parking garage here in Vegas are 7 to 7 1/2 feet . I fit in half of them
  24. May 29, 2018 at 11:03 AM
    Corr2626
    Corey
    2014 Tundra Limited
    Thanks for your input Jsena! I appreciate it
  25. Apr 30, 2020 at 7:56 AM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    Any rust issues with the pro comp?
  26. Apr 30, 2020 at 10:15 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    i replaced the shocks once under warranty bc of rust second time i went fox that are holding up great. coils once on my own dime because of rust. these are holding up better but i cover them several times a year in wool wax.
    brackets are ok. have had some peeling of the powder but not horrible. lift is 12 years old also.
  27. Apr 30, 2020 at 10:24 AM
    sillydadztrksR4momz
    Oh wow ok good to know. Thank you. Ya I’m pretty disappointed I haven’t even had it for a month and the spindles already have surface rust and it’s parked on the garage and I live in southern Cali so I’m really worried what’s to come.
  28. Apr 30, 2020 at 10:38 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    They road salt here.
    I just pressure wash the undercarriage, spot prime any rust spots and touch up with some flat black Rust-Oleum industrial enamel.
    It's become an annual maintenance thing.
    The ProComp components are holding up just fine.
  29. Apr 30, 2020 at 10:42 AM
    sillydadztrksR4momz
    Thanks for the feedback
