Pressure washers
Discussion in 'Home Improvement' started by Kung, Sep 10, 2022.
  1. Sep 10, 2022 at 11:24 AM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    Between cleaning the house, the deck, and the vehicles, I figure it’s time to break down and buy a pressure washer. Any recommendations? Am trying to stay under/around $500 or so.
  2. Sep 10, 2022 at 11:30 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I've been looking also. I had an old Craftsman that gave up the ghost a couple of years ago.
  3. Sep 10, 2022 at 11:41 AM
    RobertD
    Robert
    DFW, Texas
    I like the convince of electric, and if you are just using this around your home it should be easy to run an extension cord. I have owned a Sun Joe (2k psi max) for like 6 years, and its been good but I do wish it had more power at times. I've linked one that is over 3k psi that is within your budget. A pressure washer is definitely handy to have.
    https://www.homedepot.com/p/Sun-Joe...lectric-Pressure-Washer-SPX8000-PRO/319700009
  4. Sep 10, 2022 at 11:43 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Been really happy with my Ryobi. It’s the 3300psi with the idle down feature and a Honda engine. Absolutely no complaints. We have the driveway attachment which works incredibly well. Like taking a 12” eraser to your pavement. I also bought a cheap foam cannon off Amazon for washing the vehicles. $449 @ HD.
    https://www.ryobitools.com/products/details/46396024138
    Mr Badwrench and NyCSnEaK like this.
  5. Sep 10, 2022 at 11:46 AM
    Retired...finally
    Kung[OP] likes this.
  6. Sep 11, 2022 at 6:23 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    I use mineral oil for storage.
    Drain left over gas, run it until it dies.
    Lean it back and put a couple cap fulls of mineral oil in the hose connection. A couple tugs on the starter rope until the oil comes out the pressure side.
  7. Sep 11, 2022 at 7:00 AM
    Mr Badwrench
    Mr Badwrench New Member
    If you're going to be using for heavy duty stuff around the house, try to get a Honda engine and a Cat pump. The pump is usually the weak link, get the best one you can. Honda engines are nice, they are pretty quiet.
    If you are doing light duty stuff, a harbor freight washer is probably all you need.
    AgileTundra likes this.
  8. Sep 11, 2022 at 7:07 AM
    Retired...finally
    I bought a Ryobi, a small one from Home Depot on sale a few years back for less than $100.00 delivered. Light duty but that keeps the wife from blowing holes in things like her feet.
    Many of these smaller units use the same wand which has a bad weak spot where the high pressure hose connects. I caught my wife holding on to the wand to thy to pull the stuck hose and it breaks the plastic on the handle. So if you get this type, support the hose with one hand and pull the hose, not the handle. My mother did the same thing with her Karcher.
    biebs96 likes this.
  9. Sep 11, 2022 at 7:08 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    +1 for anything with a honda engine. start on the first couple pulls.
    ATV25 likes this.
  10. Sep 11, 2022 at 7:22 AM
    JRS
    JRS New Member
    2012 DCLB
    I had the Ryobi. Mine had idle and high pressure delivery issues, but I didn't go through it and try to fix it. For how cheap they are I just ran it. It was replaced by this, which to me, is a superior unit: https://m.northerntool.com/shop/tools/product_200818033_200818033 Northern Tool seems to always carry quality stuff and this is their #1 recommended unit.
  11. Sep 11, 2022 at 7:32 AM
    biebs96
    PA
    I have two. A large, loud craftsman one that is almost 4K psi… which I never use, because it’s a bear to move and fuel and blah blah.
    my go to is the $89 1800psi electric ryobi one. I use it for everything. Works great with my foam cannon too. I’m sure I lost a little psi as I run a 50’ hose vs the 25’ it came with.
    It’s quiet, turns off when you are spraying and uses no fuel to worry about storing.
    Retired...finally likes this.
  12. Sep 11, 2022 at 7:40 AM
    Retired...finally
    That may be the same one I have. It's very handy and easy to get out and put away.
    biebs96[QUOTED] likes this.
  13. Sep 11, 2022 at 7:56 AM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
  14. Sep 13, 2022 at 7:05 AM
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    2018 Tundra DC TRD OR Silver
    GPM trumps PSI. simpson makes solid consumer washers. The Honda 3.5gpm model is solid. (They label dewalts)
    Get a cheap car wash foamer, tubing to match foamer inlet and 5 gal bucket. Pool store liquid chlorine (10-12.5%)
    Gain laundry detergent.
    cut chlorine 2parts chlorine to one water. Drop hose in mix bucket. Soak area, dwell 8-10 minutes. Rinse. Pressure is for concrete or stripping house to paint. 7415A67A-D707-4C6F-AAF2-4DAE552C2DE1.jpgor get a set up like I have. Honda 690 3000psi but 8gpm
    ATV25 likes this.
  15. Sep 13, 2022 at 6:10 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    ^^^. What he said. ^^^ I used to work at Cat Pumps as a test tech. We did comparisons against all other pump configurations. For longevity and trouble free operation you can’t beat it. One drawback is the price, but you would only need to buy one if properly winterized for storage.
