Pre programmed tpms sensors
Discussion in 'Wheels & Tires' started by Noeyes, Jun 10, 2021.
  1. Jun 10, 2021 at 6:47 PM
    Noeyes
    Noeyes [OP] New Member
    Shawn
    2021 tundra sr5
    Getting ready to swap my steel wheels on my 21 sr5 over to a set of platinum wheels from a buddy. I finally found the correct part number for the new sensors I need and found some aftermarket sensors that are programmed already and am wondering if anyone has used similar and how much luck they've had? I can get the aftermarket ones for 129 per set vs 90 each for OEM. Huf intelesense is the brand I'm looking at online.
  2. Jun 10, 2021 at 7:45 PM
    The 20/21's will need OEM sensors. Its a royal pain in the rear but the truck will register and program them. The procedure is in the manual.
    Noeyes[QUOTED][OP] likes this.
  3. Jun 11, 2021 at 6:51 AM
    Noeyes
    Shawn
    2021 tundra sr5
    Yeah I've read that. So the aftermarket ones are a complete no go or just not worth the effort trying to find ones that will register with the truck?
  4. Jun 11, 2021 at 6:57 AM
    Even the OEM sensors are a pain. It took forever to register mine but I'm still having problems getting the pressures to display. I ordered mine from Sparks...they were about $65 each.
  5. Jun 11, 2021 at 7:29 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    I did swap of 2020 Limited wheels to 2021 Nightahade wheels with TPMS already. Drove about 20 MPH around my neighbor hood with turns and brief stops for about 10 mins and they registered. I haven't had any issues as of yet.
    Noeyes[OP] likes this.
  6. Jun 11, 2021 at 7:44 AM
    Is the key low speed and what pressures did you have them set at? The issue I have is that they won't read on the display, but they show on my aftermarket radio.
  7. Jun 11, 2021 at 7:52 AM
    JerryH
    SOMD
    I think it was the low speed. I put them on about 30 miles from my house and drove home 50-70mph straight, no turns. They did not register. I hit the reset/program button in my driveway and then drove 20-25 mph around turns in my Neighborhood. It registered on my cluster as I do not have aftermarket radio. I had 40lbs in the tires.
  8. Jun 11, 2021 at 7:54 AM
    Thanks.....I'll try that.
    JerryH[QUOTED] likes this.
  9. Jul 4, 2021 at 6:44 PM
    Smallmouth King
    Smallmouth King New Member
    2021 Tundra Limited 4x4 Crewmax
    Bakflip MX4, Husky Liners X-ACT
    can you please tell me the appropriate part number for those? I have a 2021 limited crew max with keyless entry.
