Pre-collision sensor in grill problem!
Discussion in '2.5 Gen Tundras (2014-2021)' started by bensky, Feb 15, 2019.
  1. Feb 15, 2019 at 7:56 PM
    bensky
    bensky [OP] PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I have a 2018 Platinum CM and the sensor behind the Toyota emblem stops working when it gets covered by snow/slush (which seems like a magnet for the slush.) Then the PCS OFF light comes on until I stop and clear it off.
    I recently got hit by a chunk of asphalt and damaged the grill so I need to replace it.
    Anyone with the TRD PRO grill and the PCS sensor have this problem too. If it’s less prone to snow/slush collection, I’m going to switch to that grill.
    TIA!
  2. Feb 15, 2019 at 7:58 PM
    Huh, never heard of this issue before.....:anonymous:
    NCinCO and Black Wolf like this.
  3. Feb 15, 2019 at 8:01 PM
  4. Feb 15, 2019 at 8:05 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    If anything covers the sensor it'll stop working. It needs to be clear of debris, or it can't shoot out the laser beams.
    There's no harm in driving it, just be aware you can't use adaptive cruise and your pre-collision won't work until its clear again.
    Similar to how the clearance sensors will get angry if they are covered.
    You can't really do much to stop it from happening, when weather kicks up.
    If I'm understanding you correctly.
    Black Wolf likes this.
  5. Feb 15, 2019 at 9:36 PM
    bensky
    Ben
    Utah
    I’m trying to find out if the TRD PRO grill is less susceptible to the problem.
  6. Feb 15, 2019 at 9:42 PM
    Krezz
    Kevin
    Nope, just as. I have it fitted to my trucks and the rectangle gets covered the same as the oval. Not much of a noticeable difference between these two in that's respect anyway .
    ColoradoTJ likes this.
  7. Feb 15, 2019 at 10:05 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    You need one of these to keep that sensor clean....
