Prayer to the Toyota gods
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Dec 27, 2017.
  1. Dec 27, 2017 at 10:34 AM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Once upon a time, a man owned a 2007 Toyota Tundra 5.7l. He loved that truck but one really cold day (8 degrees), he heard the trucks starter grind for .33-.50 second during the initial startup. The man was concerned that this might lead to the starter going bad such as it did in his previous 2000 Toyota 4runner.
    He thought to himself "luckily replacing the starter is an easy job". Little did he know, the Toyota gods made this motor so that it was in a very inaccessible location. Why, why did the Toyota gods place the starter under the exhaust manifold and P/S pump?
    He thought, "Hopefully this is just a 1 time occurrence and this does not happen again...".
    He pondered the thought, "Can I lubricate the bendix without fully removing the starter".
    Can anyone answer this?
    I would like to lubricate the bendix to see if I could make it easier for the bendix to retreat back into its case (without fully removing the starter). I really do not want to do this job, I let it go on the 4runner for 3 years before it left me stranded once. Luckily the 4runner's starter was easy to replace (like all starters should be...).
    Black Wolf and NewImprovedRon like this.
  2. Dec 27, 2017 at 10:57 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't know the answer to either question, but this meme came to mind.
  3. Dec 27, 2017 at 11:39 AM
    kenomouth64
    Tetrus
  4. Dec 27, 2017 at 11:58 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Might be able to free it up a bit by hitting it hard. I've got a few military vehicles to start by doing this.
  5. Dec 27, 2017 at 12:03 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That’s how I got my kids to start when they were teenagers
  6. Dec 27, 2017 at 12:32 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    The ol’ technical tap.
    Army tested, Army approved.
    Black Wolf, aperezsh and JMB like this.
  7. Dec 27, 2017 at 12:57 PM
    I do believe you're not going to be happy, but the Toyota gods stuck it to you once again.
    Prostar 190, Black Wolf and aperezsh like this.
  8. Dec 27, 2017 at 1:33 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Might be a "Safety Issue", like the deleted driver's side Grab Handles on the third gens:devil:
  9. Dec 27, 2017 at 1:42 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    Excuse me, but the correct term is "mechanically agitated". I've used it many times in problem/resolution responses. :smash:
  10. Dec 27, 2017 at 1:48 PM
    TheBeast The Beach
    but does the man have a name and does he pray to the many faces god ?
  11. Dec 27, 2017 at 8:37 PM
    JMB
    Chesapeake, VA
    No but a girl has no name. "That man's life was not yours to take. A girl stole from the Many-Faced God. Now a debt is owed."
  12. Dec 27, 2017 at 8:45 PM
    Glad to see so many Game of Throne fans on here...
    kenomouth64[OP], TheBeast and JMB like this.
  13. Dec 27, 2017 at 8:48 PM
    TheBeast The Beach
    I read his post in jaqen h'ghar voice...
    kenomouth64[OP] and ColoradoTJ like this.
  14. Dec 27, 2017 at 8:52 PM
    TheBeast The Beach
  15. Dec 28, 2017 at 6:23 AM
    kenomouth64
    Tetrus
    Well, "A Man wonders what he is to do with this issue". A man does not have enough space to get his finger in the hole, a man calls upon another known as 'littlefinger' for the task at hand. The little man known as 'littlefinger' misinterpreted the hole the man needed his finger in....
    TheBeast, JMB and Black Wolf like this.
  16. Dec 28, 2017 at 6:30 AM
    The Tundra starter is located in there somewhere....[​IMG]
  17. Dec 28, 2017 at 7:25 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have always called home at least an hour before i get there, so she has plenty of time to get that “little finger” stud-muffin out of the house before I arrive...
  18. Dec 29, 2017 at 5:31 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    At 8 degrees, sometimes weird things happen. I would not worry about it yet.
    If it happens again when warmer, then you may have a problem.
    kenomouth64[OP] likes this.
