Power Window Lock Out Switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by Farmer24, May 14, 2018.
  1. May 14, 2018 at 5:57 PM
    Farmer24
    Farmer24 [OP] New Member
    2017 Blue Tundra Platinum
    Bed rug, SnugLid tonneau
    New member her with a 2017 Tundra which replaced a 2007 Tundra.
    Noticed something that seems wrong with the operation of the Power Window Lock-Out Switch.
    With my other Tundra and all other vehicles I have used with power windows that have a lockout switch, when the lock-out switch is activated, the master panel (driver's door) can still operate the windows on all other doors.
    The owners manual seems to indicate that this truck should act the same way as the text reads: "Press the switch down to lock the passenger window switches.". The key phrase being 'passenger windows switches'.
    My truck doesn't act that way. With the switch activated, the only window I can open from the drivers window panel is the drivers window. I cannot operate any of the other door windows unless I de-activate the lock function.
    I feel this is WRONG. Where is the safety in preventing children from opening the window, if I have to disable the lock feature to change one window and at the same time that enables another child to open another window.
    I tried to get the dealer to fix it but they said it was normal operation and even showed me other Tundra's that acted the same way. Regardless of what they said (and showed me), I still feel it is WRONG and a safety exposure,
    I tried to search on this site but nothing in my search results looked promising.
    Before sending a complaint letter to Toyota, I thought I would ask here to see if anyone else has noticed this and maybe found a service bulletin regarding the strange behavior
    Thanks in advance for any direction, suggestions or help you can provide,
    Bob
    Rider0120 likes this.
  2. May 14, 2018 at 6:43 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Funny story. On my 2006 Tundra I noticed one day that I could not operate the passenger window. It was stuck down and I couldn't raise it. It was during the rainy season and I was SOL plus I couldn't lock the truck if it was not raining. So I parked it in my garage and ordered an after market window motor and window lift system for replacement. Got it, installed it and decided to test it before buttoning up the door. It didn't work either!
    After running voltage and fuse tests I notice my lockout switch was depressed. Pushed the button and it worked perfectly. So did the original which I re-mounted. So I have a brand new passenger window motor assembly in my storage room at the barn.
    Dipwinkle Danny at your service!
    NewImprovedRon, Black Wolf and nk1794 like this.
  3. May 14, 2018 at 6:51 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s how mine works too. My previous chevy was the opposite. I could lock everyone out but still have control. For me it’s not a problem I don’t have little kids. But it works great for giant Dutch oven‘s.
  4. May 14, 2018 at 6:55 PM
    :rofl: how ya feeling?
    15whtrd[QUOTED] likes this.
  5. May 14, 2018 at 6:56 PM
    Welcome from Texas
  6. May 14, 2018 at 7:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Little better. Still aching and light headed. In a fog.
  7. May 14, 2018 at 7:46 PM
    Get well
  8. May 14, 2018 at 7:46 PM
    15whtrd
    15whtrd Mr. Blonde
    Thanks brother
  9. May 14, 2018 at 7:47 PM
    Yes Sir
  10. May 15, 2018 at 4:14 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I'm with you OP.On my previous Chevy 2500 when I used the passenger window lock out button I could still run all the windows from the driver's seat.With this Tundra I have activate/deactivate the button to have control of all the windows when using the lockout switch.Still getting used to the differences.
  11. May 15, 2018 at 4:38 AM
    My 07 works the same. Only driver window functions with safety switch depressed.
  12. May 15, 2018 at 7:02 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    2012 mine works the same.
  13. May 16, 2018 at 9:57 AM
    Farmer24
    Well, it seems the consensus is that only the driver's window can be operated from the driver's panel when the lock out switch is activated, even tho the owner's manual appears to indicate that only the passenger panels should be locked out thereby implying the driver's panel should still be active for all windows.
    I feel this 'normal' operation is NOT appropriate and is in fact a safety related issue. I would like to correspond with Toyota regarding this. Can anyone suggest who or where I should send this correspondence to in order to get a definitive response on how the switches 'should' respond to the lock out switch.
    If I am not satisfied, I may forward it to the NTSB.
    Thanks
  14. May 19, 2018 at 4:13 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    I'm with you about being annoying and a safety issue since I have 2 kids, one being 3 1/2 and is able to operate his window. He has learned that he can hold the switch while I use the lockout button and try to closes his window, and when I'm trying to close it he's trying to open it, the window just stays in the same position. It's annoying that the window lock lock me out as well as the passengers. My wife's Hyundai does the same thing as my truck. This issue should go to the NTSB and a standard should be made before a accident happens, but unfortunately safety is written in blood.
  15. May 22, 2019 at 5:26 AM
    Topherwv
    Topherwv New Member
    Bump. This is driving me crazy. My Tacoma acted normal in that it locked out everyone but me. It's a constant game of battleship with my 3.5 old boy who thinks getting rain on down the highway is an amusement park.
    There should be a by pass module or something of that nature to allow a simple function mod. Has no one been able to find a remedy?
  16. Jun 5, 2019 at 1:33 PM
    Topherwv
    Topherwv New Member
  17. Jun 9, 2019 at 9:48 AM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    I don't see the conflict, Bob ("Farmer24"). The manual ("lock the passenger window switches") doesn't imply anything other than the passenger window switches (all of them, including yours) are locked. In truth, having another window switch (your "master panel") override that is unsafe. You could mistakenly operate that overriding switch, allowing a child or whatever to fall out a window. If it's important to lock the windows, they should remain locked until you make an unmistakable effort to turn that feature off. Since this is the logical behavior, Toyota obviously has no incentive to change it, much less issue a "service bulletin."
