Power window failure points?
Discussion in '1st Gen Tundras (2000-2006)' started by Dwarven1, Apr 14, 2021.
  1. Apr 14, 2021 at 2:34 PM
    Dwarven1
    Dwarven1 [OP] New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Got a 2000 SR5 that I'm putting up for sale, and as it's not been run in a couple of weeks I decided to use it for a dump run. (Well, that, and I'm damned if I'm going to put two dozen cans of expired paint and a few fluorescent bulbs in my new 2018!!)
    Anyway, the right (passenger) power window won't go down. Now, over the winter, I had to replace the master switch (in the driver's door) AND the regulator and motor in the passenger door. So the parts are still under warranty; I'm just more curious about what could have failed? It looks like the power locks and both windows are on the same fuse - a big 30A job in the cab, right?
    So if not that, because the driver's window and the locks work, could the replacement motor or master panel have failed?
  2. Apr 14, 2021 at 3:08 PM
    Professional Hand Model
    Hand Protectors
    Asking an obvious question: Is your pass side window safety switch On or Off?
  3. Apr 14, 2021 at 3:16 PM
    Dwarven1
    Ross
    Yes.
    It doesn't work no matter what position it is in.
  4. Apr 14, 2021 at 3:20 PM
    Hand Protectors
    bmf4069 and BubbaW like this.
  5. Apr 14, 2021 at 3:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    see that your crazy pills are still wearing off :crapstorm:
  6. May 20, 2021 at 9:39 AM
    Dwarven1
    Ross
    Turns out that the replacement motor was burned out and was replaced (again) at no charge under the parts warranty. (Yeah, I have a REALLY good garage.)
