Power when brand new
Discussion in '2.5 Gen Tundras (2014-2021)' started by PA452, Jun 16, 2021.
  1. Jun 17, 2021 at 5:50 AM
    15whtrd
    15whtrd Mr. Blonde
    Do you think the 2011 just felt like it would smoke the other ones, or do you think it would all be similar in the quarter mile? Obviously if they all have the same set up.
  2. Jun 17, 2021 at 5:51 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Same. Tow haul is too sensitive for me. Have never driven one of the older 3rd gens as this is my first tundra but mine will get up and go whenever needed in normal drive. Definitely feels peppier than my 2018 5.3 Silverado
    Oey12 likes this.
  3. Jun 17, 2021 at 6:15 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    It’s definitely rocket mode on my 2020. I easily chirp the wheels pulling out from stops hence why I don’t use it all the much. It maybe Toyota made some simple tweaks to up the mpgs by a hair…for when it’s no engaged.
  4. Jun 17, 2021 at 6:50 AM
    Kung
    KG, VA
    This. I mean, if I get on it, I can chirp the tires withOUT TH mode engaged on my 2020; I can flat lay rubber down a bit with TH and/or 'beast mode.'
    Oey12[QUOTED] likes this.
  5. Jun 17, 2021 at 7:12 AM
    PA452
    PA452 [OP] New Member
    2021 Tundra SR5 CM TRD O/R
    Tow/haul was pretty sensitive in my '18 as well. You had to be very light-footed to not chirp the tires when starting from a stop. Even pulling a trailer I'd have to go easy on it. I'd mostly only use it when pulling a trailer. It was also nice on the rare occasion I'd want to pass someone on a two-lane.
    I thought maybe it was possible they have it programmed to go a little easier on it during the break-in period, but I don't know how likely that is.
  6. Jun 17, 2021 at 7:15 AM
    War Machine
    War Machine SSEM # 5 3MW
    No, I’ve still got it and it’s definitely faster off the line by a wide margin. There’s a big difference in both the takeoff, and hitting the passing gear. Tow/haul mode on the 2017 is close to the same as the 2011 without it, but not quite, and it feels smoother in the Gen2. The 2011 has tow/haul mode also. Haven’t really used it, but I’d assume it has the same effect.
    There’s other variables involved though. The 2011 is a DC 2wd with no lift and smaller tires. My 2017 is Crewmax, with a 3/2 level and bigger tires, so it’s not exactly apples to apples. That said, I did test drive a Gen3 with the same setup as the 2011, and it was noticeably more sluggish.
    15whtrd[QUOTED] likes this.
  7. Jun 17, 2021 at 12:08 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Toyota updated the engine / transmission tune in 2019 , better shift mapping and throttle response . Plus the OP having a new truck the transmission adaptive tables still are learning his driving style .
  8. Jun 17, 2021 at 2:09 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Black Wolf likes this.
  9. Jun 17, 2021 at 2:40 PM
    Being left handed.....quite frankly I'd like more left handed engineers involved.......
    2mchfun[QUOTED] likes this.
  10. Jun 17, 2021 at 2:41 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I actually think my 2021 DC is quicker and more responsive than my 2019 DC. Same exact setup….:monocle:
  11. Jun 17, 2021 at 4:02 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    My ‘21 feels about the same as my ‘19. The biggest difference is the ‘21 consistently got about 3-4 mpg less than the ‘19 before I upgraded the tires. Other than that, it’s pretty much the same truck as far as engine/transmission.
  12. Jun 17, 2021 at 7:25 PM
    PA452
    I figure by the time it fully adjusts, and as I get used to it, fair chance I'll have forgotten exactly what my '18 felt like.
  13. Jun 17, 2021 at 9:08 PM
    GatorBodine
    GatorBodine New Member
    I don't believe vehicles "learn" each individuals driving styles. I could be wrong though. Never known a vehicle to think to itself, "hey this guy likes hard acceleration off the line, let me adapt myself to his driving habits". The motor and trans all come the same with the same throttle and transmission programing from the factory. A young buck's heavy lead foot isn't gonna make his 21' Tundra any faster then grandpas light foot in his 21' Tundra. Same motor, same trans, same computer
  14. Jun 17, 2021 at 9:13 PM
    PA452
    Pretty sure it's a thing.
    My 2007 Tacoma was the first vehicle that I was told would do that; it was a manual transmission. When the original battery died, it was like driving a different truck when I hooked up the new one. It all reset to factory. The difference was much more noticeable with a manual transmission.
    GatorBodine[QUOTED] likes this.
  15. Jun 18, 2021 at 4:27 AM
    BrakeDust
    Hill Country, TX
    I'm not sure it does either.
    But just to be safe, I make sure to floor it at least a couple times a week so it knows who's boss!
    2mchfun and GatorBodine[QUOTED] like this.
  16. Jun 18, 2021 at 5:17 AM
    jordoncloutier
    Jordon
    Alberta , Canada
    Google " adaptive transmission shift strategy " its been a thing since early 2000's
    GatorBodine likes this.
