Power Tailgate Lock: Wiring Splice > 2013 Tundra Plat
Discussion in '2nd Gen Tundras (2007-2013)' started by AussieSteveGuy, Jan 3, 2021.
  1. Jan 3, 2021 at 9:14 PM
    AussieSteveGuy
    AussieSteveGuy [OP] New Member
    WA State, USA
    2013 Tundra Crew Cab Plat
    Pop & Lock Tailgate Power Lock, LoMax folding aluminum bed cover
    Hi there - newbie question. Looking for location of passenger side rubber grommet. I’m installing a Pop & Lock tailgate Power Lock. For the life of me I can’t figure out the entry point to bring in the wire at the passenger front. Tips? What am I missing?
  2. Jan 3, 2021 at 9:19 PM
    Welcome from NY.
    It's kinda in the center of the passenger side floor pan but to the right. Looking at the passenger side frame rail lookon the left side of the rail, it's pretty much tucked in by the frame.
    AussieSteveGuy[OP] likes this.
  3. Jan 3, 2021 at 9:27 PM
    AussieSteveGuy
    WA State, USA
    Thanks Jim. I was looking toward the front, not under the crew cab. That did it!
  4. Jan 3, 2021 at 10:18 PM
    AussieSteveGuy
    WA State, USA
  5. Jan 3, 2021 at 10:37 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    KTJO makes a Plug N Play harness for this, it's part of their tailgate lock kit, but can be sold as just a harness. I have it on my 2016 and use the Pop Lock tailgate lock kit as well. I don't like to cut or splice wires if I don't have to.
    The easiest way is to locate the connector first, find the one that matches the instructions and count the pins based on how the connector looks facing you. That's how I did it on my 2014, before this harness came out.
    https://www.ktjo4x4.com/product/2nd...ock-plug-n-play-harness-2007-2013-/28?cs=true
    Mr. Wasteland and Skew12 like this.
  6. Feb 20, 2023 at 1:54 PM
    TundraSteven
    TundraSteven New Member
    Hi Steve! I am going through the exact same situation you did. Were you able to figure out those wires? I already spliced into two of them that a video recommended on youtube but that didn't work. Any help would be appreciated.
  7. Feb 20, 2023 at 4:38 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I had this problem, too. Toyota changed the wire colors over the years. This is the video that had the right color wire for my 2008: https://youtu.be/6ly6hg0nz0Y
    That might not be right for you... I think I tried 5 different wires from 5 different write-ups before I found the one. Sorry I don't have a better answer.
