Power Steering Rack damage caused by 6 inch lift?
Discussion in '2.5 Gen Tundras (2014-2021)' started by GSXR1Kstang, Jan 8, 2016.
  1. Jan 8, 2016 at 9:08 AM
    GSXR1Kstang
    GSXR1Kstang [OP] New Member
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    So far, just a Westin Bull Bar and custom made Flowmaster exhaust.
    For Third Gen (Maybe 2nd Gen also) Tundra owners:
    I've been doing plenty of research of 6 inch lifts, mainly to prevent premature wear to other components. While I'm not sure on which OEM parts need to be replaced to prevent wear to minor parts, I was told something interesting by at the local Toyota dealer.
    One of the workers advised against getting anything above a 3-4 inch lift. According to him, the lifts (combined with heavier wheels), cause the power steering rack to bend. He claimed that they constantly have lifted Tundra's coming in with steering rack problems caused by the 4+ inch lifts. He also "claims" (although I smell BS on this one), that the motor has to be pulled out just to replace the steering rack
    Has anyone had this problem or know anything about it?
    Tj6818 likes this.
  2. Jan 8, 2016 at 10:02 AM
    I replied to ur other post, but anything up to 4" of lift is usually the safest.
    GSXR1Kstang[OP] likes this.
  3. Jan 8, 2016 at 10:13 AM
    PlatPro
    PlatPro New Member
    Randall
    A silk gloved hand with brass knuckles underneath.
    2014 Platinum, TRD Pro Suspension , Truxedo Bed Cover, Vent Shade Rain Guards, Tint match windows,TRD Exhaust, Linex, Custom Dyno Tune, TRD SwayBar, and just started.
    The rack is of a car design. Yes they build it up for truck use but it is still a car design. Long term I would stay under 4" and 35" is really pushing the components at that angle. Most daily driver/ long term owners go with a 3/1 slight lift and level kit for best long run performance.
  4. Jan 8, 2016 at 2:40 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looking underneath, I'm wondering if you could just unbolt the engine mount and carefully lift the engine a bit to get the rack out.
    As far as lifts go, I think a control-arm type lift that uses spacers, coilovers or a combination thereof, that's more than 3" places the suspension and steering geometry at too high of an angle. I think that may be where the rack damage is coming from, especially when adding the weight of bigger and heavier tires. I can see ball joints and CV axles prematurely wearing with increased angles also.
    I'm wondering if a bracket-type lift, where drop-down brackets are used, would still cause steering rack damage. I'm only vaguely familiar with those, never having installed one, so I don't know. I do know they retain for the most part the suspension and CV axle angles. I don't know if they retain the tie rod angles, though, but maybe they do? If so, then I guess the bigger and heavier tires from such a lift may still place added stress on the steering rack, but at least the angles would be at or near the stock geometry.
  5. Jan 9, 2016 at 4:54 PM
    GSXR1Kstang
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    Yea, I know you replied. I just wanted to ask the question in the proper section. Thanks!!
  6. Jan 9, 2016 at 4:56 PM
    GSXR1Kstang
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    I did not know that fact about the steering rack being of a car design. That must be one of the reasons for the steering being so smooth.
    Isn't there anyone out there that sells aftermarket racks that are beefed up?? My wife had a Chrysler 300 that was constantly having rack issues due to poor design. I bought an aftermarket rack and never had another problem with it.
    So you think that 35" would be too big of a tire?
  7. Jan 9, 2016 at 5:04 PM
    GSXR1Kstang
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    I know a lot of guys use drop brackets on 6 inch lifts, but none of them have Tundras.
    The closest I have to first hand knowledge of Tundras with 6" lifts is the dealer. My local dealer was selling lifted Tundras (brand new) and sending them to a place called Keystone Styling, located near Harrisburg, PA. That place was using Rough Country kits, and all the trucks that they did ended up being shit. Again, I wonder if it was them not installing the kits right or using Rough Country kits to begin with. Or maybe a combo of both. But I do know the trucks they were doing were coming back with rack problems.
    MotoTundra likes this.
  8. Jan 10, 2016 at 8:37 AM
    equin
    Ed
    DFW, TX
    I've seen the drop-bracket lifts on 1st gen Tacomas, but not on any Tundras yet. Although they do retain the stock suspension geometry, I don't remember if that also applied to the tie rod ends and steering rack. Although these lifts do allow more room for bigger tires, they don't necessarily provide more ground clearance since the brackets supporting the suspension were lowered correspondingly, despite the bigger tires.
    I'm not familiar with the Rough Country lifts, and I don't think you can use a combination of spacers and coil overs alone to achieve 6" of lift up front by pushing down on the control arms. To achieve lift that way, you have to use available down travel, and there's only so much of it. Plus, you'll also risk breaking ball joints and CV axles if 4wd. But I could be wrong about that due to my unfamiliarity with the Tundra Rouch Country lift.
  9. Jan 10, 2016 at 2:34 PM
    GSXR1Kstang
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    I've seen a lot of pictures here of 3rd Gen trucks with 6". I wonder how those guys are fairing?
  10. Jan 10, 2016 at 7:09 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I can verify what that dealer told u. We've done quite a it of steering related repairs on trucks woth larger the 3 inch lifts. Racks, pumps... they strain alot with those larger lifts/tires. As for the rack replacement, yeah it's under the engine. Real pita to replace
  11. Jan 10, 2016 at 7:27 PM
    GSXR1Kstang
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    Thats unfortunate!! :-( What would you suggest? No more than 3-4 inches? And even with only 3-4, would 35s be too heavy??
  12. Jan 11, 2016 at 7:14 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    3 to 4 inches and 35s correct. No bigger
  13. Jan 11, 2016 at 7:25 AM
    GSXR1Kstang
    Gene
    Pennsylvania, USA
    2014 Tundra SR5 TRD
    Ok, well thanks for the info! In spite of how disappointed I am in not being able to go with a 6, there are some plus sides to it. It's a lot easier to find a good 3-4 lift, and cheaper! And I won't have to worry about sacrificing ride quality and mpg!
  14. Jan 11, 2016 at 10:05 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Taking tire size out of the equation, with drop bracket lifts you actually swap tie rods (driver's side to passenger and vice-versa) and then attach the tie rod to the top->down rather than bottom->up. Meaning there's actually less stress on the rack in terms of geometry than compared to a 3" coilover/spacer lift. Blaming the lift is easy since it's not a Toyota product.
    jeremyd, texasrho83, GNTundra and 3 others like this.
  15. Jul 1, 2018 at 6:23 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    So from the multiple thesis’s , what is the final verdict? Is there a good-fix?
    TXRailRoadBandit73 likes this.
  16. Jul 1, 2018 at 6:30 PM
    :popcorn:
  17. Jul 1, 2018 at 6:33 PM
    Not knowing what I was getting into when I saw the one I wanted, '14 CM 4WD with 6" RC lift, and according to RC rep, since I've been looking underneath it since I bought it, it's a older model spacer kit because the rear crossmember is not cut out as per the instructions shown on their site, bought truck used mid '16 with 26000 miles now at 58200 starting to hear some creaking noises up front
    Les7311 likes this.
  18. Jul 1, 2018 at 6:36 PM
    Thinking noises coming from either upper or lower ball joints or UCA's to extended steering knuckles from kit and never taken truck serious off-roading
  19. Jul 1, 2018 at 7:35 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I have a 2014 with a 6 inch and 35's for the last 40000 miles. Zero issues. My buddy has a 2008 with the same lift, Zero issues. I don't think the steering racks are bending. Although I do believe the steering stops are not being installed/ welded which is most likely causing the steering rack leakage.
    Poseidon 762 and Les7311 like this.
  20. Jul 1, 2018 at 7:40 PM
    Les7311
    ........ so if the rack is leaking, does keeping the PS fluid level at full causes any immediate concerns?
    jeremyd likes this.
  21. Jul 1, 2018 at 7:41 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wanna say @Blueeagle68 has spacers with Fox coils to get 8" of lift but his is a Pro Comp system IIRC.
  22. Jul 1, 2018 at 7:43 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    If it's leaking slowly, it's collecting in the boot.
    texasrho83 likes this.
  23. Jul 1, 2018 at 7:44 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've got a Readylift 6" kit & 35s (won't go any larger) on my '16 and am about to hit 40k miles. Zero issues here. Matter of fact, I just had the dealer check out the PS pump and steering to confirm.
    Les7311 and jeremyd like this.
  24. Jul 1, 2018 at 7:52 PM
    Les7311
    I noticed a drip on passenger side and at the lowest point on f sway bar. But couldn’t trace it.
    Where should I start the Dx?
  25. Jul 1, 2018 at 7:59 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Have you added fluid to the power steering reservior ? It doesn't dissapate. If you have. then most likely it's sitting in the boot.
    Les7311[QUOTED] likes this.
  26. Jul 1, 2018 at 8:14 PM
    Les7311
    The reservoir is full.
  27. Jul 1, 2018 at 8:16 PM
    Les7311
    If worse comes to shove, I see a DIY project. Already watching some YouTube vids which doesn’t seems hard.
    Am on a 6 inch RC w 4x4, and that part am scratching head.....
    texasrho83 and jeremyd like this.
  28. Jul 10, 2018 at 5:45 PM
    Les7311
    Well the dealership gave the Toy a clean bill of health.
    The rust protection sealant done last November is basically sweating from the extreme heat, and still in its curing state.
    Checkmate!
  29. Jul 10, 2018 at 6:16 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I was quoted $900 to pull the rack to swap the bushings by lifting the transmission, previously done on a shop Tundra.
  30. Aug 5, 2018 at 1:54 PM
    Bart 4x4
    Bart 4x4 New Member
    2010 Tundra 5.7 4x4 Big Cab, what ever it's called.
    ARB leveling kit 2.5 inch front, add a leaf rear, plus one inch shim in rear to maintain rake. ARB Lockers front and rear. Bush Wacker fender flairs, with Nitto Trail Grapplers.
    I gotta get a picture for this account. My Power Steering just failed. The fluid drained into the boot for the rack. Has anyone seen an aftermarket power steering replacement kit for a 2010 Tundra? I am going to contact Rare Parts tomorrow to see what they have, very few people supplying this part.
