Power steering fluid leaking, 01 Tundra AC
Discussion in '1st Gen Tundras (2000-2006)' started by 400kTundra, Jul 28, 2025 at 12:13 AM.
  1. Jul 28, 2025 at 12:13 AM
    400kTundra
    400kTundra [OP] New Member
    Sunday
    2001 Toyota Tundra AC 4.7 V8
    This truck has almost 400k miles has been so good to us until recently. Main problem right now is power steering, doesn’t leak until we turn it on then just starts draining from a little above the steering rack. Power steering hoses need to be replaced soon but it doesn't look like it’s leaking from a hose, I don’t have a lot of experience working on vehicles but looks like it’s coming from somewhere on the rack and pinion. Maybe it’s a O ring or some kind of bearing that finally disintegrated and is just leaking everywhere when the truck is running. Any suggestions on what to do would be helpful thanks. Looking to replace everything myself I have access to a lift.
    Video link:
    https://vimeo.com/1105028524?share=copy
    Also other parts that need to be replaced are: UCAs, LCAs, all ball joints, struts (I have Bilstein 4600s already), and Valve cover gasket. I’m considering buying after market parts for these, any suggestions on quality parts here or just stick with OEM?
  2. Jul 28, 2025 at 3:47 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    First you need to get some engine degreaser and clean it up so you can actually see what is leaking. OEM only for LBJs (unless you want to die on the freeway) and valve cover gaskets. Once your figured out where it’s leaking we can go from there.
  3. Jul 28, 2025 at 5:04 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    That's what the mechanic did when my Tundra was losing PS (AFT) fluid. Leaking hose that was easily replaced.
  4. Jul 28, 2025 at 7:52 AM
    shifty` Oh, I have felt Cobain's sarcoma
    The valve cover gaskets are notorious for leaking, and raining oil down onto everything below.
    Start here: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    That's our collective community knowledge sharing all the stuff you really need to be warned about with these trucks before you start digging too deep into breathing life back into it.
  5. Jul 29, 2025 at 2:22 PM
    400kTundra
    Sunday
    Thanks for the replies but it was 100% leaking from up and out of the steering valve. We bought a refurbished steering rack and fix fixed the problem there.IMG_9975.jpg
    ChattanoogaPhil and shifty` like this.
