Power Running Boards
Discussion in '3rd Gen Tundras (2022+)' started by SoCalJose, Nov 3, 2022.
  1. Jan 7, 2023 at 10:28 AM
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    Go Rhino Running Board Pics
  2. Jan 7, 2023 at 10:36 AM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Looks great against the MGM color. I’m a little concerned how they will look against WCP.
  3. Jan 7, 2023 at 10:41 AM
    Point Man
    Mark
    2023 1794 MGM
    Just like any running board I reckon. With the WCP you'll have the Star Wars Storm Trooper look going on. Throw some black wheels on her and intimidate everyone on the road:D
  4. Jan 7, 2023 at 10:43 AM
    Yota802
    Yota802 New Member
    Good idea!
  5. Jan 7, 2023 at 10:46 AM
    Point Man
    Mark
    2023 1794 MGM
    This is a good look. Running boards look fine
    Yotax109 and Piki like this.
  6. Jan 7, 2023 at 10:50 AM
    Yota802
    Yota802 New Member
    Yes it does!
  7. Jan 7, 2023 at 10:52 AM
    Yota802
    Yota802 New Member
    Which finish did you go with? Any pictures of where the manual override switch gets installed? Did you buy direct - $1600?
  8. Jan 24, 2023 at 2:41 PM
    Kepaniamekolea
    Kepaniamekolea New Member
    Kendall
    Kailua-Kona, HI
    2022 WCP 1794 TRD Off-Road
    Yours has 3 motors? Is it a newer model? 2022 version just has 2 motors
  9. Jan 24, 2023 at 4:15 PM
    manapiko
    manapiko New Member
    Patrick
    Soon to own 2023 TRD Pro
    I think its just three hinges and two motors
    raylo and Kepaniamekolea like this.
  10. Jan 24, 2023 at 4:17 PM
    Point Man
    Mark
    2023 1794 MGM
    Correct. Two motors on each side. Three brackets.
    Kepaniamekolea likes this.
  11. Jan 24, 2023 at 4:18 PM
    Point Man
    Mark
    2023 1794 MGM
    Yes I bought direct from GoRhino. Manual switch is on the underside of the dash above the gas pedal. Went with the powder coated finish and not the bedliner finish
  12. Jan 24, 2023 at 6:01 PM
    Kepaniamekolea
    Kendall
    Kailua-Kona, HI
    If you dont mind, can you tell me how many inches does the step end up below door? I'm still undecided because I feel like I may need amp xl with extra 3" drop cause I'm planning on 6" lift with 37s.
  13. Feb 2, 2023 at 5:22 PM
    Yota802
    Yota802 New Member
    Is there an option to keep them open/down when parked at a parking or whatever, potentially to help from dings.
  14. Feb 3, 2023 at 10:24 PM
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Fox 3.0 Camburg UCA's and Trailing Arms KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV K&N Cold Air Intake and charge pipes Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs and Focal Components 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
  15. Feb 4, 2023 at 6:03 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Seeing all the different options available now, maybe I should of waited to buy OEM. They are still in boxes.
  16. Feb 4, 2023 at 6:37 AM
    Breathing Borla
    AZ
    The oem ones are really nice , the test drive truck had them when I took one out. The advanced package was a must have for me so mine has that coming
  17. Feb 4, 2023 at 8:14 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    When I bought my Tundra a couple weeks ago they had a pre-owned Capstone CM short bed in the showroom that had these. I opened the driver door to take a look inside and the board extended. Agree it is a very nice feature. Went back 2 days ago to pick up my plates and that truck was still there. If it had been a long bed I would have given it some consideration but you always have to wonder what's up with such a new vehicle being turned in so soon.
  18. Feb 4, 2023 at 8:21 AM
    Breathing Borla
    AZ
    Plus the capstone is a rip off, it’s way more money than a platinum and you get a panda bear interior and laminated side windows, oh boy
    DexterL likes this.
  19. Feb 4, 2023 at 8:33 AM
    #49
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Well, it wasn't an option for my truck. SR5. I bought all the comments from Toyota, minus a wiring harness I'll have to make. Ya Capstone seems to much of a premium for what you get.
  20. Feb 4, 2023 at 8:36 AM
    #50
    raylo
    Frederick, MD
    Nice, shouldn't be too hard an installation. Only hard part is finding the door trigger wires and figuring out how much of the interior needs to be disassembled in the process to run the harness and make those connections. The board mechanical install itself should be easy.
  21. Feb 4, 2023 at 10:46 AM
    #51
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    And don't forget it more chrome and the 22" wheels... Then Panda Bear interior is a different leather-ish material than the Platinum as well. $10 difference, nope, not going to do it.
  22. Feb 4, 2023 at 11:02 AM
    #52
    Maharisc
    Maharisc w/Patty
    Karl
    The thing about OEM vs aftermarket, is the OEM comes with the power bed-step. If you compare the powered bed step to the manual, there is about a 6" drop difference. The manual is lower and makes for 22" stretch from step to tailgate and 13.5" off the ground. Where the powered is nearly centered at 16" between ground and step with an 16" also between the step and tailgate. I have had both, manual on 22 Tundra DC TRD-OR with TRD Lift and now 23 Tundra Plat w/ adv package and powered running boards w/ powered bed-step.
  23. Feb 4, 2023 at 4:27 PM
    #53
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ya, the boards and motor are a cinch. I put Amp steps on both my other Tundras. I'm more concerned on these because it has its own ECU that is also tied to the truck. I hope my truck doesn't have to be flashed to recognize the steps. I can't remember but I think someone said there's info about the steps in the cluster. Maybe just the hybrids though.
  24. Feb 4, 2023 at 4:39 PM
    #54
    Maharisc
    Maharisc w/Patty
    Karl
    Nope, nothing in the cluster for the running boards on the Hybrid.
  25. Feb 4, 2023 at 4:46 PM
    #55
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. I thought there was. That's good news.
  26. Feb 5, 2023 at 3:10 AM
    #56
    raylo
    Frederick, MD
    I perused the install instructions for the GoRhino electric boards. These at least seem to have no interface with truck computers. They have a controller module and +12v and ground for main power and connections to the door circuits to sense door open and close position. Maybe you could obtain one of these harnesses and make it work by changing the connectors.
  27. Feb 5, 2023 at 5:36 AM
    #57
    chastings1954
    chastings1954 New Member
    charles
    capstone
    I think the OEM boards retract if the truck is put in gear.
  28. Feb 5, 2023 at 5:41 AM
    #58
    raylo
    Frederick, MD
    The only one I have seen was that Capstone in the dealer showroom. That one lowered the boards when I opened the door, and raised them when I shut it. Not to say it doesn't do other things with them as well when it's running. Although when you think about it there is no reason for the boards to take any action other than from the doors. If a door is open on one side the boards on that side should be down. And if shut, then the boards should be raised.
  29. Feb 5, 2023 at 5:53 AM
    #59
    John_in_NC
    John_in_NC New Member
    North Carolina
    2022 Black Toyota Platinum
    Side Steps
    How far do do they drop down, good for vertically challenged partners?
  30. Feb 5, 2023 at 5:58 AM
    #60
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    So you installed factory running boards and did away with the ECU for them?
