Power running boards question
Discussion in '3rd Gen Tundras (2022+)' started by randomquickness, Dec 20, 2021.
  1. Apr 28, 2022 at 11:34 PM
    mrkheiser
    mrkheiser New Member
    Hello— I just bought a 2017 tundra 1794 with the automatic running boards but I can’t figure out how to work them..
    the seller told me he removed the fuse so they would stay in the up position (he didn’t like them) but I can’t for the life of me find the fuse nor can I identify a button to activate them.
    my passenger running board is stuck down and driver stuck up
    thanks in advance
  2. May 1, 2022 at 9:25 AM
    MJPlat
    MJPlat New Member
    Try asking on the 2nd gen forum, you might have better luck there
  3. May 1, 2022 at 9:45 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You'll need to start chasing wires from the power supply. I bet you run into a fuse not too far along from the source
  4. May 1, 2022 at 9:46 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The Aries ActionTrac boards will definitely prevent cart dings and they're powered.
  5. Oct 25, 2022 at 4:01 PM
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Try looking under the driver seat or passenger seat (under the truck) and see if you have this plug. Obviously would have a cap if is outside. IMG_5553.jpg
    Or look on either side, driver or passanger seat, remove the small plastic panel and see if close to the main harness as in the second picture. IMG_5558.jpg
    if you see that rubber plug from outside, than the plug may be inside under the carpet.
  6. Oct 26, 2022 at 2:37 AM
    Kepaniamekolea
    Kepaniamekolea New Member
    Kendall
    Kailua-Kona, HI
    2022 WCP 1794 TRD Off-Road
    Anyone have pics of one installed on a 2022?
  7. Oct 26, 2022 at 4:25 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't think they make them yet
  8. Nov 6, 2022 at 7:30 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Will the OEM AMP power running boards work on a 2023 Limited crewmax truck?
    regarding functionality, I know they fold in/out with unlock/lock with doors. Is there a switch or something where you can run or override manually?
    Also, I’ve received mixed reviews in certain elements, like snow, ice, and salt creating issues with power running boards. Any feedback on this?
    MateoAirborne likes this.
  9. Nov 7, 2022 at 8:54 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Ran AMP steps for over 500k miles in MT, ID and WY winters and only had them get stuck 1 or 2 times. I was good about kicking ice and snow build up off of them though and spraying them at the car wash every week or so.
  10. Nov 7, 2022 at 9:29 AM
    Yota802
    Yota802 New Member
    Thanks for the feedback.
    Has anyone installed on a Limited? I’m not sure if they will work?
    I believe the interior switch goes next to headlight adjuster, which mine is blank/available for a switch.
  11. Nov 7, 2022 at 9:50 AM
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    Correct. I even called Amp and they would only say "next year". That's a lot of range. I just ordered the Go Rhino powered running boards. Supposed to ship 12/16.
