Power mirror switch illumination
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Mar 21, 2019.
  1. Mar 21, 2019 at 9:05 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Just wanted to throw this out there for the tundras.com people. I hate that my mirror switch isn't lit. In the past I installed and LED bolt light just above the switch to light the area. It was too long and too bright and ended up failing after a couple months. I just installed this new bolt light and I like it alot. Its shorter than any bolt light I have seen and only like 6 lumens (I got amber). White would be too bright, blue would have probably looked better but I'm happy with this. Wired to the light blue wire that illuminates with other dash lights at night and it provided just enough glow to see the switch and is short enough it doesn't impede the view of the switch. Here is the item. Highly recommend it. https://www.amazon.com/gp/aw/d/B07N6HCLWT?psc=1&ref=ppx_pop_mob_b_asin_image&th=1
    danz75 and Watt maker like this.
  2. Mar 21, 2019 at 9:18 PM
    Pudge
    CT
    Old, too bright, stuck out too far. Bulb started to flicker and burnt out
    New, not overly bright, doesn't stick out so far I cant see the controls. Better quality.
  3. Mar 21, 2019 at 9:50 PM
  4. Mar 22, 2019 at 2:48 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Good work, 2 wires come off the bolt light, where do they go?
  5. Mar 22, 2019 at 7:08 PM
    Pudge
    CT
    Yeah 2 wires. Black I grounded and the red i tied into a light blue wire on the back of the blind spot switch , its the wire that makes it illuminate when the headlights turn on. I think every switch that illuminates will have this same blue wire.
  6. Mar 22, 2019 at 8:10 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Thx Sean, that’s a nice subtle/functional upgrade.
    Pudge[OP] likes this.
