Power Inverter in Bed of truck
Discussion in 'Electrical' started by digdug, May 15, 2022.
  1. May 15, 2022 at 7:31 PM
    digdug
    digdug [OP] New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
    I have a 800 watt invertor I want to mount inside my cap in the bed of my truck. I was going to run a feed from the front and need to know what size wire would work best. Thanks
  2. May 15, 2022 at 7:47 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I like to use this chart
    This would suggest you should use 4 gauge wire (I'm assuming you are near or about 20ft). I used 1/0 ga for a 3000W inverter and a set of bus bars for other accessories in my bed.
    Wallygator likes this.
  3. May 16, 2022 at 4:56 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    800w at 12v is about 70A max load. I would assume close to 80A with voltage fluctuation.
    The chart above is a good reference based on length of power wire between the battery and inverter. I would agree 4ga looks like a good option.
    I strongly strongly recommend you put a 100A fuse within the first 1ft of power wire near the battery. If not all of your power circuit down the length of the truck will not be protected.
    I work as an accident investigator and one of my cases, an 18 wheeler had a 6ft power wire to an inverter with no fuse. It shorted out under the cab, caught the truck on fire and the driver didn’t survive due to smoke inhalation.
    Put a fuse on it!
  4. May 16, 2022 at 6:15 AM
    Retired...finally
    Is that 800 watts AC?
  5. May 16, 2022 at 6:30 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Hell yeah...
    Loves me some 0 ga and a 100 amp fuse..
    0e33q5g2_zpssm0sqsag_4e5c61a8d163349fbefdd407c1a9c2fd2fad5986.jpg o0tt5klg_7c3a503bb2fe582082d582eb48d67d597806cb0d.jpg
    Wallygator, Vizsla and Jeff_5_7 like this.
  6. May 16, 2022 at 6:56 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Its 800 Watts, AC or DC. Watt is a measure of power, energy consumed over time.
    DC generally 12V
    AC generally 120V but with alternating current
    Power (Watts) = Voltage * Current (Amps)
    800W DC is lower voltage (12V) but higher Amperage (66A) 12 V *66 A= 800 W
    800W AC is high voltage (120V) but lower Amperage (6.6A) 120 V * 6.6A = 800 W
    Its really just a big conversion becasue most household items, phone chargers, lamp, coffer pots, are made for 120V input.
  7. May 16, 2022 at 6:59 AM
    Vizsla
    Vizsla 2 = 2.5
    usedtobenice, Wallygator and des2mtn like this.
  8. May 16, 2022 at 7:04 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Back when @1lowlife had his X2 :boink:
    and that’s some mighty tidy wiring you have in your engine bay there :thumbsup:
    1lowlife[QUOTED] likes this.
  9. May 16, 2022 at 7:21 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Sh!t, that is back when I had my truck.
    We're on day 180 of waiting on cat parts..:eek2:
    Toyota is also replacing the battery, but I told them I wanted my Interstate back.
    I'm thinking I got a lemon on that X2.
    But Batteries + can bite me, they didn't keep their promise to replace it without testing it for 3 days
    Mater[QUOTED] likes this.
  10. Dec 29, 2023 at 10:14 AM
    TRD_Ghost
    TRD_Ghost New Member
    17 Superwhite TRD Pro
    Loving this config.
  11. Jan 9, 2024 at 1:40 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Are you planning on running the negative wire to the battery? Or just running a shorter run to the chassis somewhere?
