Power Cord in glove box.
Discussion in '3rd Gen Tundras (2022+)' started by Hella Krusty, Jan 26, 2023.
  1. Jan 26, 2023 at 11:18 AM
    Hella Krusty
    Hella Krusty [OP] New Member
    Did anyone get a 120V plug in cord? Plugs into a spot on the grille. I cannot figure out what the hell this is for. 2022 Hybrid
  2. Jan 26, 2023 at 11:29 AM
    Lator21
    Lator21 New Member
    2022 Tundr TRD OFFROAD LIMITED
    Leveling kit and tires
    Is it not your block heater cord?
    Yaboy likes this.
  3. Jan 26, 2023 at 12:18 PM
    Hella Krusty
    You are correct. I sent a picture to the salesman. Apparently these are standard for Alberta trucks....BC not so much
    Yaboy and ryanwgregg like this.
  4. Jan 26, 2023 at 1:39 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Not standard in my Alberta truck. I think it's the premium cabin heater package. My SR5 TRD Off Road didn't come with it. Maybe the Limited and up do?
    ryanwgregg likes this.
  5. Jan 26, 2023 at 2:56 PM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    It's for the block heater. My truck has it as does my wife's Toyota SUV.
  6. Jan 26, 2023 at 2:57 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Block heaters are standard in Alberta and required by Toyota. If you didn't get one or a cord you better complain!
    Yaboy likes this.
  7. Jan 26, 2023 at 3:00 PM
    Outbound
    Aaron
    Northern Alberta
    There's the block heater which is standard (I have it), then there's the trickle charger/cabin heater/block heater accessory package which is an add-on.
    Toyota calls it the Comfort+ Heating System.
    https://www.toyota.ca/toyota/en/connect/4354/toyota-heating-accessories
  8. Jan 26, 2023 at 3:16 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Look at you’re bill it will be on there, block heater $500
  9. Jan 26, 2023 at 3:27 PM
    mountainpete
    I think it uses the same block heater cable and connector to power Comfort+.
    For those in the south who have no concept of Comfort+, watch this:
