Powdercoat the lug nuts?
Discussion in 'Wheels & Tires' started by oul, Jan 14, 2017.
  1. Jan 14, 2017 at 4:45 PM
    oul
    oul [OP] Old New Member
    Larry
    Huntington Beach, CA
    2017 Tundra White SR5 TRD Off Road CM
    I'm taking my wheels to the powder coat guy on Monday morning and am thinking of getting the lug nuts done to match the wheel color. Anyone done this? Any problems?
  2. Jan 14, 2017 at 5:48 PM
    oul
    Larry
    Or opinions.
  3. Jan 14, 2017 at 5:53 PM
    Lowcountrytj
    Lowcountrytj Buford T. Justice
    Phillip
    SE GA
    2008 Tundra DC, SC
    Larry I don't think it's worth getting coated unless it's free.
    I imagine it will bust off as soon as the impact/torque wrench tightens them down.
    What color are you getting wheels done in?
  4. Jan 14, 2017 at 5:54 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I agree with Phillip, torque wrench will strip the coating off.
    oul [OP] and Lowcountrytj like this.
  5. Jan 14, 2017 at 6:02 PM
    oul
    Larry
    Thanks for the input. I found out that the TRD Package wheels are the same as the TRD Pro have the black removed from the out side edge. I like the Pro wheels but I'm doing a different color a bit lighter. It's called Titanium Silver but looks like a dark grey. I just wanted it to be a little different
  6. Jan 14, 2017 at 6:04 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I bought Gorilla black lugs on Amazon for like 50 bucks and still holding strong after several tire rotations. Even cheaper if you don't want wheel locks
  7. Jan 14, 2017 at 6:06 PM
    Lowcountrytj
    Phillip
    SE GA
    2008 Tundra DC, SC
    Me personally I would find a finger polish paint or something you would prefer that is close to your finish and once installed paint them. Then hang onto it for touch ups for later?
    scurdyness likes this.
  8. Jan 14, 2017 at 6:11 PM
    oul
    Larry
    Do you have a link as I'm not finding them?
  9. Jan 14, 2017 at 6:15 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  10. Jan 14, 2017 at 6:24 PM
    oul
    Larry
  11. Jan 14, 2017 at 6:33 PM
    1UPPER
    1UPPER New Member
    TEXAS
    I have black powder coated lug nuts. The manufacturer recommends you tighten them by hand and not use an impact. Powder coat if done right is just as strong if not stronger than paint. Just my .02
    scurdyness and oul [OP] like this.
  12. Jan 14, 2017 at 6:34 PM
    Lowcountrytj
    Phillip
    SE GA
    2008 Tundra DC, SC
    oul [OP] likes this.
  13. Jan 14, 2017 at 6:38 PM
    oul
    Larry
    Thats what I'm thinking. I'll talk to the powder coat guy. Maybe no impact guns. Thanks.
  14. Jan 14, 2017 at 6:38 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I wouldn't have the patience to hand tighten and loosen lol
    TheBeast and oul [OP] like this.
  15. Jan 14, 2017 at 6:46 PM
    1UPPER
    1UPPER New Member
    TEXAS
    Anytime I take one of my vehicles in to get tires rotated I make sure they start the lugs by hand first. Otherwise they often cross thread the studs. What color of powder coat are you thinking of using on the lugs?
    joonbug and oul [OP] like this.
  16. Jan 14, 2017 at 7:10 PM
    mtnbiker1978
    mtnbiker1978 Dr. Kenneth Noisewater
    OR
    2017 Inferno Tundra SR5 TRD Off-road Crewmax
  17. Jan 14, 2017 at 7:18 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah that is weird.. I think all 07+ use M14 x 1.5 so this should work
  18. Jan 14, 2017 at 7:21 PM
    mtnbiker1978
    OR
    That's what I thought too.
  19. Jan 14, 2017 at 8:09 PM
    oul
    Larry
    Same as the wheels, it's called titanium silver. Kind of a dark metallic grey. Hopefully it will have the look that I want. I found a Dupli-color wheel paint that matches very close that I'll use on the cap.
  20. Jan 18, 2017 at 6:23 PM
    oul
    Larry
    I got the wheels back yesterday and got them mounted. I talked to the powder coat guy and he said that he hasn't had any problems with doing the lug nut because they really sand blast the nuts heavily and the coating sticks fine. We will see. Here is mine although they look darker than this as the flash went off.
    Lowcountrytj and louscrw like this.
  21. Jan 18, 2017 at 6:25 PM
    oul
    Larry
    I'm getting the 5100's put on and a alignment tomorrow. When the sun comes out again I'll post picks of the whole truck.
  22. Jan 19, 2017 at 5:51 AM
    oul
    Larry
    It appears that this is the largest size and I think the Tundra lug nut is 22 mm? I think I would need 27-22?
  23. Jan 19, 2017 at 6:07 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2021 Ram 1500 Limited 4WD
    Those turned out great! Nice color choice
  24. Jan 19, 2017 at 6:31 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Screw you... seriously... screw you. That picture just cost me a set of wheels, tires and powder coating. That looks freakin' awesome against the white. And we know that all the cool kids drive white trucks.
  25. Jan 19, 2017 at 6:46 AM
    Martin Rolka
    Martin Rolka New Member
    Martin
    2014 Tundra Crewmax Limited
    those wheels look great!
  26. Jan 19, 2017 at 6:47 AM
    Martin Rolka
    Martin
    now do I want to do that or buy the FN's
  27. Jan 19, 2017 at 7:42 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    If the powder coater is good it should hold up just fine,besides you should never impact your lug nuts!
  28. Jan 19, 2017 at 8:10 AM
    oul
    Larry
    I'm really happy the way they look. I'm a old guy that wanted to keep the original geometry on this truck with a bit larger tire. I've had the big tires and wheels. Yea, cool old kids drive white trucks. ;-)
    tomsinamerica likes this.
