Potentially snapped Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Jun 21, 2021.
  1. Jun 21, 2021 at 1:32 PM
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
    At 65mph in the HOV lane going through LA, the last thing I wanted was a snapped timing belt. But that may have been what I got.
    Heard a quick pop sound from the engine and no gas could be given after that. Luckily, I was able to coast off the hwy and get towed to a shop my friend recommended. I'm still waiting to hear back what exactly it was, but I'm expecting the worst.
    If it is the timing belt, any idea what this will look like in terms of damage/repair? I know it can ruin the engine and a replacement may be the only answer. At this point, again, I'm expecting the worse and want to get ahead of planning for it. How much should a "new" engine cost plus labor?
    218K miles
    Potential timing belt snapped at 65mph
    Thank you!
    Bigstick likes this.
  2. Jun 21, 2021 at 1:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    IF the belt snapped at that speed your looking at severe valve damage and piston damage. Be looking into an new engine. Do you know when the belt was last replaced? If it was recently I’d be talking to the company that made the belt. Engine replacement at a shop will run 3-6k depending on mileage labor rate, location, etc.
    A reman engine will be a fair bit more
    KKJC2654 and thefish712[OP] like this.
  3. Jun 21, 2021 at 1:48 PM
    thefish712
    Fish
    Oof, yeah, that will suck. I am not sure when the belt was last replaced. There is no sticker on the engine like there usually would be. At 3-6k, is it worth it to fix in your guy's opinions?
  4. Jun 21, 2021 at 2:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Personally, I'd replace the engine with reman'd if you ever plan on selling this truck sometime in the future. Even if it's just a tiny fraction of uncertainty. I'd replace with a reman'd engine.
    Now, if you're going to keep the truck... this is a perfect opportunity to have some fun. See the meme above.
    Glad you're safe!
  5. Jun 21, 2021 at 2:14 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sounds like you either need a used or rebuilt engine you can buy. How many miles did you add from ownership?
  6. Jun 21, 2021 at 2:17 PM
    thefish712
    Fish
    Only 9k
  7. Jun 21, 2021 at 2:20 PM
    Jack McCarthy
    Bill
    North of Boston
    Wow, that really sucks. Sorry to hear. You could probably use the Toyota site to check if the first change of the timing belt was done at the dealer. Hard to believe the original owner would let it go that long.
  8. Jun 21, 2021 at 2:21 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You can pull back the timing cover and check the belt in around 90 seconds. You need to do that first before anyone can give advice.
    bfunke, Fragman, Sampson and 4 others like this.
  9. Jun 21, 2021 at 2:23 PM
    thefish712
    Fish
    Yeah, I'm still waiting to hear back from the shop I had to leave it at. It's all just guesses until then. Would sure be nice if it wasn't the timing belt.
  10. Jun 21, 2021 at 2:26 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ll cross my fingers for you. There’s been a few people I’ve read about that broke a timing belt without engine damage. I don’t understand how, LOL, but that’s what I’ve read. So I’m gonna hope for the best for you.
  11. Jun 21, 2021 at 2:43 PM
    thefish712
    Fish
  12. Jun 21, 2021 at 3:03 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I’d rebuild the engine on my time, and go with a known-good jy engine in the meantime. But i could swap myself. And id change parts. I also wouldnt be scared of a 4.8/4l60 swap.
  13. Jun 21, 2021 at 3:26 PM
    empty_lord
    05 rollover special
    Depends on the condition of the truck overall. If it’s a clean one, you sure as hell won’t find a replacement for 6k. A new truck would be double that.
  14. Jun 21, 2021 at 4:19 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I’ve read a few times of others that the belt has snapped. One was even supercharged going 45-50mph. All were able to put a new belt on and no damage was done. I hope to hear good news when your mechanic calls, good luck!
    Sampson, thefish712[OP] and 15whtrd like this.
  15. Jun 21, 2021 at 5:17 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Same here, so it is possible that you won’t have any damage if your belt snapped. Hopefully is not the belt and you’re able to get it back in shape!
    Sampson and thefish712[OP] like this.
  16. Jun 21, 2021 at 6:22 PM
    thefish712
    Fish
    The truck is in great condition otherwise and looks incredible. I bought it for $9k and a Toyota shop told me that was a steal for the condition it was in. I would much rather fix her up.
  17. Jun 22, 2021 at 2:29 PM
    thefish712
    Fish
    Timing belt totally broke. Sounds like the '05 Tundra 4.7 is a non-interference engine which means that I'm probably SOL. Does that sound right? Just want to prep myself.
    The mechanic will know more about the condition of the engine tomorrow.
  18. Jun 22, 2021 at 2:32 PM
    thefish712
    Fish
    Actually, the more I read, the more it sounds conflicted. Mine is a 4.7 V8 engine. Any ideas?
  19. Jun 22, 2021 at 2:35 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  20. Jun 22, 2021 at 2:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think you have that backwards. Non-interference means it wouldn't hurt anything. I've always read these trucks have interference engines. Several people have reported the belt breaking and it not causing damage though. You won't know until the shop checks further. Do you trust the shop?
    More info in these treads.
    https://www.tundras.com/threads/timing-belt-break-2006-tundra-4-7.19966/
    https://www.tundras.com/threads/2004-toyota-v8-timing-belt-breaks-at-65mph.56717/
  21. Jun 22, 2021 at 2:55 PM
    2mchfun
    Your mechanic might be able to just rebuild the engine you have. All is not lost just because of some bent or broken rods, wasted valves, and pistons. Cylinder sleeves is a way to fix up the block damages.
  22. Jun 22, 2021 at 2:59 PM
    empty_lord
    05 rollover special
    Well the issue with bent valves is the damage to the head usually requiring new heads. Pistons suffer too. Bore should not unless a valve completely broke
    Darkness likes this.
  23. Jun 22, 2021 at 3:04 PM
    2mchfun
    Precisely why I said MIGHT be able
    empty_lord[QUOTED] likes this.
  24. Jun 22, 2021 at 4:40 PM
    Professional Hand Model
    Hand Protectors
    Sorry to hear this news.
  25. Jun 22, 2021 at 4:47 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  26. Jun 22, 2021 at 4:58 PM
    Any records to indicate the age of the timing belt?
  27. Jun 22, 2021 at 6:01 PM
    SouthPaw
    2000 Limited 4x4 AC
    If it did bend valves, I’d be looking for a yunk yard motor. They can be had pretty cheap and you can freshen everything up before you stab it in.
  28. Jun 22, 2021 at 6:31 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Wish you the best of luck with this. I have seen a few people on here report losing their timing belt and getting away with no damage but I would prepare yourself.
    2mchfun likes this.
  29. Jun 22, 2021 at 6:48 PM
    terrward
    terrward New Member
    2004 DC SR5
    I had a old Honda prelude that the timing belt let go at ~ 60mph, 6 bent valves and one damaged piston.
    I would suspect OP would have a few bent valves at that speed. If it broke during idle then there would have been a better chance at no damage.
  30. Jun 22, 2021 at 8:14 PM
    thefish712
    Fish
    Well, hoping for the best. My buddy was telling me to check out junk yards as well. Sounds like there are so many vehicles with this engine (both the aluminum and plastic(?) insides,,, excuse my ignorance), that he's even seen several under $1,000
