Post Your Weights - GVWR
Discussion in 'Towing & Hauling' started by knoxville36, Jan 22, 2021.
  1. Jan 22, 2021 at 11:27 AM
    knoxville36
    knoxville36 [OP] New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Your truck weights that is...... Thought this would be fun. If ever a slow day or rained out I may weigh some more stuff. The company was here to calibrate the scales out back at work. Multiple zones on the scale they calibrate, guaranteed to be within 20 pounds from 4,000 pounds to 120,000 pounds. So here is what we weighted with me sitting in the truck:
    1. 2019 Toyota Tundra Platinum - Line=X Premium Bed Liner, Factory Running Boards, soft tonneau cover, Toyota rubber bed mat. Full tank of gas.
    Weight = 6,440 pounds stock
    GVWR = 7,200 pounds
    Total Payload= 760 pounds (1,160 on sticker on door)
    2. 2020 Chevy 2500 HD, 6.6 GAS - Undercover Ultaflex bed cover, Chevy spray-in liner, Chevy OEM tube steps, full tank gas.
    Weight = 7,520 pounds stock
    GVWR = 10,650 pounds
    Total Payload = 3,130 pounds (3,465 on sticker on door)
    3. 2018 caterpillar 239 Skid Steer with 72" bucket - Smallest skid steer we have
    Weight = 7,980 pounds (Cat listed as 7,298 before bucket, operator)
    Please post up if anyone else has weighed your Tundra or any other vehicles you have owned.
    omgboost and Cpl_Punishment like this.
  2. Jan 22, 2021 at 7:00 PM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    2018 4WD Platinum. Full fuel tank. Sticker says 1185 lbs.
    Added Equipment:
    1. Spray in bedliner ~ 40 lbs
    2. TRD Rear Sway Bar - 30 lbs
    3. Tyger Trifold Tonneau - 30 lbs
    4. Tyger Starsteps - 120 lbs
    5. Me, wife and two Small Dogs - 400 lbs (mostly me)
    Total: ~620lbs
    Scale = 6,540 lbs. Leaves me with 660lbs for cargo or payload. So, at 1280 total cargo, I'm actually getting almost 100 lbs more than the sticker says I should. Of course that's just the sticker, which is pretty much the manufacturer's guess for payload. It is not calculated in any real test, the way J2807 does for maximum towing capacity. Now gross axle weight rating (GAWR)and maximum tire payload, that is some real s**t.
    So while I get all my setups weighed, when it comes to a truck's payload, "the sticker is more what you call guidelines than actual rules."
    Terndrerrr and knoxville36[OP] like this.
  3. Jan 22, 2021 at 7:06 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    6600 on the dot at the dump scale today.
    Suspension
    Wheels/tire
    Myself, wife, 17 month old, 3 month old
    Sliders
    Spare tire carrier
    40% tank of gas
    Heaviest things to note
    szabo101 and knoxville36[OP] like this.
  4. Jan 22, 2021 at 8:47 PM
    knoxville36
    Knoxville, TN
    Pretty close to my Tundra! Good info!
    szabo101[QUOTED] likes this.
  5. Jan 28, 2021 at 5:20 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Wow, I've barely even started modding my tundra and seems like everything will add weight. 40 pounds for Line-X, really? Won't run a bed mat that's for sure.
    Tundra owners flowchart:
    - Am I still under the door jamb weight?
    No:
    - Am I still under GVWR?
    No:
    - Am I still under GAWR? I'm GTG! :rolleyes:
    Terndrerrr likes this.
  6. Jan 28, 2021 at 5:54 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Weight = 4910 pounds stock... approximately 5250 pounds with me in the truck, Line-X, bed mat, and UnderCover Classic bed cover leaving me 1350 in payload capacity.
    GVWR = 6600
    Payload = 1690
    Toolaholic likes this.
  7. Jan 28, 2021 at 6:27 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Hmm... that weight seems a bit high. Does that include any passengers? I have way more mods on my truck and it is lighter than yours. If yours is a 4x4, I could see it weighing more.
    Anyway...
    2016, CM, 2wd, full tank of gas, and a bunch of other stuff.
    Weight = 5950
    GVWR = 7000
    Payload = 1050 (door sticker says 1201)
  8. Jan 28, 2021 at 7:17 AM
    knoxville36
    Knoxville, TN
    When I got my Line-X premium they said it would be between 60-70 pounds is what they told me. I did have a bed mat also, and it is heavy! My guess is a good solid 60-75 pounds. Between the bedliner and nat, it is probably a good 120 pounds of payload you eat up.
  9. Jan 28, 2021 at 7:18 AM
    knoxville36
    Knoxville, TN
    Nope, only mods are the ones listed, me only in it, full tank of gas. It is 4x4. Only 760 of payload is dead accurate for my Platinum. Weighed it several times.
  10. Jan 28, 2021 at 7:20 AM
    Netmonkey
    Georgetown, TX
    what is the weight without passengers?
  11. Jan 28, 2021 at 7:22 AM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    2020 f250 gasser 4x4:
    GVWR-10,000lbs
    Weight- 6,701lbs
    Payload- 3,299lbs
  12. Jan 28, 2021 at 7:27 AM
    knoxville36
    Knoxville, TN
    6,440 is with only me in it.
    6,180 without me in it.
  13. Jan 28, 2021 at 7:39 AM
    knoxville36
    Knoxville, TN
    What cab and bed configuration?
  14. Jan 28, 2021 at 7:42 AM
    aggie_tundra
    2021 2500 Custom
    Crew cab, 6.75’ bed length, 6.2 engine
  15. Jan 28, 2021 at 8:22 AM
    Toolaholic
    Toolaholic New Member
    David
    2021 black tundra SR5 SX 4x4
    TRD rear sway bar
    My registration says 5360. 7200 gvw. Never weighed it. Sr5 SX
  16. Jan 28, 2021 at 8:42 AM
    Netmonkey
    Georgetown, TX
    that sounds reasonable :)
  17. Jan 28, 2021 at 8:55 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    My door sticker says 1270 lbs. Goodyear added a sticker that says mounting my Duratracs reduced my payload by 53 lbs.
    I’m sure if I loaded up my family, dog, kids’ carseats, a full tank of gas, and all our camping gear, we will have eaten up 600-700 lbs of the door jamb rating.
    When we take our next camping trip in the Spring, I’ll find some scales and get weighed.
  18. Jan 28, 2021 at 9:26 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    My DC 4x4 with running boards, sub, and decked system full of shit is about 6300-6400lbs with a full fuel tank and me.
  19. Jan 28, 2021 at 12:39 PM
    knoxville36
    Knoxville, TN
    Cat scales does a pretty good job at making it pretty easy. For example at Pilot as they all have Cat Certified Scales. I believe they also have a mobile app that you can use with payment information on the scale and you never have to get out and go into the store to get your weigh ticket.
    Terndrerrr[QUOTED] likes this.
  20. Jan 28, 2021 at 2:42 PM
    Well...I may have to sneak over to our scales after 4:30 pm tonight....
  21. Jan 28, 2021 at 6:27 PM
    This is a great thread. I was curious since adding the B&W Gooseneck hitch and all my winter gear under the rear seat.
    B2B24EB6-FAF6-4FD0-8399-AEB25D3E659F.jpg B00A3325-F368-4BB6-8267-02816DA7A2DF.jpg 1150A8F7-E412-49E9-B115-28781DF52A2D.jpg
    Cpl_Punishment likes this.
  22. Jan 28, 2021 at 6:42 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    6,100 lbs. 2019 SR DC, 4x4 with bed mat, running boards, 275/70R18 Falken Wildpeak and TRD Pro wheels just me and 1/2 tank of gas. GVWR is 7100 lobs leaving 1,000 LB payload.
  23. Jan 28, 2021 at 7:21 PM
    Funny how the weight just adds up so fast!
    Front axle is rated at 5600 lbs, so 960 left on that.
    Rear axle is rated at 7050 lbs, 3830 lbs for pin weight.
    GCWR is 11500 lbs. Truck weighs in at 7900 (kinda, I have some things in the bed and plenty in the cab). Hold the brakes.....that only leaves me with 3600 lbs.
    So if I want to be legal, I cannot go over 3600 lbs even though my pin weight is 3830 lbs left. When I'm pulling this and two guys...getting pretty close to maxing the 3500 out. I might have to crawl over a scale with this kind of load on it.
    This is exactly why I skipped over a 3/4 ton.
  24. Jan 28, 2021 at 7:49 PM
    knoxville36
    Knoxville, TN
    That is awesome and good information. I like seeing different setups!
  25. Jan 28, 2021 at 7:53 PM
    knoxville36
    Knoxville, TN
    We have a handful of 1500 to 3500 Denali trucks at work. Also several F150 to F750. If we get a bad weather day and some are sitting around, I will try to weight them for the hell of it. I am curious to see what the 1500 Denali truely weighs in at. Also have a couple newer F-150 with 3.5 eco and one 5.0. Curious to see what they way and true payload for the hell of it.......
    We also just got a new 2021 Yukon Denali and something tells me it has pretty high payload but never looked at it. Rode in it going to lunch for the first time. Nicest SUV I have ever been in and is a rocket with the 6.2!
  26. Jan 29, 2021 at 6:09 AM
    aggie_tundra
    2021 2500 Custom
    Is that a short bed 3500?
  27. Jan 29, 2021 at 6:16 AM
    Yes
    aggie_tundra[QUOTED] likes this.
  28. Jan 29, 2021 at 10:51 AM
    aggie_tundra
    2021 2500 Custom
    I never knew that was even possible until recently.
  29. Jan 29, 2021 at 11:06 AM
    Short beds are more popular and can be a pain to find. Long lox...easy.
  30. Jan 29, 2021 at 12:31 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Probably because you can't get duallies with a standard box and everyone needs those. You always need as much truck as possible to prove you're a real man.SwAHNJE.jpg
