Post Bakflip mx4 installation
Discussion in '3rd Gen Tundras (2022+)' started by Lunar * Rock, Dec 2, 2023.
  1. Dec 7, 2023 at 1:18 PM
    Lunar * Rock
    Lunar * Rock [OP] New Member
    I went out and tightened again and it still
    Won’t go flush.
    the right side seems to sit a bit lower than the left side. How can I adjust it? The rails have set holes in them
  2. Dec 8, 2023 at 5:50 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Any suggestions for weatherstripping that sticks to spray on liners effectively?
  3. Dec 8, 2023 at 6:05 PM
    Lunar * Rock
    I was told to stick it to the cover instead of the bed
  4. Dec 9, 2023 at 7:53 AM
    e263rd
    e263rd New Member
  5. Dec 13, 2023 at 9:23 AM
    dano9258
    dano9258 New Member
    2024 Limited 4x4 OR Pkg
    MX4 Cover
    Did you ever figure this out? Just installed mine and have big gaps on both sides as well. I saw that one member didn’t install the weatherstripping across the front and lets the rubber lay on the bed top? I have the spray in liner so I won’t if the weather stripping is needed?
  6. Dec 13, 2023 at 10:40 AM
    Lunar * Rock
    Never figured it out but maybe I need a smaller weather strip then
  7. Dec 13, 2023 at 11:50 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    You are aware it a plastic composite bed? You really have bed spray, like Line-X, on the plastic bed? Yes, the weather strip is needed. The rubber lip flap across the front will compress into the weather stripping.
