Possible Issues with ICON suspension
Discussion in 'Suspension' started by SoCalTundy, Feb 25, 2019.
  1. Feb 25, 2019 at 8:54 AM
    SoCalTundy
    SoCalTundy [OP] Member since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    So I originally had a spacer lift that resulted in squeaking oem shocks after 15k miles. Last December I decided to swap my stock suspension with an ICON stage 2 and TC arms. Everything was great up until two weeks ago when my rear started to squeak. Rear shocks and leafs are ICON. I can’t figure out where the heck the noise is coming from, but I did notice my leafs are all over the place. Is this normal? It’s only been two months with this setup5E0F4761-5F14-4BE5-877E-DBE697721429.jpg
  2. Feb 25, 2019 at 8:58 AM
    Sunnier
    Sunny
    San Diego, CA
    Do you know, were these put on so the sides of the leafs didn't line up, and tightened that way? If not, it looks like they're loose?
    We're those spacer shim round things part of the pack or added? ("anti friction pads". Thanks, @YZTundy)
  3. Feb 25, 2019 at 8:58 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    SoCalTundy[OP] and Sunnier like this.
  4. Feb 25, 2019 at 9:00 AM
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    Usually its the anti friction pads, I would try to put grease on all the pads and see if that helps.
  5. Feb 25, 2019 at 9:06 AM
    SoCalTundy
    The round things I believe were part of the pack. I also think they’re loose, but I don’t know enough to say if that’s normal or not.
  6. Feb 25, 2019 at 9:07 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The shackle looks twisted on the right side frame mount. Almost as if the bushing is popped out too. Something isn’t lined up correctly on the leaf pack. Most likely it’s not seated properly on the axle. I suggest you take the entire leaf spring off and ensure that everything is lined up correctly when tightening back down.
  7. Feb 25, 2019 at 9:07 AM
    SoCalTundy
    After two months? I have not gone off roading with this setup yet, although we have had a lot of rain here lately.
  8. Feb 25, 2019 at 9:10 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, I'm just learning but this weekend watched a suspension install and saw the leafs kinda fanned out a bit when attached, then needed to be smacked from the side so each side lined up in a neat stack. Then tightened together.
  9. Feb 25, 2019 at 9:11 AM
    SoCalTundy
    Good catch I did not notice that. I’ll have to take a closer look
    Danman34[QUOTED] likes this.
  10. Feb 25, 2019 at 9:11 AM
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    @JRODinSoCal I would take it back to the shop who installed it. Which one was it?
  11. Feb 25, 2019 at 9:13 AM
    SoCalTundy
    It was SoCal supertrucks in San Bernardino. I do have an appointment Saturday for a re-torque on the suspension but I want to make sure I’m well educated by you guys on this stuff so I can bring it up.
    Sunnier likes this.
  12. Feb 25, 2019 at 9:17 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Good luck with the shop.
    SoCalTundy[OP] likes this.
  13. Feb 25, 2019 at 9:21 AM
    YZTundy
    YZTundy New Member
    Denver, Co
    It wouldn't be uncommon, the anti friction pad is made out of a hard plastic that is resting on the leafs that can cause a squeak. Not saying that the pads are bad or worn out might just need a little lube.
  14. Feb 25, 2019 at 9:34 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Here's a pic of my Icon RXT leafpack. (Ignore the Red Circles.) They do shift from side to side. As for the squeeking, mine start squeeking after every wheeling trip. I just blast water between the leafs and it goes away.
  15. Feb 25, 2019 at 9:35 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Lithium grease and have SoCal adjust the leaf pack so it's clamped straight. They will squeak from time to time but that's kinda part of it. Flex, dirt, water, salt, all contribute to this not to mention any other chemical on roads.
  16. Feb 25, 2019 at 9:40 AM
    SoCalTundy
    I washed it down over the weekend and the squeak is still there. Yours look straighter than mine. So you’re saying the shifting is normal?
    joonbug[QUOTED] likes this.
  17. Feb 25, 2019 at 10:07 AM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    Mine is like that too. Just one side though.
  18. Feb 25, 2019 at 10:10 AM
    SoCalTundy
    Any squeaking on your side?
  19. Feb 25, 2019 at 10:17 AM
    Agitated1
    Los Angeles
    There was some squeaking on both sides. I pretty much sprayed down both sides with CRC dry moly lube and the squeak is gone. I also went on the trail this past weekend and still no squeak.
  20. Feb 25, 2019 at 10:25 AM
    SoCalTundy
    Right on. I ordered some of that for my control arms last week and it arrived Saturday. I paid 11 and it’s now $9
  21. Feb 25, 2019 at 1:44 PM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    @JRODinSoCal
    I recommend checking the ubolts. It's likely that they are a few pounds short of the torque spec. Which is why most shops offer a retorque after 100-500 miles because of the nature of the material.
    To address the issue crack the ubolts loose a turn or 2 and tap the leafs back into alignment. Then torque the bolts to spec and be sure to check the torque multiple times in a cross pattern to insure that are all torques correctly and your issue should be resolved. Be sure to do one side at a time to avoid the axle housing rotating on you.
    LKTundra, equin, allibubba and 3 others like this.
  22. Feb 25, 2019 at 3:00 PM
    SoCalTundy
    Is this something I'm going to run into on a constant basis, meaning are the leafs going to be moving to the sides? Or will the next adjustment and torque take care of the issue permanently? I didn't have this issue with the stock leafs. Thanks.
  23. Feb 26, 2019 at 7:37 AM
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    A retorque should fix the issue permanently.
  24. Jan 24, 2020 at 4:52 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Let me resurrect this old thread... My pack doesn't taper like this. My leaf that is shipped out of the pack was installed in the spot Icon recommended, but is a little shorter than the one under it, so it looks a bit staggered. Is this the correct way, or should they all get shorter as the go down? I called Icon tech support, they verified it was correct, just doesn't look right to me.
  25. Jan 24, 2020 at 7:56 AM
    SoCalTundy
    Do you have a picture?
  26. Dec 13, 2020 at 2:08 AM
    BenInILM
    BenInILM New Member
    Ben
    Surf City, NC
    2023 Toyota Tundra Platinum (Hybrid)
    OEM BBS Bronze 18" Wheels Rokblokz Mud Flaps
    I've got the same issue after moving to the Add a Leaf for 750# load. Annoying after spending this kind of money for ICON 3.0 for the truck to sounds like a 1970's rusted-out Ford. Ans it is constant. I've tried T-9 and blowing out the areas with a power washer.
  27. Dec 13, 2020 at 6:55 PM
    SoCalTundy
    Check out my post here. It should help.
    https://www.tundras.com/threads/leaf-spring-help.60885/#post-1595808
  28. Apr 27, 2023 at 12:59 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    My RxT pack looks like that too. I installed it as is from stock config. Started squeaking this weekend now too. Was fine for the past 1,500 miles. Had a day in dusty roads then washed it now it squeaks. However that wasn’t an issue with my stock pack.
  29. Apr 27, 2023 at 8:15 PM
    SoCalTundy
    I think that’s just the nature of icons leaf springs. Probably not what you want to hear. I replaced mine with deaver u748 over a year ago and no squeaks. I did have an issue with popping but figured out that one of the rebound clips on the leaf spring was loose and flapping back and forth.
  30. Apr 28, 2023 at 1:03 AM
    Tundra694
    AJ
    yea disappointing for sure. I thought I was upgrading my leaf pack ‍♂️
