Posi-tap connectors
Discussion in 'General Tundra Discussion' started by Tundra234, Feb 19, 2021.
  1. Feb 19, 2021 at 10:14 AM
    Tundra234 [OP] New Member
    I am looking to use posi-tap connectors on the wires in the kick panels (as soon as I figure out which ones to tap) to add puddle lights. What is the size that I need for most wiring on our trucks and is there a kit that contains locks, taps, and twists?
  2. Feb 19, 2021 at 10:16 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I typically use the red/grey ones but have an assortment. I have used several of the blue ones too.
    1lowlife likes this.
  3. Feb 19, 2021 at 10:20 AM
    Yeah I see there are quite a few. Amazon is probably the best place to get them.
  4. Feb 19, 2021 at 10:23 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  5. Feb 19, 2021 at 10:24 AM
    Tundra234[OP] likes this.
  6. Feb 19, 2021 at 10:37 AM
    toyofan87 likes this.
  7. Feb 19, 2021 at 10:48 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Not sure if your 2020 has it, but I tapped into the little footwell light on the driver's side of my 2014 SR5 for my puddle lights.
    Also have my custom footwell lights tapped into that circuit.
    That way it dims on with the unlocking of the door and dims off when it times out.
    Seems my ign key trim ring is also on that circuit..
    Since I simply removed that little LED, I was able to solder my stuff in.
    znycblvn_zps1l4c6wi9_6afc90dc961f8ac99eac2cb9d3227f1a663c41ca.jpg 0rjnegpa_zpscuofg07t_08c12743b110df41f24c2904111610f488fbd5a4.jpg fottwell%204_zpslbuhodom_516763fae38bb39fb3c3c053ca8b2fe1cad3aec2.jpg
    Those VLEDs are awesome..
    f5xhgddq_zpsk85eh7wh_fc32f36bea7ea38e6c41826a1e6d78d0509c5f83.jpg 3gnu04bz_zpsgecrr1ak_2df32e71398228ccec612352af0fe3e8ae6d3a33.jpg
    Those Posi-taps work pretty good.
    Only had one issue with them when installing my Amp steps.
    The door open switch wire in the kickplate (that triggered the step) was so small, it took a little work to get the posi-tap to make a connection..
    I have them in 3 sizes, Amazon was the only place I could find them.
    Parts stores around here don't seem to carry them..
  8. Feb 19, 2021 at 10:53 AM
    Yes I have the footwell light. I have the Vled kit plugged into it. On my 2013 I had them tapped in at the kick panels. It was a shorter and cleaner wiring run. That is the goal on this one too.
    1lowlife[QUOTED] likes this.
  9. Feb 19, 2021 at 11:44 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    They are usually rated by gauge, I've used the blue ones posted above to splice into the kick panel wiring.
