Portable battery booster experience?
Discussion in 'General Tundra Discussion' started by mountainpete, May 10, 2020.
  1. May 10, 2020 at 8:54 PM
    mountainpete
    mountainpete [OP] Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Hi,
    My trusty portable booster pack from well over a decade ago doesn’t hold a charge anymore. It was basically a 20 lb acid battery in a plastic shell but it worked well.
    I’m seeing these new small lithium booster packs. Looks like something I can almost keep in the console.
    Anyone have experience with boosting a frigid 5.7 with one of these small packs? (The ones that attach directly to the battery)
    I’m specifically looking at a Noco 2000 amp off Amazon.
    Wallygator and Ely010606 like this.
  2. May 10, 2020 at 9:00 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  3. May 10, 2020 at 9:06 PM
    mountainpete
  4. May 10, 2020 at 9:14 PM
    Ely010606
    SPARKS, NV
    I have used it once on my stock battery when it died after a year i had my truck, thank goodness i had it at that moment or else i would have had to call AAA. It cranked right away on the first try.
    The second time was someone needed a jump, cranked right away.
    As of any colder than what you stated , no i haven't used it. If its that cold I am staying home, lol.
  5. May 10, 2020 at 9:22 PM
    TheBeast The Beach
  6. May 10, 2020 at 9:33 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  7. May 10, 2020 at 9:38 PM
    mountainpete
    Anyone have super cold weather experience with one of these packs?
    And by cold, I’m thinking a week continuously below -20 C.
  8. May 10, 2020 at 10:50 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    I have a Noco GB150. Used it every day for a week a while back to start my civic to and from work. Had to wait until the weekends to figure the parasitic draw. After 10+ jumps, the GB150 still showed 100% charged.
    During that week, it was the winter. UT early mornings I’d say is slightly probably around -5 C. My charger was sitting in the house.
  9. May 11, 2020 at 4:53 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I have never had decent experience with these tiny jump packs,not once and I have tried several too.
    I have never had a NOCO and they do seem nice but I have had several Battery Tender brand which is also supposed to be a premium brand and I got nothing from them.
    The 20 lb battery in the one that you already have is usually a simple tp replace Alarm Standby Battery and if you find an Alarm Supply House they are pretty cheap too.
    I replace them all the time and also use the same batteries in things that I make but I am also an Alarm guy for a long time so have easy access too.
    Just FYI
    Black Wolf and mountainpete[OP] like this.
  10. May 11, 2020 at 6:08 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Since you're also in Canada, I'll share my experience. My family has had a few different Eliminator brand booster packs from Canadian Tire and some have been better than others. I have a small one and I've never been able to boost any vehicle even when it wasn't cold outside. My dad and brother have bigger ones and have had better experiences with them. I would recommend getting the one with the most cold cranking amps you can find and charging it once a month in the winter.
    jpod, ezdog and mountainpete[OP] like this.
  11. May 11, 2020 at 6:32 AM
    timsp8
    NY
    I have a noco and it’s always worked well. Coldest was probably around 10F and no issues starting the truck. Although I’ve used it more on other people’s vehicles than the tundra.
  12. May 11, 2020 at 6:37 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Cpl_Punishment likes this.
  13. May 11, 2020 at 6:55 AM
    War Machine
    War Machine SSEM # 5 3MW
    I have the smaller GB40. Have jumped off Sequoias, a Tahoe, forklift batteries, and no bullshit - one of our F750 delivery trucks with no problems.
  14. May 11, 2020 at 7:21 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    They are the best. I use them on everything. Lifesaver on boat when I run radio too long.
  15. May 11, 2020 at 7:48 AM
    Cfincke
    San Antonio
  16. May 19, 2020 at 1:06 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
