Popping sound when stationary and turning wheel (video)
Discussion in '2.5 Gen Tundras (2014-2021)' started by cook2kill, Jun 25, 2020.
  1. Jun 25, 2020 at 9:00 PM
    cook2kill
    cook2kill [OP] PNW
    Portland OR
    2018 CM
  2. Jun 25, 2020 at 9:12 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Could be your skid plate rubbing against the frame when it flexes when you turn the wheel.
    Try removing your skid plate and check if it will still make the popping sound without the skid plate.
  3. Jun 25, 2020 at 9:26 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I had this same sound. They tightened up on the lower control arms and the pop when away.
  4. Jun 26, 2020 at 4:32 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Similar issue here - need more info like did you make any changes? A couple things to try. Mine was the skid plate was rubbing on tires - sounded really bad. Yours might be your LCA cam bushings.
    Check clearance on skid plate
    Check/grease wheel stops (this would only be an issue at full wheel lock)
    Check LCA cam bolts for tightness
    2point5seconds likes this.
  5. Jun 26, 2020 at 9:18 PM
    cook2kill
    cook2kill [OP] PNW
    Portland OR
    2018 CM
    Changes from stock?
    kings, tc UCAs, Coachbuilder shock shims & tie rod ends, 35’s, 18 wheels, BMC.
    I don’t think anything’s hitting the skid (stock sport skid). I definitely need to check the LCA bolts. Sounds like it’s coming from the CV or perhaps the tie rod end. Maybe need to degrease the tie rod end if I haven’t screwed it up already. @Coachbuilder1 thoughts?
  6. Jun 26, 2020 at 9:41 PM
    tunamac
    tunamac New Member
    2016 CM 4x4
    When mine made similar sounds it was because the Toyota dealer didn’t tighten my right LCA bolt peppery after an alignment.
  7. Jun 27, 2020 at 8:37 PM
    60driver
    60driver New Member
    Spring Lake, NC
    2016 Tundra CM Platinum Sunset Bronze
    2.5 Toytec Aluma front coilovers JBA UCAs Wheelers Off-road front bumpstops 2.0 Toytec Aluma rear shock OME greasable shackles and bushings OME Dakar Leaf Springs ARE CX Topper with Prinsu Toprac Northstar AGM deep cycle Renogy 100w solar panel with Renogy wanderer controller and BT1 module Yokohama Geolandar X-AT 35x12.5R17 Black Rhino Stadium 17x8.5 +10 Offset
    Remove your skid plate and watch the steering rack. If it’s shifting significantly, it’s probably the rack bushings. I had the same issue and noise, my bushings were shot, warped and fatigued. I replaced them with energy suspension’s rack bushing kit and it fixed it.
  8. Jun 28, 2020 at 3:20 PM
    Mhenders1069
    Mhenders1069 New Member
    Mn
    2019 tundra Trd on king suspension
    4.88 Nitro Gears. King coil overs and rears with remote resi and a pedal commander throttle control. AFE cold air intake. RSI Smartcap and GFC supernate 50.
    The sway bar almost looks like it moves and pops? I’ve got Kings and spc uca with a coach builder. I had some weird noises from the sway bar bushings. Pull the sway bar and see if it helps. Plus you’ll allow those Kings to fully engage and cycle.
  9. Dec 22, 2020 at 10:14 AM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    What did you end up doing with the skid plate rub? I've seen people cut their skid plate a few inches to make the clearance.
  10. Dec 22, 2020 at 11:07 AM
    glowblue
    VA
    For a temp fix I bent the little “wing” up to make clearance - but ultimately installed an RCI skid plate since I was already sick and tired of removing the OEM skid plate for oil changes. This gave me enough reason to upgrade the skid plate and glad I did.
  11. Dec 22, 2020 at 11:10 AM
    2point5seconds
    Sensei
    Nor Cal
    Nice. So, the RCI skit was narrow enough to miss the tires? That was my next step, look at third party skid plates to solve that hitting problem.
  12. Dec 22, 2020 at 11:13 AM
    glowblue
    VA
    Yep! Fits great - a lot of folks on here have upgraded. It’s solid and well made, great product.
