Popping Noises - Chassis/Body Bolts?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Aug 3, 2017.
  1. Aug 3, 2017 at 8:02 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I posted in another thread about a metal popping noise I get *after* turning on an incline (I had dealer look into it, but they were unable to reproduce the sound). Now, on top of this sound, I'm hearing subtle pops and clings *while* turning on inclines. Especially if it's bumpy.
    I think these sounds are produced as a result of twisting/flexing of the chassis/frame.
    I noticed the maintenance recommendations in the manual include "Tighten nuts and bolts on chassis and body". The manual describes this as, "Re-tighten the seat-mounting bolts and front/rear suspension member retaining bolts to specified torque".
    Has anyone ever done this or had it done? Anyone have a complete list of where these bolts are located? What are the torque specs? Could I get the dealer to do this work under warranty? (i'm coming up on 36k miles)
  2. Aug 3, 2017 at 8:19 AM
    Are you completely stock?
  3. Aug 3, 2017 at 9:25 AM
    RussellVaughan
    Houston
  4. Aug 3, 2017 at 10:03 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Check the bed bolts. Mine were loose because the knucklehead at line-x didn't tighten them enough. I took them out, added lock tite and it fixed it
    TheBeast, 15whtrd and treihing like this.
  5. Aug 3, 2017 at 10:09 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    ^^^^This.
  6. Aug 3, 2017 at 10:24 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    You dont happen to have a TRD skid plate do you.
  7. Aug 4, 2017 at 8:32 AM
    RussellVaughan
    Houston
    I have the RCI skid plate. Popping noise before and after i installed it. Also made the noise with no skid plate.
    trdlife[QUOTED] likes this.
  8. Aug 4, 2017 at 8:36 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    ok just checking the trd skid is known for the poping you are describing. Do you happen to have a video of the noise you could upload?
    NewImprovedRon likes this.
  9. Aug 4, 2017 at 8:37 AM
    RussellVaughan
    Houston
    Good idea, I'll try to capture the sound
  10. Aug 4, 2017 at 8:38 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Yea post it up id like to hear and maybe help point you in the right direction. any lift on the truck?
  11. Aug 4, 2017 at 12:00 PM
    RussellVaughan
    Houston
    https://youtu.be/H1XCK29lAXE
    my phone didn't pick up the noise very well, so you'll have to turn your volume waaay up most likely. The sound occurs at exactly the 2 second mark.
  12. Aug 5, 2017 at 7:46 AM
    graves037
    graves037 New Member
    Michael
    Pea Ridge AR
    16 Tundra SR5
    3" readylift, trail grapplers on 20" rockstar II's, truxedo lopro, lund bull bar, 20 & 30 in lightbars, tint, LEDs
    Following.....Mine has a light popping noise pulling onto an incline as well, but I thought it sounded like it was coming from the back glass area. I was thinking it was just a structural integrity thing having a roll down back glass, nothing in a fixed position. But I haven't located it nor taken it to the dealership
  13. Aug 7, 2017 at 4:07 AM
    RussellVaughan
    Houston
    Update - the noise appears to occur at the same speed (12-15 mph), and only the first time I reach that speed after turning on the truck. So here goes my new theory - I think it's related to the automatic abs check the truck does, and it's causing the dust shields to pop. Thoughts?
    Edit - Looks like this is an old issue (2001), and I'm just the latest to bring it up...
    https://www.tundras.com/threads/need-advice-major-clunk-sound.2592/page-2
    Edit 2 - the noise apparently is reported to come from the abs actuator itself. one person reports getting toyota to replace it. so my dust shield theory was, in fact, stupid lol.
  14. Aug 7, 2017 at 4:51 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    if that is the noise that you are hearing, then that is completely normal. at ~15mph, the abs system does a check and you hear a little pop. my Tacoma did it and my tundra does it.
    BlueFalconActual likes this.
  15. Aug 7, 2017 at 6:44 AM
    RussellVaughan
    Houston
    not to be argumentative, but i wouldn't call it normal unless all tundras do this. from what i understand and have read, that's not the case. the abs self-test is normal, the loud metal clunk/pop is not IMO.
  16. Aug 7, 2017 at 6:48 AM
    Netmonkey
    Georgetown, TX
    AFAIK, all tundras make the little pop sound during the abs self check. if you are hearing something different than that, then I don't know what it is.
  17. Aug 18, 2017 at 8:18 AM
    Long5152
    Long5152 New Member
    Long
    2017 Crewmax black trd tundra
    New here to the community. Just got a 2017 trd off road cm.
    300 miles on the odo and it has that popping sound. It does it periodically around 10-15mph. I thought something was wrong with it.
    What what you guys are saying that it is normal???
  18. Aug 18, 2017 at 8:22 AM
    Netmonkey
    Georgetown, TX
    every time you first start the truck and then hit 15mph, the ABS system does a check and you hear a little pop sound. however, it should only do that once. if you keep hearing the sound after that, then there could be something wrong.
    I will make a recording of what I am talking about. I will have it posted later today.
    Long5152[QUOTED] likes this.
  19. Aug 18, 2017 at 10:02 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    That little popping sound freaked me out the first couple times I drove my Tundra after purchasing it. But sure enough it does it every time, 1 time, at 15 mph almost on the dot.
  20. Aug 18, 2017 at 10:10 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I have a popping noise at the front, too, but it's related to my driver's side body mount. I've just been too lazy to fix it.
  21. Aug 18, 2017 at 10:15 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Do you guys have your auto door locks turned off? I think the door locks at 15mph too. Probably why I never hear this popping sound you speak of.
    15whtrd likes this.
  22. Aug 18, 2017 at 10:17 AM
    Netmonkey
    Georgetown, TX
    I set my doors to lock when I put it in gear :)
  23. Aug 18, 2017 at 10:22 AM
    Spvrtan
    Kris
    San Diego, CA
    I didn't even know you can turn that off..
  24. Aug 18, 2017 at 11:11 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Can't remember if I saw it on the truck or through techstream, but yeah.
  25. Aug 18, 2017 at 11:36 AM
    TheBeast The Beach
    gotta check those bolts because my bed makes popping/creaking noise too...
  26. Aug 19, 2017 at 1:56 PM
    laniermax
    laniermax New Member
    Jack
    Atlanta
    2014 Tundra Limited 4x4 DC TRD Off-Road, Sunset Bronze
    Retrax Pro, AMP Bed Step, Aries 3D Mats, Thule Roof Rack, Bilstein 5100's, SCS SR8 Wheels, Toyo AT2's.
    I had this same problem with popping sounds from the front of my truck. The sounds were most noticeable when coming in /out of my driveway which is on an incline. I saw a post about problems with the TRD skid plate so decided to drop mine this morning to have a look. Sure enough, I could see where the skid plate was rubbing on the frame cross-member at the back (picture below). With the skid plate off, I took the truck out for a ride and it didn't make a peep. I thought about mounting some washers to provide some clearance at the rear bolts but decided to adhere some small pieces of rubber from an old bicycle tube over the spots that were rubbing. I just used some silicone adhesive to attach the rubber. I mounted the skid plate back up and no noises!! Problem solved - for now.IMG_2908.jpg IMG_2910.jpg
    NewImprovedRon and 15whtrd like this.
  27. Aug 19, 2017 at 3:49 PM
    TheBeast The Beach
    that fixed the issue..they were loose from the line X guys...
  28. Aug 25, 2017 at 8:16 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I installed nylon washers between the PRO shield and the frame. Problem totally solved.
    laniermax and NewImprovedRon like this.
  29. Jul 22, 2018 at 2:20 PM
    Berettafan
    Berettafan New Member
    2017 CM
    thanks for the pics Lanier. pulled mine after creaking and found rubs on the same spots.
  30. Sep 26, 2018 at 11:23 AM
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    There is a Toyota bulletin on this and gives the torque specs. I think we all need to call Toyota Care and get them to fix this once and for all. 800-331-4331
