Need advice..major clunk sound
Discussion in '2.5 Gen Tundras (2014-2021)' started by racin, Sep 12, 2015.
  1. Sep 13, 2015 at 4:07 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    No i have never heard of this concern
    T-Rex266[QUOTED] likes this.
  2. Sep 13, 2015 at 5:06 PM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    20150913_170412.jpg was tempted to level the truck same week I bought it but wanted to keep it stock at least for 6 months just incase anything crazy happens and the dealer want to blame it on my upgrade only aftermarket upgrade I have now is my antenna had to remove that pole outta there..but I can not lie I love this truck guess everything has it flaws in one way or the next such is life
    Jsena likes this.
  3. Sep 13, 2015 at 5:37 PM
    Mr.Green
    Mr.Green New Member
    I'm sure the antenna is interfering with the magnets on the abs check and that's why it clunks. :)
    Jsena, T-Rex266 and racin[OP] like this.
  4. Sep 13, 2015 at 5:53 PM
    2015 LIMITED CREWMAX 4X4
    2015 LIMITED CREWMAX 4X4 New Member
    Glenn
    2015 Tundra Limited TRD 4wd crew max.
    Bed cover, spray in bedliner, tinted windows, black coating on wheels, blacked out grill and all other badges, 2.5" front leveling kit, rear Firestone air bags.
    No noise on my 15. I've been a mechanic for many years and most vehicles will run a self test when the key is turned on. The ABS module will communicate with each wheel sensor to check the circuit. It will also monitor it as you drive as the traction control system uses the ABS system. I've never heard of any vehicle that actually activates the ABS system while driving as a test. Typical dealer answer though that it's normal. That's why I've never worked for a dealer.
    racin[OP], Mr.Green and rons23 like this.
  5. Sep 13, 2015 at 5:54 PM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    lol
  6. Sep 13, 2015 at 5:55 PM
    Glenn
    I got a stubby antenna but the HD radio wouldn't come in very good. Going to return it.
    racin[OP] likes this.
  7. Sep 13, 2015 at 5:55 PM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    seems like the dealer been saying this from 2001
  8. Feb 9, 2016 at 1:21 PM
    pdrhound
    pdrhound New Member
    T
    2015 sr5
    i have a clunk in the front when I'm in 2wd and spin the tires on ice. seems weriod. traction control is no where near as good as it is on the tacoma.....?????
  9. Feb 9, 2016 at 5:43 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    i have a 2000 limited and a 2008 sr5 tundra both 4wd, i have never heard this noise while driving
  10. Feb 9, 2016 at 6:00 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Only noise my truck makes is the doors locking the first time after starting.
  11. Feb 9, 2016 at 6:43 PM
    That's ur traction preventing wheel slip. These guys are just touchier than the Tacomas.
  12. Apr 22, 2016 at 9:51 AM
    Boriqua63
    Boriqua63 New Member
    2014 DB cab limited tundra
    None
    Hello Racin,
    I own a 2014 DB cab limited 4x4 tundra. I just got a call from my services advisor stating that the noise is comimng from my ABS actuator. They are going to replace it. He never stated that it was a normal issue. He even stated that the newer models are having the same problem. I would definitely take it to another service center and have them fix the problem. Hope this helps.
    RussellVaughan likes this.
  13. Apr 22, 2016 at 12:26 PM
    Boriqua63
    None
    Hello RowdyRon. Don't know if your joking or serious about door locks at 15 mph. It is a feature that can be deactivated by going into your settings in the vehicles computer.
  14. Apr 22, 2016 at 3:43 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I had a similar noise. The single occurrence is the ABS module. Mine occurred EVERY time leaving a stop at a lower speed than 15mph.
    After arguing with the dealer and calling Toyota corporate...my transfer case was replaced. Happy to say since then, I have only heard a noise half dozen or so times in the last 10k miles.
  15. Apr 22, 2016 at 3:46 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Some people have also heard a "clunk" that was found to be the ECM bracket rivet or weld that had failed.
  16. Jun 6, 2018 at 5:41 AM
    Marco
    Marco New Member
    Yes it is the ABS.. 100% varified.
    And the wiz sound after shut down is the air system emissions pumping air into cats to purge for next start up. Cleaning...
    Now I have a groin in rear suspension
    When I go over speed bump. Toyota checked every component checked torque of all components..all check good...
  17. Jun 6, 2018 at 7:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My truck has a groin there too. :rofl:
  18. Jun 6, 2018 at 7:52 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Clunk is a very general term. Without video or experiencing it first hand it is hard to say.
    When I start my truck that has been sitting all night/after a day of being at work I feel and hear a “clunk” noise. It almost feels like it is in the gas pedal.
    This does appear to be a common issue and documented by many other members.
    https://www.tundras.com/threads/2018-“clunk”-noise.20749/
  19. Jun 6, 2018 at 8:07 AM
    #49
    Henry Hooker
    Henry Hooker New Member
    I have about 300 miles on my 18. I notice a slight clunk after backing up the driveway, switch to drive and I'd say about 10 or 15 feet I hear a little clunk on the drivers side front. When I go get my plates I'm going to have the guys listen to it and possibly drive another one just to see if the same...
  20. Jun 6, 2018 at 5:31 PM
    #50
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Probably brake pad shift^
  21. Jun 6, 2018 at 6:32 PM
    #51
    Henry Hooker
    Yeah, I was thinking that, but only from one side? Also I tested it today, if I back up and then go forward, no sound. But if I back up and turn wheel to pull into street and then go forward I get the noise. Under 8 mph is when it does it...
  22. Jun 6, 2018 at 8:43 PM
    #52
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    I get the same thing sometimes too but those dumb asses at the dealer blame my nfab light bar.
  23. Jun 8, 2018 at 11:47 AM
    #53
    Henry Hooker
    I tested again today, this time driving straight without backing up or turning wheels, still happens. Did it at 6mph, so I'm guessing abs system like everyone else. I thought it was only happening after reversing and turning wheels.
  24. Jun 8, 2018 at 12:10 PM
    #54
    Mine doesn’t do this. I’m liking @rons23 explanation on his truck.
  25. Jun 8, 2018 at 1:48 PM
    #55
    Henry Hooker
    Dig, except his description was for clunk from rear...
  26. Jun 8, 2018 at 2:15 PM
    #56
    He has a front drive shaft....
