Popping noise in front end at low speeds
Discussion in '1st Gen Tundras (2000-2006)' started by because_wumbo-truck, Mar 13, 2020.
  1. Mar 13, 2020 at 10:50 AM
    because_wumbo-truck
    because_wumbo-truck [OP] TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    So I recently took my truck to an off road park and this popping noise started.
    Let me back up first.
    So my buddy swapped the passenger CV for me with a Napa CV since the OEM boot was MIA. I've seen him swap so many Toyota CVs that I took his word for it when he says I didn't lose enough fluid to bother removing the skid plate to top it off. The driver CV has a torn boot but it's still in ok shape so we didn't swap it out.
    Fast forward to the off-road park.
    My truck slipped out.ifn4hi about 3 or 4 times over the course of 11 miles off road and toward the end of them the front end started making this popping noise. I've determined it only happens at low speeds. So when braking and accelerating.
    Anybody have any ideas? I'm hoping the torn CV boot just let in debris and needs the be swapped for a fresh CV, but I fear the problem may be with my diff. The new Napa CV is already surface rusting, while the OEM CV looks great minus the torn boot.
  2. Mar 13, 2020 at 11:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Does it do it all the time, like going straight? My boot has been torn a while but I dont have any popping, just broken cv noise when in 4wd.
  3. Mar 13, 2020 at 11:25 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    The boot has been torn for a long time. It just started popping 2 weeks ago. It does it when going straight or turning at low speeds. Most prevelant when coming to a stop or turning but does it on acceleration as well.
    I went thru some mud and water and I'm wondering if some shit got into that torn boot
  4. Mar 13, 2020 at 2:54 PM
    Professional Hand Model
    Hand Protectors
    I had torn boots for years and never had clicking or popping. Just had aftermarkets CV’s put on almost 2 years ago and no problems so far (should stayed OEM in retrospect). Shoulda kept the cores, but wasn’t thinking.
    Sounds like you messed something up during your off road event. Driving through mud, water, and banging on rocks can mess stuff up fast.
  5. Mar 13, 2020 at 5:39 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I kept the cores :thumbsup:
  6. Mar 13, 2020 at 6:00 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Check your bushings and ball joints. Could be a dry bushing popping. Or could have a bad ball joint. make sure the cv is seated in the shaft right to that could explain the slipping.
  7. Mar 13, 2020 at 6:34 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Why is it coming out of 4wd?? Would that be an actuator issue or transfer case issue???
  8. Mar 13, 2020 at 6:40 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's what I'm wondering and kinda throwing me for a loop. But I dont think the actuator would cause a popping. Maybe its randomly engaging and causing something to pop?
  9. Mar 13, 2020 at 8:26 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I already greased the upper BJ's. Need to buy a needle to grease the lowers. Maybe I'll fill the torn boot with grease and see if it gets any quieter :notsure:
    Next thing I guess would be to drain and fill front diff and see if there's any carnage in there. But I'd like to wait until I'm ready to install the ECGS bushing. One other thing I'm wondering is whether or not the Napa CV had grease or not. It was assumed that it came greased out of the box.
  10. Mar 13, 2020 at 10:14 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    They come greased.
    Coming out of 4wd is prob unrelated to popping noise
