Popping noise after turning on incline
Discussion in 'Suspension' started by RussellVaughan, Apr 6, 2017.
  1. Apr 6, 2017 at 9:32 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    that makes complete sense to me. But I'm more of a smart ass then just smart sooo.....
    NewImprovedRon and Bear like this.
  2. Apr 6, 2017 at 9:43 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I'd snap a phot of mine, but running a PC lift. Wouldn't quite compare
  3. Apr 6, 2017 at 9:54 AM
    TheBeast The Beach
    tag for outcome
  4. Apr 6, 2017 at 10:03 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    ya I'm pretty interested in what the outcome will be also.
    DVYota likes this.
  5. Apr 6, 2017 at 10:51 AM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    I'm no mechanic... but this is the Internet so we are all "experts" on here lol
  6. Apr 6, 2017 at 12:30 PM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    wow...yeah your tabs are completely 180 to mine. I've got an appt scheduled tomorrow morning with my mechanic. I described the issue over the phone and they told me they have a good idea what it is. I didn't get greedy and ask what their idea is...so suspense until tomorrow morning. I'll post more once I know more. Thanks for the help everyone.
  7. Apr 6, 2017 at 12:40 PM
    DVYota
    South Carolina
    Basically stock
    I have a spacer leveling kit so mine is probably at a different setting because of that. not necessarily anything wrong with where yours is at that I know of. (Not a mechanic so these are mostly guesses) interested in the outcome. Did you look for rubbing on your coilover and swaybar?
  8. Apr 6, 2017 at 12:45 PM
    RussellVaughan
    Houston
    I turned all the way to the left, then all the way to the right, but couldnt' see any potential for rubbing. No rubbing marks either. Bushings on sway bar look good. Boots look good/clean. Haven't raised front end, so couldn't check for movement.
    DVYota[QUOTED] likes this.
  9. Apr 6, 2017 at 1:03 PM
    Bird42
    Bird42 New Member
    Utah
    Pro Comp Wheels, Pro Comp 2.5" level kit, Nitto Grappler G2 Tires.
    i get a very similar popping noise. Found out i have bad lower control arm bushings and one bad lower ball joint. I will be replacing all this weekend. I'll let you know if my popping noise goes away, or if i still have it. If i do still have the noise i will be looking at coils and sway bar next. Food for thought
  10. Apr 6, 2017 at 1:08 PM
    RussellVaughan
    Houston
    good to know. if it turns out i have bad bushings or ball joints, should I expect the factory 3 yr/36k warranty to cover it? i do nothing extreme in this truck...worse it sees is deer lease, and even then i've only needed 4wd once. nothing should be failing at 29k imo
    040Tundra likes this.
  11. Apr 6, 2017 at 1:13 PM
    Bird42
    Bird42 New Member
    Utah
    My guess would be yes a warranty should cover something something as simple as bad bushings or ball joints but that's just my guess with out doing any research. Mostly because your bushings and ball joints should be just fine with such low miles on them.
  12. Apr 6, 2017 at 6:02 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Ran into a guy the other day that had put new shocks up front and was having popping noises. I looked under his truck and saw his alignment cams all bent and one of the cam tabs almost broken off. He took it to a different shop after taking lots of pics and had the original shop cover the tab for all repairs. Truck works great now. Keep us posted.........
    DVYota likes this.
  13. Apr 6, 2017 at 6:36 PM
    15whtrd
    15whtrd Mr. Blonde
    Aren't those bolts post to be tightened to some ridiculous amount of foot pounds? I thought I remember something like 200 LOL
  14. Apr 6, 2017 at 6:45 PM
    CM-LENNY
    San Diego, CA
    That is true, but I actually watched a video once that showed a guy torquing on the fixed adjustment bolt rather than the nut. Jacked up the whole mess........
    209TRDPRO and 15whtrd[QUOTED] like this.
  15. Apr 7, 2017 at 7:10 AM
    RussellVaughan
    Houston
    UPDATE got back from the shop. inspected front end and couldn't find any issues. no play anywhere, and lca bushings were fine. they said cam tabs are fine, chewed up but within normal expectations. alignment machine showed caster was off slightly, right was too low. truck pulled to the right slightly, so we figured let's loosen the cam bolts up, adjust caster, then torque everything up real good. turns out the front bolts were "loose". more than hand tight, but def not to spec. I'll test it this evening in the driveway...keeping my fingers crossed.
    TheBeast, DVYota and NewImprovedRon like this.
  16. Apr 10, 2017 at 6:45 AM
    RussellVaughan
    Houston
    UDPATE Alignment didnt work, truck still pops. Not sure what to do next, other than get the truck up and inspect myself. Have my 30k service coming up...I'll try to do it then. Probably won't find anything, so I'll take it to the dealer to get the issue documented before warranty is up. Thanks for the help everyone.
  17. Apr 12, 2017 at 6:08 PM
    Bird42
    Bird42 New Member
    Utah
    So i replaced both lower control arms a cv axle all 4 ball joints both front bearings and both outer tie rod ends and 1 inner tie rod end. I'm letting you know all this because i have a very similar pop and even after replacing all the parts i just listed, i still have the pop noise. And my truck had a full alignment done on it.
    I read in another forum that Toyota Camry's had a recall on their front struts because of a popping noise they made while turning the vehicle in a parking lot type situation.
    I've narrowed the popping noise down to a few parts from most likely to least likely- Struts, sway bar, upper control arms.
    On a side note i replaced the most critical components in the front end. So even if the noise does persist, at least you know its most likely not a threatening noise.
  18. Apr 12, 2017 at 6:09 PM
    Bird42
    Bird42 New Member
    Utah
    Dannydirtyfingers likes this.
  19. Apr 13, 2017 at 6:44 AM
    #49
    RussellVaughan
    Houston
    thanks for the info, and sorry to hear you still have the noise. it gets on my nerves big time.
    how would you describe your noise? Mine is definitely a pop, but very metallic with a reverberation. there is absolutely NO thud, click, or knocking aspect. sounds like something that was flexed releasing from tension or something.
  20. Apr 13, 2017 at 6:47 AM
    #50
    RussellVaughan
    Houston
    by the way, my truck will be going to the dealer soon for body work. i had a guy right on red right in front of me. then accused me of causing the accident. while it's there, i'm going to document the issue with toyota and hope they can investigate. will update this if i learn more.
  21. Apr 13, 2017 at 7:19 AM
    #51
    RussellVaughan
    Houston
  22. Apr 13, 2017 at 7:21 AM
    #52
    Vizsla
    Vizsla 2 = 2.5
    If your alignment cams still look like the pics, then they are 180 deg. off. This will make it pop for sure, and the bolts are junk, need replaced, lower control arm bushing can also be damaged.
    Should look like this.
    AE941F4C-BAAF-426B-AB99-22C22F9BDDD0_zps_b889608666455cd13a8e741c1c650a446de09b23.jpg
    38769A32-0DFC-4F4C-92D3-05029C874222_zps_75411e83910efe120e306cb5ac29946097307532.jpg
    Pudge likes this.
  23. Apr 13, 2017 at 7:27 AM
    #53
    RussellVaughan
    Houston
    They still look like that (upside down from yours). I asked my mechanic specifically if the orientation mattered and he was adamant that it did not. Now I feel stupid for not having him correct this. Looking at your pics, it's obvious to me that my cam tabs are resting on the lower lip and aren't sitting flush against the control arm. bolt angle is probably screwed up, not perpendicular to control arm. is this why you think the bolt and bushings are probably bad?
  24. Apr 13, 2017 at 7:37 AM
    #54
    Vizsla
    Vizsla 2 = 2.5
    It definitely matters. You need a good Toyota tech to get you fixed proper, don't take anything but a bill wherever you've been. Those bolts are super important, imagine one breaking etc., I would not drive it like that. Good luck.
  25. Apr 13, 2017 at 7:45 AM
    #55
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Common symptoms of a failed OE wheel hub bearing are :
    • Loose wheels leaning into the vehicle
    • Premature tire wear and poor handling
    • Snapping or clicking noise on turns
    • Humming or rattling when driving straight
    • Anti-lock Braking System (ABS) light is on
  26. Apr 13, 2017 at 7:48 AM
    #56
    RussellVaughan
    Houston
    i think i've been able to rule this out as a possibility. the noise only occurs after I turn, not during the turn. also, its only one pop, not repetitive. i posted a video above of a sound that is very similar to what i hear.
  27. Apr 13, 2017 at 7:50 AM
    #57
    csuviper
    Broomfield, CO
  28. Apr 13, 2017 at 7:58 AM
    #58
    RussellVaughan
    Houston
    its the one that plays when you click the video..at least it was supposed to startup at the right noise...2:26 mark. its the "poign-loin-short02.wav"
  29. Apr 13, 2017 at 8:02 AM
    #59
    csuviper
    Broomfield, CO
    Ok gotcha. Single pop like that sounds like binding that is released. Could be CV still but not showing wear unless you pull it apart.
  30. Apr 13, 2017 at 8:07 AM
    #60
    RussellVaughan
    Houston
    thanks! I will inquire on both issues...the cam tab orientation and cv's.
