Poor Fuel Economy
Discussion in 'Performance and Tuning' started by Jeffery R, Feb 25, 2019.
  1. Feb 25, 2019 at 10:37 AM
    Jeffery R
    Jeffery R [OP] New Member
    Jeff
    2011 Toyota Tundra 4.6 liter
    None
    I have a 2011 Tundra 4.6 liter, I was getting 18-22mpg, all the sudden I have dropped to 11.94mpg. Cleaned the MAF sensor, new air filter, cleaned the throttle body, ran a can of Sea foam through the gas tank. I am thinking O2 sensors, does any one have any other ideas? Which of the 3 O2 sensors controls the most fuel economy?
  2. Feb 25, 2019 at 12:27 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    Somebody else on here had this happen recently, and they found that one of their brake calipers was seized up. Maybe check that.
    14burrito, 15whtrd and Mnorris1206 like this.
  3. Feb 25, 2019 at 4:42 PM
    Jeffery R
    Jeff
    None
    Just got under the truck it has 4 O2 sensors, I do have a brake light on also so I will check the Calipers. Any other ideas are welcome. Thank you
  4. Feb 25, 2019 at 6:19 PM
    A sticking caliper should make it pull to the side pretty hard and you would probably smell the hot brakes.
  5. Feb 26, 2019 at 6:02 AM
    Jeffery R
    Jeff
    None
    So I have been looking at Rock auto for O2 sensors. I found 4 under my truck but can't find any diagram/info that shows all 4 sensors. Does anyone have a better place to find any info?
    My truck does pull a little to the right but not bad enough to say a caliper is stuck.
  6. Feb 26, 2019 at 6:11 AM
    Blueknights75
    Ron
    Clayton, NC
    One thing I learned the hard way. If you are replacing O2 sensors replace them all and replace them with an OE brand! Do it once...
    14burrito, Sas, P-Factor and 2 others like this.
  7. Feb 26, 2019 at 6:15 AM
    15whtrd
    15whtrd Mr. Blonde
    Do you have a infrared thermometer? If you do go for a drive and check each brake rotor individually. It won’t pull very much necessarily if it’s one of the rears. You say it is pulling lightly. A little bit goes a long way.
    14burrito likes this.
  8. Feb 26, 2019 at 9:35 AM
    Jeffery R
    Jeff
    None
    Just shot all 4 wheels with the IR gun nothing sticks out as super hot. I did notice today that idling at the stop light I could feel the truck idling funny. Felt like it was almost cutting out, I will have to find all 4 o2 sensors and go that route next unless there are other ideas?
  9. Feb 26, 2019 at 11:00 AM
  10. Feb 26, 2019 at 11:02 AM
    15whtrd
    15whtrd Mr. Blonde
    Why don’t you pull out a spark plug or two and see how they look. Before you go throwing money at 02 sensors.
    trayday, 14burrito and Blueknights75 like this.
  11. Feb 26, 2019 at 11:08 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
  12. Feb 27, 2019 at 4:43 AM
    Jeffery R
    Jeff
    None
    Thanks for the help everyone, I will let you know what the truck is doing after I do all the O2 sensors.
  13. Mar 7, 2019 at 10:35 AM
    Jeffery R
    Jeff
    None
    So I pulled and replaced all the plugs, new O2 sensors, took it to a shop had them put it on a machine and nothing is wrong according to the machine. All the fuel to air ration is correct, all sensors reading good. I am still getting 11.98 MPG compared to 19 MPG 5 weeks ago. Throttle body cleans, MAF sensor cleaned, I have good compression on all cylinders. Any other ideas out there?
  14. Mar 7, 2019 at 10:44 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Have you checked to make sure a caliper isn't seized, or your alignment isn't messed up and you are plowing.
    Steve89gt and 15whtrd like this.
  15. Mar 7, 2019 at 10:46 AM
    Justin.TX
    Justin.TX South Texas Tundra
    Justin
    2015 Tundra TSS CM
    Ummm. Stuff
    Just pretend you have a 5.7 and it will be right....
    But in all seriousness have you hand calculated MPG or just went off of the computer?
  16. Mar 7, 2019 at 10:47 AM
    15whtrd
    15whtrd Mr. Blonde
    Are you Flexfuel?
  17. Mar 7, 2019 at 11:08 AM
    Jeffery R
    Jeff
    None
    Not Flex Fuel, I always hand calculate, my truck is not equipped with much as far as technology pretty plain Jane Tundra. Just had it aligned last week no calipers sticking, had new rear brakes put on yesterday since it was in the shop. I am seriously running out of ideas, I guess unless I get lucky I will have to wait for something to break and give a code.
  18. Mar 7, 2019 at 11:11 AM
    15whtrd
    15whtrd Mr. Blonde
    Shot in the dark. Maybe unplug the battery for 20 minutes and hit the break pedal a couple times to make sure everything resets. Longshot
  19. Mar 7, 2019 at 11:14 AM
    Justin.TX
    Justin
    2015 Tundra TSS CM
    Ummm. Stuff
    Do you have reduced throttle at all?
    Catalytic Convertor comes to mind
    15whtrd likes this.
  20. Mar 21, 2019 at 6:06 AM
    Jeffery R
    Jeff
    None
    At time it feels like I have reduced throttle, but I took the truck for 1000 mile trip got 13.12 MPG on the way there, 14.59 on the way back at 80 MPH. Now I am back in town getting the 11.92 MPG again. The truck has been hooked up to the computer at a shop 4 times in 2 weeks no codes, nothing wrong as far as they can find.
  21. Mar 21, 2019 at 7:35 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    OP, did you try this yet? Here's why I ask. I was getting 14mpg on the hwy recently on a trip to Athens GA. 75 mph and under, cruise control, not a heavy foot. No mods on my 2018 CM 5.7 4x4 OR, all stock. I've noticed over the last 3-4 months my mileage slowly started going down, hand calculated. Usually 18 on the HWY, to 14. When in Athens, I unplugged my negative terminal for about 30 minutes, which reset the ECU and immediately my mileage went back up. On the way home from Athens, 18.2 MPG, hand calculated. That was in January 2019. My in-town mileage is around 14.5 or so, but that's expected. This may or may not work, and for some reason, it may still be an issue for me over time. But I've never done any mods to my truck, use different gas stations for fuel so I can't explain why this happened to me. I've heard of other folks having the same issue and it was cleared up by doing this. Try it, you have nothing to lose.
    15whtrd[QUOTED] likes this.
  22. Mar 21, 2019 at 2:25 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Try not using the onboard mpg readout. Zero out one of your trip meters and just hand calculate when you fill up like others have said. What do you normally get over the course of a tank? How many miles does your truck have?
    15whtrd likes this.
  23. Mar 21, 2019 at 3:58 PM
    Jeffery R
    Jeff
    None
    Unhooked for about an hour, we will find out tomorrow I have a 280 mile trip so hopefully my MPG is back, fingers crossed. Thanks for all the help and suggestions, I will post the results later tomorrow. Again thanks to everyone.
    15whtrd likes this.
  24. Mar 21, 2019 at 5:20 PM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    Maybe it’s trying to tell you it’s time for an oil change:gossip:
  25. Mar 21, 2019 at 5:49 PM
    Jeffery R
    Jeff
    None
    I hope not since this oil only has 2K on it.
  26. Mar 21, 2019 at 6:26 PM
    Professional Hand Model
    Hand Protectors
    Fuel filter.
    Fuel injectors.
    May be clogged/dirty.
  27. Mar 21, 2019 at 6:37 PM
    T@B400_Puller
    T@B400_Puller New Member
    2015 2 WD Tundra SR5
    Possibly a wheel bearing? I watched a guy jack a vehicle up in a shop and he spun the wheels slowly one at a time while listening to the hub with a stethoscope. It is possible that a wheel bearing is dragging?
    Having just purchased a 2015 Tundra with a 4.6 L I am just happy to hear that you were getting 18-22.
  28. Mar 22, 2019 at 12:28 PM
    Jeffery R
    Jeff
    None
    15whtrd said was correct resetting the ECU worked. I drove 78-79 MPH all trip and got 17.91 MPG. Thanks.
    Finch and 15whtrd like this.
  29. Mar 22, 2019 at 12:49 PM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    So resetting the ECU was the fixer?
  30. Mar 22, 2019 at 12:51 PM
    Jeffery R
    Jeff
    None
    Yes sir
