Pond boats and towing a pop up/camper
Discussion in 'Fishing' started by frichco228, Mar 10, 2020.
  1. Mar 10, 2020 at 9:16 AM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Does anyone have a small pond boat like a pond prowler, sundolphin or such?
    How well do they fit in the truck bed?
    I have a crewmax...considering a 10 foot prowler but also need to tow a pop up camper. Think the boat will be too long?
    If so, wonder if I can somehow lift up the rear of the tow when hauling it and towing to get some extra clearance?
    jewsNbrews likes this.
  2. Mar 10, 2020 at 8:24 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have a 10 ft Jon Boat that goes grate in the bed of my truck. I also made a rack to lift it above the bed so I can tow my other boat as well. 20181202_072716.jpg 2019-12-11 22.01.20.jpg
    20191022_162000.jpg 20191129_091924.jpg 20191129_145642.jpg 20191129_095655.jpg 2020-02-17 15.47.07.jpg
  3. Mar 11, 2020 at 6:32 AM
    frichco228
    Thanks, I have the 5.5 bed so a 10 ft pond boat would stick out a little more. I am thinking that I may be able to rig something to raise the rear end of the boat in the bed to gain some extra clearance when towing.
    Nice truck you have there.
    Brown Bear likes this.
  4. Mar 11, 2020 at 6:58 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    When I was younger my dad had a similar problem you do. He just cut some 2x4s to the width of the pop-up and lined them with some old carpet. We would then just flip the boat over and place it on top of the pop-up, and tie it down. Works great if you always have someone with to help. Not my picture but a Google search pulled up some results of what I mean...
  5. Mar 11, 2020 at 8:33 AM
    frichco228
    That could be a solution, however, my Pop up has rooftop AC. That is a cool rig!
    Medic343[QUOTED] likes this.
  6. Mar 11, 2020 at 10:55 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    Depending on the layout of your boat you may be able to "fit" the AC in the void the hull creates when flipped upside down. Maybe?
    pickeledpigsfeet likes this.
  7. Jan 22, 2021 at 9:36 PM
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    I have an 8 ft. Bass Pelican I put in my 2010 CrewMax. I put it in the bed or turn it sideways and sit it on top of my bed. Works great. I’m now working on installing an ATV winch in the bed to pull it up out of the water.
