Poly LCA bushings???
Discussion in 'Suspension' started by TexasTundra27, Mar 29, 2018.
  1. Nov 30, 2021 at 12:46 PM
    #121
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Yes, you definitely can. You'll need a good bench/vice, impact, and reciprocating saw.
    Sumo91[QUOTED] likes this.
  2. Nov 30, 2021 at 3:08 PM
    #122
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Reciprocating saw? To install bushings? Kinda lost me there. I have a 20 ton press at my house but won't be doing the work there, and I REALLY don't wanna load that thing up
  3. Nov 30, 2021 at 3:25 PM
    #123
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    Just in case you have to cut the bushing sleeves out. I've had to chisel one out in pieces before because it was rusted/seized. Would've made it a heck of a lot easier for me.
    Just the right fittings and you should be able to do it with a ball joint press.
  4. Nov 30, 2021 at 4:24 PM
    #124
    Sumo91
    TN
    Ahh for the sleeve! I'm hoping that won't be a problem, truck has zero rust, but who knows. I'll cross that bridge when I get there. I'm installing new UCAs so gonna refresh the lowers while I'm at it
    wv00097[QUOTED] likes this.
  5. Dec 10, 2021 at 2:55 PM
    #125
    Sumo91
    TN
    Finally done with a 3 month job, and my bushings were waiting for me today! I quickly realized my ball joint press is too small to fit these massive bushings, and my 20 ton press is 5 hrs away, so looks like I'm taking it to a machine shop to get them pressed in
    wv00097 likes this.
  6. Dec 11, 2021 at 2:37 PM
    #126
    Sumo91
    TN
    Has anyone else noticed how the big bushing doesn't have a taper, but the smaller bushing is tapered, and falls almost all the way into the hole, and only has to be pressed in a half inch or less? Would this cause any issues? Seems like it has alot of room to move up and down under load
  7. Dec 11, 2021 at 4:12 PM
    #127
    Sumo91
    TN
    So I got bushings pressed in, had to take it to a machine shop, 18 bucks a bushing and he made the metal collars to fit them perfectly, his press had a gauge on it, and it never went over 5 tons. I did apply anti seize to the inside so that may have reduced friction, a 12 ton press from harbor freight should be able to handle this job no problem! He also told me the smaller bushing with the shoulder was designed like that to allow wiggle room for alignment. So I got my answer to that question
    NueveTundra and wv00097 like this.
  8. Jan 11, 2022 at 3:56 PM
    #128
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    Finally got around to getting an alignment and wrapping this project up. Truck rides great with the new steering and LCA bushings, firmer, but well worth it. Steering feels new/stock again.
    BigAl likes this.
  9. May 18, 2022 at 7:59 AM
    #129
    Milowilli
    Milowilli New Member
  10. May 18, 2022 at 8:23 AM
    #130
    Sumo91
    TN
  11. Sep 28, 2022 at 5:12 AM
    #131
    Tundra_King1
    Tundra_King1 New Member
    Ryan
    2018 Tundra 4x4 5.7L Crewmax
    2.5" Level with Bilstein 5100s, 275/70R18 Nitto Ridge Grapplers, and JBA UCAs.
    These fit 2014-2021 Tundras? I have a 2018 and looking to replace the bushings with polys.
