Poly LCA bushings???
Discussion in 'Suspension' started by TexasTundra27, Mar 29, 2018.
  1. Oct 9, 2018 at 12:19 PM
    #61
    TexasTundra27
    TexasTundra27 [OP] Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    For a brief second I was considering the LSK stock length lowers, but the $1900 preorder price and $2400 normal price is still too rich for my blood. Im gonna give Energy Suspension time to come up with something like they said and I’ll decide which bushing to go with from there.
    SoCal619 and dcsleeper408 like this.
  2. Oct 9, 2018 at 1:27 PM
    #62
    stealth09
    stealth09 New Member
    Canada
    I am surprised it has took them so long to come up with one, considering the market wanting them.
    TexasTundra27[OP] likes this.
  3. Oct 9, 2018 at 5:40 PM
    #63
    Bulhas
    Bulhas New Member
    Joe
    2007 Double Cab Limited
    They already sell bushings lol ..... The superpro are the answer! No need to wait anymore they are here
    The LC200 and tundra control arms are the same
  4. Oct 9, 2018 at 6:36 PM
    #64
    TexasTundra27
    Mark
    I understand that, but want to see what the people that have bought them have to say in a few months, and as I said earlier I’d love to have the energy suspension bushings that are made with graphite in them so they’re self lubricating to an extent.
  5. Oct 10, 2018 at 6:41 AM
    #65
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Does each part number come as a pair?
    So do you need to order 1 of each part number or 2 of each part number?
    USA guys, where are you going to source them? Looks like Energy sells them, and they're in stock.
  6. Oct 10, 2018 at 10:19 AM
    #66
    stealth09
    Canada
    1 of each.
    I got mine from suspension.com I believe.
  7. Oct 11, 2018 at 8:44 PM
    #67
    stealth09
    Canada
    Not sure if this is normal but the bushings leave a little bit of space for in the control arm pocket. Hopefully it closes up once I tighten them. Btw if it looks different than your LCA pockets, it’s because i am installing a lift.
    I might install a washer.
    dcsleeper408 likes this.
  8. Oct 12, 2018 at 5:26 AM
    #68
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    that doesn't look right to me. Especially if the inner sleeve isn't long enough. If you install a washer, you might find that it won't hold an alignment because the cams will wander. But maybe not
    14burrito likes this.
  9. Oct 12, 2018 at 10:08 AM
    #69
    stealth09
    Canada
    No the washer should have no effect on it. Lots of other kits come with washers on different vehicles.
  10. Oct 13, 2018 at 2:46 AM
    #70
    stealth09
    Canada
    Update: that’s the way it is when it is not tightened. When I tightened up the bolts it was all good!
  11. Nov 12, 2018 at 5:16 PM
    #71
    TexasTundra27
    Mark
    How’s the ride? Any difference from stock?
  12. Nov 12, 2018 at 5:43 PM
    #72
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Were you able to identify any play in the LCA bushing, or was it just that process of elimination you mentioned that led you to the bushing replacement? I've torqued everything down and I couldn't identify any play in the LBJ or the bushings. We have a little popping and a loose feeling, especially when the wheel falls away from the truck (if that makes sense).
    Any noticeable difference? Did you change yours just because you were installing the lift, or were your stocks bad?
  13. Nov 12, 2018 at 7:07 PM
    #73
    TexasTundra27
    Mark
    Honestly I ASSumed that it was the LCA bushings because of the mileage I have and the life it’s had. Turned out to be the steering rack bushings which are a royal PITA to replace. I had a loose feeling and popping noise also, with all that you do in your truck I’d say check the steering rack bushings first.
  14. Nov 13, 2018 at 1:23 AM
    #74
    stealth09
    Canada
    Honestly, I am not sure. Everything feels good.
    My truck has high mileage and since the suspension was due for replacement, I just replaced everything.
  15. Nov 13, 2018 at 5:21 AM
    #75
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thats how mine feels. Replacing the drivers tie rod end today. It has 1mm - 2mm play in it. I can grab the brake caliper and put my fingers on the joint and I can feel it move when I wiggle the caliper.
    KevinK[QUOTED] likes this.
  16. Nov 14, 2018 at 6:55 AM
    #76
    KevinK
    Tundras to Sedona
    Yeah, I considered the steering rack bushings first, but we just had the rack replaced less than 10k miles ago. I also ASSume the bushings are replaced when the rack is, but might have to confirm that with the dealership. Did you go with the poly bushings for the rack?
    Right on, that makes sense.
    I checked the tie rods and LBJ and they all felt good. Gonna have to tear it apart more deeply in order to free the LCA from the spindle and coilover/bypass so I can really check for play in the bushing without anything connected to it applying pressure. @Prostar 190 I may be asking to rent your garage again soon. :rofl:
    Prostar 190 likes this.
  17. Nov 14, 2018 at 6:59 AM
    #77
    TexasTundra27
    Mark
    Yes I did, twice because I’m stupid... :anonymous:
  18. Nov 14, 2018 at 7:05 AM
    #78
    KevinK
    Tundras to Sedona
    Hate to say it, but I love hearing that other people do stupid things too. Makes me feel less alone in my stupidity. If I may ask (just so I don't do it too) how did you do it twice?
  19. Nov 14, 2018 at 7:11 AM
    #79
    TexasTundra27
    Mark
    Was tired and in a rush (had an appointment to drop my truck off at Toyota the next morning) and didn’t torque the bolts down properly... so I got to torque them while on Imogene Pass in Colorado but it was too late, they were already trashed.
  20. Nov 14, 2018 at 7:22 AM
    #80
    Just get a hold of me.:thumbsup:
  21. Nov 14, 2018 at 6:11 PM
    #81
    KevinK
    Tundras to Sedona
    How do you torque them? I can only get a torque wrench to the bolt on the bottom, and not the nut on top. Do you just hit the bolt with the 89 lbft?
  22. Nov 14, 2018 at 6:39 PM
    #82
    TexasTundra27
    Mark
    That’s what I did, the first time I just used a 1/2” ratchet. No issues since I torqued it.
    dcsleeper408 and KevinK[QUOTED] like this.
  23. Feb 12, 2019 at 4:17 PM
    #83
    TexasTundra27
    Mark
    Any squeaks or issues from the bushings? I think I’ve waited as long as I can for energy suspension to come out with something.
    14burrito and KevinK like this.
  24. Feb 12, 2019 at 8:39 PM
    #84
    KevinK
    Tundras to Sedona
    Same. I need to fix our shit before Tundras to Sedona. I think body mounts and these polys if the status report is good from @stealth09
  25. Feb 12, 2019 at 8:54 PM
    #85
    TexasTundra27
    Mark
    Exactly what I’m trying to prepare for, research online says this company makes some bad ass bushings so I have high hopes. Problem is theyre in Australia
  26. Apr 21, 2019 at 2:59 PM
    #86
    TexasTundra27
    Mark
    Installing them this week, first impressions are good. High quality stuff!
    mcharfauros, careyrob and Vizsla like this.
  27. Apr 21, 2019 at 8:15 PM
    #87
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    What the price end up being for the bushings
  28. Apr 21, 2019 at 9:39 PM
    #88
    TexasTundra27
    Mark
    About $250 shipped from Australia
    Yota100[QUOTED] likes this.
  29. Apr 22, 2019 at 6:25 AM
    #89
    Yota100
    Yota100 New Member
    That's not bad
  30. Dec 27, 2019 at 4:08 PM
    #90
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Old thread, but this is where I found the info so thought I would add to it. Just finished my LCA bushings as well as swapping to 700lbs coils at the same time. Tomorrow will be the poly bushings for the steering rack. I did the bottle jack method to take the old out and that shit is dangerous but effective. Used coil compressors and u joint press pieces to get them back in. Not ideal, but I worked with what I had. I did destroy the coil compressors by stripping the threads on it and had to buy new ones to finish the job. Can’t wait for the steering bushings and alignment to see how it feels. Since I pulled the cam tab bolts to do this I switched over to the SPC cam tab bolts. Thanks guys for doing the research and documenting it. C1CFCCFC-63FF-4C20-B7CF-803E27A49879.jpg33842619-BCD8-41AB-A456-CA982DF6081E.jpgBD7E8249-0524-49E5-B1A5-55839C70A9F9.jpg
