PML Deep Transmission Pans
Discussion in 'General Tundra Discussion' started by Black Wolf, Apr 26, 2018.
  1. Jul 15, 2018 at 9:57 AM
    Black Wolf [OP] Chillin' in Alamosa
    Shouldn't make any difference. Probably why nothing was done in regards to changing the pickup location. The PML's for the 5.7L should be coming out soon.
  2. Jul 18, 2018 at 5:47 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    I am definitely down for this pan, thanks for the info. On a side note when I purchased my project truck not knowing if the tran service was done at 90K I wanted the dealer to do a full flush and service. The Toyota Master tech said absolutely not and recommended they do what you described above, unless I am having problems with the transmission. He told me especially on higher mileage vehicles a full flush and service usually means the death of these transmissions and it's just better to do a partial fluid change and leave it be.
  3. Aug 2, 2018 at 8:38 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Based off the install pics, having a tough time judging where it sits in correlation to the frame. Does it extend down past or is it flush?
  4. Oct 18, 2019 at 5:07 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Has anyone got an update on the performance of the new pan?
  5. Oct 18, 2019 at 7:52 AM
  6. Oct 18, 2019 at 8:26 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
  7. Nov 16, 2020 at 5:56 AM
  8. Nov 16, 2020 at 12:27 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I know it says that the new pan is still above the frame, but I can't help but notice that the bottom of the "shorter" pan has clear signs of contact with the ground... Does the idea of lowering the bottom of that pan by 1.5" make anyone else nervous?
  9. Nov 16, 2020 at 1:00 PM
    Who knows where that OEM has been? No need to get nervous at all. Any tranny pan can get possibly scratched up off roading if not protected. Hence>>>>>>>RCI tranny skid and it shouldn't interfere with the PML pan, but you can always add spacers similar to the ones used on front skids with the diff drop.
  10. Nov 16, 2020 at 1:40 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Thats pretty rad! Can anyone confirm this thing actually helps with cooling? Otherwise the extra fluid doesn't strike me as the one reason to do it.
  11. Nov 16, 2020 at 2:31 PM
    You get 3 1/4 quarts of additional capacity. The prime reason for that is to lower temps. It has internal baffles in conjunction with the external heat sink fins. Most reviewers stated an increase in cooling. 10 to 12 degrees F. Not earth shattering but combined with the external kit that members are adding on the newer Tunny's without the cooler should be a big plus, especially in hi demand situations if you tow a lot. B&M makes them too but PML specializes in hi capacity pans.
    Keep in mind keeping tranny temps down when hitting the dunes is a plus. Sand puts a pretty decent load on your tranny and raises temps pretty fast.
    Sundog likes this.
  12. Nov 16, 2020 at 2:35 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Those are some serious cooling Fins!
  13. Nov 16, 2020 at 2:50 PM
    They don't cool, they help dissipate heat. The taller the fins, the better dissipation you get. Heat sinks are used on most power transistors and SCR's to prevent overheating. High tension transformers on power lines have the fins to help dissipate heat.
    Mdl and 14burrito like this.
  14. Nov 17, 2020 at 1:11 PM
    blanchard7684
    blanchard7684 New Member
    I’d love to see testing on this for the 2019+.
    I am interested in a pan upgrade for higher capacity but if it helps a bit with thermal management and is an easy install done when servicing it’s a huge help.
  15. Mar 26, 2021 at 10:05 AM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    These should work on 2019s too right?
  16. Mar 26, 2021 at 10:16 AM
    Yes
  17. Mar 26, 2021 at 10:19 AM
    HONEYBADGER
    cool thx
  18. Mar 26, 2021 at 10:51 AM
    You should give them a call. A family owned business.
  19. Mar 26, 2021 at 11:23 AM
    #49
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
  20. Mar 29, 2021 at 6:25 AM
    #50
    mb66l79
    mb66l79 New Member
    For anyone that has installed the PML pan, any feedback? Do you also have a skid plate or cat protection plate and are there any clearance issues?
  21. Apr 24, 2021 at 7:18 AM
    #51
    el_taco
    el_taco New Member
    Yes this. Im interested but have RCI trans skid. Concerned about clearance.
    I tow a bass boat in summer so this may help...not that i noticed any issues with stock.
  22. Aug 5, 2021 at 4:21 AM
    #52
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    :notsure: In heat transfer terms isn't cooling and heat dissipation the same thing if there is no phase change (gas to liquid, liquid to solid)?
    The trans fluid is always liquid so the temperature must decrease at that location if you dissipate heat from it.
  23. Aug 5, 2021 at 5:32 AM
    #53
    Exactly. The heat sink "fins" dissipate heat. Heat sinks are used to help prevent overheating by dissipating heat. Not all heat sinks are fins. Example....this RF Measuring Receiver has 4 high power transistors that still get pretty hot even with a 1" thick honeycomb heat sink. Same principle. Heat sinks are a passive device used simply to dissipate excessive overtemps that could damage the transistors over time and cause them the fail.
  24. Jun 26, 2023 at 7:09 PM
    #54
    usebothhands
    usebothhands New Member
    SF, CA
    2012 Tundra DC Limited 5.7 4x4
    285/70 KO on TRD 17s, 6112 @ low, 5160 w/1" shackle spacer
    Bumping this as I myself looked for this answer a couple weeks ago and couldn't find anything except these unanswered questions. Apologies if out of line with reviving the dead thread.
    I installed the RCI aluminum engine and tranny skids plus cat guards on my 2012 5.7 limited this weekend. No clearance issues with the PML tranny pan. I don't have a diff drop so I didn't deal with the spacers on engine pan. There is still a gap between bottom of PML deep tranny pan and the RCI tranny skid. Hard to get to so I can't measure it, but it's enough. Maybe an inch, maybe a bit less. But enough for airflow and clearance for any flex if you strike any debris, I would think.
    No issues with install. The "new" or updated RCI tranny skids (which are what I received) already have the holes cut out for the cat guards. Apparently with the older version ones you need to cut the holes yourself. I lined the cat guard bolts up as best I could to the "center" of the pre drilled rectangular holes on the tranny skid, and it all lined up great during install, no adjustment needed. I first loosely mounted the crossmember adapter to the tranny skid before wheeling it below truck with floor jack. Bit of wiggling and rubber mallet banging to wedge it into the space to mate with the engine skid with the 4 inch carriage bolts. Then aligned up the crossmember thing and attached it to the frame (two bolts). Then had to maneuver around to get my hands inside the skid to do the final tightening of the tranny skid to the cross member adapter bolts. Drivers side rear bolt was a PITA. Got a ratcheting wrench in there through the drain hole opening then used another wrench hanging over the side to push it to tighten, then reached back through drain hole to reset the ratchet and repeat until I felt it was tight enough. Then I was able to reach in the drain hole cutout and grab my tools when done. The other three bolts were easy to access and got nice and tight for sure.
    Note - the PML deep pan does not have the drain and check holes in the same spot as stock, so the cutouts on the RCI skid aren't any help for trans fluid change with the PML deep. You could drill your own holes where you need them, or just drop the plate, but I'll deal with that in 50k miles or so later on :D
    VWTim and ryanwgregg like this.
  25. Jun 27, 2023 at 7:04 AM
    #55
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Pops has the deep pan from B&M with rci skids no clearance issues at all. Purchased and installed by SDHQ
    ryanwgregg likes this.
  26. Jun 27, 2023 at 7:25 AM
    #56
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Thanks for posting this, looks like people have been asking about clearance since they came out. Will likely do this if/when I do a valve body upgrade and need to drop the pan again now that I know it fits under an RCI skid.
    2mchfun likes this.
  27. Jun 27, 2023 at 11:27 AM
    #57
    usebothhands
    SF, CA
    And here it is from the back - was able to reach in from the back end and grab a pic with phone and tape measure. Since the pan is slanted a bit, it looks like it gets as much as 3 inches clearance (tape measure body) and at least 1.5 from the existing drain hole in the skid to the closest cooling fin of pan.
    ... Not sure what the reddish stain is ... hoping it's just some leftover ATF on the exterior of pan that dripped off with condensation... :O will update if it's anything else.
  28. Jun 27, 2023 at 11:46 AM
    #58
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Have you noticed any lower overall temps with the increased fluid capacity?
  29. Mar 8, 2024 at 11:03 PM
    #59
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    If you buy the B&M pan for SDHQ they give you the option to add the factory Toyota gasket and filter fyi! Huge plus. Yes it does drop the temps on the trans.
