Plumbing Issue
Discussion in 'Off-Topic Discussion' started by TXRailRoadBandit73, Apr 17, 2019.
  1. Apr 17, 2019 at 8:59 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Paging Dr. @15whtrd
    Issue... I keep having to replace these gaskets behind the valve for cold n hot water in boys bathroom, since I've been here since 2010, I've done this at least a dozen times :mad: apparently these "purple gaskets" are better??? But I just did this about 6 months ago and hot water is leaking again, also replaced valves and these metal cones as well, what gives?!?!??? I tell the boys not to crank down too tight, any solutions???
    Also in our shower the cold squeaks, but to get handle off, the Phillips screw is so tight I don't want to mess up the head on it, what would you or how to remove it, break handle and use vise grips to remove phillips screw???
  2. Apr 17, 2019 at 9:03 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Change to single lever faucets. "Cranking down" not an issue.
  3. Apr 17, 2019 at 9:05 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Municipal or well water?
    High chlorine or low Ph?
  4. Apr 17, 2019 at 9:05 AM
    Do I cap off hot n cold? I'm not much of a plumber but know just a tad
    Also then I'll have two holes in tile, and I don't know how to cover or don't know how to do tile job either :anonymous:
  5. Apr 17, 2019 at 9:06 AM
    City, TBH IDK that info :anonymous:
  6. Apr 17, 2019 at 9:10 AM
    JohnLakeman
    "Cap off"?...Neither, you just connect the flex lines to the hot and cold valves just like any other faucet. You swing the single lever to the left for hotter, to the right for cooler, back for high volume, and forward to shut off. Delta was the original design, but there are a lot of imitators now.
  7. Apr 17, 2019 at 9:17 AM
    Old one on left, from hot water
  8. Apr 17, 2019 at 9:20 AM
    JohnLakeman
    First, try using a high quality, unworn, almost new Phillips screwdriver of the proper size...it has to fit tightly.
    Phillips or cross recess heads were designed for Henry Ford to prevent the "camming out" of straight slot screws. But, a Phillips driver will still "cam out" if the screw is very tight. The trick is to apply all the axial force you can directly into the recess to hold the driver DEEP in the recess. If you can prevent the driver from backing toward you, then it's possible the screw will turn with all the force you're applying.
  9. Apr 17, 2019 at 9:25 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    You need to replace your faucet.Going with the single lever faucet made by Delta is the way to go.With Delta,if you have a leaking problem in the faucet,you remove the handle and cap and you replace a cartridge that has everything in it that needs to be replaced.Very user friendly for people who aren't plumbing oriented. I do kitchen and bathroom remodeling and Delta faucets are very reliable and easy to repair when needed
  10. Apr 17, 2019 at 9:30 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I hate to tell you. Faucets are one thing that the more you spend the better they are. I know that you can spend $150 ish for something at the big box stores. Go to a plumbing house and by good faucets. Gonna set you back $500 or more. You get what you pay for. My old man put in a $300 moen in the kitchen in 1964. I just replaced it last year.
  11. Apr 17, 2019 at 9:44 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    You can find single lever faucets that have rectangular dress plates large enough to cover the existing two-handle faucet holes included with them. Or maybe the plates can be purchased separately. Just make sure that you by a good quality cartridge insert style fixture. The better Delta, Kohler and Price-Pfister models are a couple of the good brands that I've had good experiences with. HD or Lowes should have something. Or maybe even True-Value (I know that TX has some especially awesome True-Value stores.)
    As long as you have access to the space behind the faucet, replacement shouldn't be too hard. If the pipes on the old faucet don't line up with the new faucets, Sharkbite fittings can be a god-send.
    Good luck!!
  12. Apr 17, 2019 at 9:46 AM
    Fishman57
    Wayne
    Bucks County, PA
    Like @Racingjohndeere55 said: Plumbing supply houses will have the best ones but :spending::spending:.
    JohnLakeman likes this.
  13. Apr 17, 2019 at 9:47 AM
    Replaced cold , right side
  14. Apr 17, 2019 at 9:47 AM
    All well now, but will look into single lever soon, thanks for replies guys!!! Greatly appreciated!!!
    Racingjohndeere55 likes this.
  15. Apr 17, 2019 at 10:21 AM
    Rex Kramer
    Georgia
    Chlorine will eventually destroy rubber gaskets, shop for a new faucet and check to see if the gaskets & seals are chlorine tolerant. Low Ph will eventually destroy metal making any gasket ineffective, early symptoms include blue green stains where water drips.
  16. Apr 17, 2019 at 10:22 AM
    Racingjohndeere55
    No chlorine, no heavy minerals. I love my well!
    Rex Kramer[QUOTED] likes this.
  17. Apr 17, 2019 at 10:29 AM
    15whtrd
    15whtrd Mr. Blonde
    The metal cone things are the seats. And obviously the purple are the washers. As long as the seats are nice and smooth there is not much you can do. I have the same valve in my parents bathroom shower. Price Pfister. I haven’t changed the washers in probably seven years. The trick is definitely not cranking down too tight. Your squeaky shower stem can be remedied by removing the stem. Unscrew the valve stem from the body of the stem and grease the entire shank and threads. Make sure you snug up the packing nut. Not too tight not too loose.
  18. Apr 17, 2019 at 10:35 AM
    15whtrd
    15whtrd Mr. Blonde
  19. Apr 17, 2019 at 10:36 AM
    15whtrd
    15whtrd Mr. Blonde
    If you notice, the seat that you took out rough surface. That will slowly wear down the washer. Also in the video he is calling what I call the packing nut he is calling the bonnet. Same thing
  20. Apr 17, 2019 at 10:50 AM
    15whtrd
    15whtrd Mr. Blonde
    One reason besides a bad seat why the washer wears out, is cranking them down too tight. People tend to crank them down because they want the water to stop coming out of the faucet instantly. There is going to be a certain amount of time for the spout to drain out once the water is shut. Spin the handle until you feel some resistance. Only a couple of inch pounds is needed. Test it for yourself. Shut it off lightly and see if the water stops coming out after a few seconds.
    Obviously you could switch to a new faucet with a ceramic disc cartridge etc. But these are really good faucets. They are almost infinitely rebuildable. These things are like the Toyota of faucets. I’ve been in homes that had them for at least 70 years. Still working.
  21. Apr 17, 2019 at 10:56 AM
    Very informative vid, my Dad has those wrench's and I never knew that's what they were for :anonymous:
    15whtrd[QUOTED] likes this.
  22. Apr 17, 2019 at 10:58 AM
    15whtrd
    15whtrd Mr. Blonde
    I always called them bell sockets. Pretty inexpensive but great to have. Some even work really well to install faucets so that you can get to the “large nuts underneath”. See what I did there?
  23. Apr 17, 2019 at 10:59 AM
  24. Apr 17, 2019 at 11:03 AM
    War Machine
    War Machine SSEM # 5 3MW
    Really? I’ve got a small leak under the kitchen sink that my wife discovered a couple of days ago. Pretty sure it’s a Delta faucet, and the cartridge is easy to get to. It’d be nice if it’s that easy to fix.
  25. Apr 17, 2019 at 11:03 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Have it color match the tundra
  26. Apr 17, 2019 at 11:04 AM
    War Machine
    I think so. The large nuts part right?
  27. Apr 17, 2019 at 11:04 AM
    War Machine
    That will just make it leak slower.
  28. Apr 17, 2019 at 11:05 AM
    Racingjohndeere55
    War Machine[QUOTED] likes this.
  29. Apr 17, 2019 at 11:09 AM
    Racingjohndeere55
    Dont throw the old cartridge away. They are usually o-rings in it and you can replace them and smear some vasolein on it and have a spare
  30. Apr 17, 2019 at 11:10 AM
    War Machine
    Problem is I never have Vaseline to spare.
    bvia, Sas, TheBeast and 1 other person like this.
