Plug for the truck tailgate light strip?
Discussion in 'Lighting' started by MXPCUS, Oct 7, 2021.
  1. Oct 7, 2021 at 6:33 AM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    If I get a taligate light strip for braking and turn signals, can I use the same plug that my old topper was plugged into? The topper is gone now, but the wire is still near the end of the bed
  2. Oct 10, 2021 at 11:48 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
  3. Oct 11, 2021 at 4:07 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    You disconnect the original connection behind the bumper, then this plugs in between the bumper and the original connection. It also has a 5 pin connector, but some lights come with 4 pins already wired up and the reverse wire is "loose". You can plug in the 4 pin (only one way to plug) and then get a butt connector and crimp that onto the loose reverse wire, and plug into the remaining hole on the connector.
  4. Oct 12, 2021 at 2:34 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Mike59 likes this.
