Plug and Play Turn Signal LED replacements
Discussion in 'Lighting' started by abear, Mar 1, 2017.
  1. Mar 1, 2017 at 3:01 PM
    abear
    abear [OP] Abear
    Jude
    Louisiana 71037
    '17 Tundra 1794 4x4
    While out searching for an LED replacement option for my rear turn signals, I discovered SIRUS offered several wiring adapters with built load resistors. None of the adapters matched the bulb replacement for the Tundra rear turn signals, so I contacted them to see if they would consider offer a load resistor solution for the 921 bulb. They did provide the following response:
    We do offer a new style of that sized bulb that could bypass that read for majority of cars you could try.
    https://www.amazon.com/SiriusLED-Ex...&qid=1488183474&sr=8-1&keywords=siriusled+921
    I took the chance and purchased a pair of these. They arrived today and work perfectly. I simply removed the OEM bulb inserted the replacement LED and signal indication works fine. Ran them for 15 mins straight, no issues. If you are looking for an LED replacement solution and didn't want to hack into your wiring harness to install a load resistor, this is it...
    Abear
  2. Mar 1, 2017 at 3:20 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Thanks for this! I been looking for this solution forever!!! How. Right is it in the daytime? Is it as bright or brighter than the originals? Do you have before/after pic?
  3. Mar 1, 2017 at 3:20 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Also I was planning on using a red led. What color does it come out since the led is white ?
  4. Mar 1, 2017 at 4:58 PM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    Could you post a pic? I want to upgrade to LED's on my 2017 CM, but I'm not crazy about splicing into the stock wiring harness.
  5. Mar 1, 2017 at 7:05 PM
    abear
    abear [OP] Abear
    Jude
    Louisiana 71037
    '17 Tundra 1794 4x4
    I will say this they are brighter the OEM bulbs... Even though the LED is white, with the red lens, they emit a bright red light... Since they are the turn indicators, I'm struggling to get a good picture, took three a minute ago all were when the indicator flashed off or just coming on... it's more difficult than I thought....ok... I'll try and get a picture tomorrow.
    BlueBottle likes this.
  6. Mar 1, 2017 at 7:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    great @abear ! you just made me spend $25 on this lol... I should get it on friday and I will take some shots to compare them to stock.
  7. Mar 1, 2017 at 7:45 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :popcorn:
  8. Mar 3, 2017 at 9:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wow these are brighter than stock!!! And no hyper flash. Thanks @abear for the recommendation.
    Left is LED right is oem.
    I will upload pictures soon
    https://youtu.be/fCEdB4rlp2I
    Backslider and cjmay13 like this.
  9. Mar 3, 2017 at 11:31 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Left is LED, Right is OEM
    SouthBoundSteve likes this.
  10. Mar 4, 2017 at 4:02 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Do they have them for the front??
  11. Mar 4, 2017 at 6:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It is the same as OP. No adding resistor. All I did was change the bulb. No hyper flash.
  12. Mar 4, 2017 at 6:48 PM
    abear
    abear [OP] Abear
    Jude
    Louisiana 71037
    '17 Tundra 1794 4x4
    I have not been able to locate a solution for the fronts yet. The fronts unfortunately are also CK format and there doesn't seem to be a lot of support for that format.
    Abear
  13. Mar 5, 2017 at 2:06 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Had to order more,fried one geeting it hooked up yesterday:facepalm: When I get 'em,I'll make sure to pull the one that's working, to make sure how they need positioned in the housing.Using them in the doors on my 2010 DC. In comparison,they look like they're twice as bright as the LED's I have now:thumbsup:.
  14. Mar 5, 2017 at 7:29 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    How did you fry it? You should be able to plug it in Either direction? Unless you touched the truck body with the light as you are plugging it in? Make sure the light is off when you are plugging it in.
  15. Mar 5, 2017 at 8:41 AM
    CMB
    CMB New Member
    Cecil County MD.
    I'm not sure if it has to do with the fact that these LED's are "2 sided" or not. Not really possible to touch anything as they're being installed. The door bulbs are contained in a "capsule" that snaps into the housing which snaps into the door. I'm replacing LED's that have been in my truck for several years but these are just a little larger, so I won't be able to just slap' em in there like the smaller ones.
  16. Mar 6, 2017 at 6:12 AM
    MrWrench
    MrWrench New Member
    Thanks for uploading pics of the new lights. Now you are forcing me to buy some new lights for truck hahahaha
    BlueBottle[QUOTED] likes this.
  17. Mar 6, 2017 at 8:53 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  18. Mar 26, 2019 at 12:34 PM
    Billthecat67
    Billthecat67 New Member
    Tried theses in my 18 TRD Sport CM and still had hyper flashing.
  19. Mar 26, 2019 at 12:42 PM
    Billthecat67
  20. Mar 26, 2019 at 12:56 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
  21. Mar 26, 2019 at 1:08 PM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    Blacked 2015 going strong!
  22. Mar 26, 2019 at 1:22 PM
    sundance
    sundance New Member
    Good for DRLs too?
  23. Mar 26, 2019 at 1:25 PM
    CCLJ03
    Craig
    I’ve got the 2018 LEDs and only the outer whites light up so I don’t know! I’m sure they’d be good though.
    sundance[QUOTED] likes this.
  24. Mar 26, 2019 at 1:31 PM
    sundance
    sundance New Member
    Thanks! I've tried them and DRL usually works but the turn signal doesn't. Good to know these work on the turns....
  25. Sep 9, 2019 at 8:27 AM
    tigerbite84
    tigerbite84 New Member
    Changed pins and also installed the JDM ASTARs on my 2018 led headlights, still have hyperflash? Any ideas?
  26. Mar 4, 2020 at 12:56 PM
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    For those that want to know, the Sirius 921 LED turns signals do not work on 2020 models when you have the JDM Astar LED Bulbs in the front. You will get hyperflash.
  27. May 12, 2020 at 4:34 PM
    mightyowl
    mightyowl New Member
    So it sounds like, its either or then?
    with both led install is too low of resistance to work properly is where I'm getting at?
  28. May 12, 2020 at 4:35 PM
    mightyowl
    @BlueBottle What are you running in the front turn signals?
  29. May 12, 2020 at 4:45 PM
    Tundra234 Mods, mods, and more mods
    Vleds is what you will want. Don't use cheap Autozone or Amazon bulbs.
  30. May 12, 2020 at 4:49 PM
    mightyowl
    $30 per bulb is a bit steep. And also still seems to need load resistors for hyper flash
