Please help me install my first tonneau cover...
Discussion in '3rd Gen Tundras (2014+)' started by tundrathr0w, Aug 17, 2018.
  1. Aug 17, 2018 at 8:53 PM
    tundrathr0w
    tundrathr0w [OP] New Member
    2018 Silver Sky Metallic Tundra CrewMax 4x4 5.7L
    My Tundra is not only my first Tundra, but also my first truck. Please pardon my ignorance and stupid questions.
    I got me one of these Tyger tonneau covers: https://www.amazon.com/Tyger-Auto-TG-BC3T1432-2014-2018-Fleetside/dp/B011AO376S
    The instructions say that the clamps must hook onto the metal bed lip:
    But I cannot for the life of me find out where this metal lip is, so I attached it to the plastic lip of the bed rail cap:
    I tried looking underneath the bed rail cap for an actual metal part to clamp to, but I just cannot find it. Is this normal for Tundras?
    It seems pretty secure when I try to move it with my hand, but the lip of this plastic bed rail cap does bend a bit. Is it OK to just clamp it on this plastic bed rail cap?
    If over time this tonneau cover causes the bed rail cap to break or warp, how easy is it to replace the bed rail cap? Maybe with something sturdier? What do people usually upgrade to?
  2. Aug 17, 2018 at 9:02 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Yup that’s fine
  3. Aug 17, 2018 at 9:13 PM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate, RCI front skid plate.
    It is metal under the bedrail lip.
  4. Aug 17, 2018 at 9:18 PM
    tundrathr0w
    teedubbya, do you have a similar tonneau cover on your truck? Does the lip of your bed rail cap bend a bit when the clamp is tightened on?
    Thanks 15whtrd. I was wondering about that. By "metal under the bedrail lip" do you mean that the lip itself a metal sheet with plastic coating?
  5. Aug 17, 2018 at 9:42 PM
    tundrathr0w
    I just took a closer look... it does seem like that "lip" is a metal lip with the plastic part of the bed rail cap on top of it/on the outside.
    In the below picture, thin metal lip on the left (my bed is Linex'd), plastic part of the bed rail cap on the right.
    However as you can see from the picture, the whole lip is kind of bending with that clamp tightened on it, and I guess I'm just concerned that over time the metal lip will warp or break.
    At that point, if this lip of the metal bed rail snaps off, that sounds like a big deal to repair, as it's an integrated part of the bed, not a replaceable part?
  6. Aug 17, 2018 at 9:52 PM
    15whtrd
    15whtrd Mr. Blonde
    It is thin and will probably bend a little but won’t snap off. I have the same cover but mounted mine to the bedrail system. I didn’t have the bedrail system at first and didn’t like that it was slightly bending my rail. So I upgraded lol.
  7. Aug 17, 2018 at 10:00 PM
    tundrathr0w
    I might go this route because I'm paranoid about the bed rail snapping off... what did you upgrade to? Got a link?
  8. Aug 17, 2018 at 10:02 PM
    tundrathr0w
    Do you mean that you upgraded by adding a utility track?
    15whtrd likes this.
  9. Aug 17, 2018 at 10:03 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes, its more solid. Did your cover come with the optional hardware for the utility track?
  10. Aug 17, 2018 at 10:04 PM
    tundrathr0w
    Yes, it did come with 6 aluminum brackets for the utility track, but my truck itself doesn't have a utility track (I got a barebones Tundra trim).
    Did your Tundra come with the utility track or did you add it on?
  11. Aug 17, 2018 at 10:06 PM
    15whtrd
    15whtrd Mr. Blonde
    The bedrail won’t snap off. You don’t need the cover ridiculously tight either. The bed rails hold camper shells on. Very unlikely to break off.
  12. Aug 17, 2018 at 10:08 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s what I added on. You may need to chase the threads with a tap to get the liner material cleaned out.
  13. Aug 17, 2018 at 10:10 PM
    tundrathr0w
    Do you have a link to the utility track/deck rail you added on?
  14. Aug 17, 2018 at 10:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Roman likes this.
  15. Aug 17, 2018 at 10:16 PM
    tundrathr0w
  16. Aug 17, 2018 at 10:17 PM
    15whtrd
    15whtrd Mr. Blonde
    I can’t remember if I had to buy the tiedown cleats separately. I want to say yes and they come in 4s. But unnecessary if you just want the rails.
    Also there is a write up around here on how tymake your own out of unistrut.
  17. Aug 17, 2018 at 10:18 PM
    15whtrd
    15whtrd Mr. Blonde
    No but we do get a forrum discount. I think it’s forum20. Like 5%
    He’s just helpful if you have any questions.
  18. Aug 17, 2018 at 10:23 PM
    15whtrd
    15whtrd Mr. Blonde
  19. Aug 18, 2018 at 12:44 AM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    I have an Xtang, but here is how it hooked up to the bed rail system. It came with the hardware. The silver brackets attach to the bed rail using a t-bolt, then you’re all set.ABBDBE45-698D-4FA7-A175-F150BFF0FEBF.jpg F4441912-3ACD-4893-A0E2-1504B985BEAC.jpg
  20. Aug 18, 2018 at 12:45 AM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    $163 for OEM rails is good.
    15whtrd likes this.
