PLC721 2017 Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by PLC721, Feb 5, 2017.
  1. Feb 19, 2018 at 7:44 PM
    #301
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    That's what I was thinking about just haven't bugged you about it. I don't know how much you have tried to slow down your rebound in the rear but slowing it down may help. Also if your high speed compression to high may be packing out also and sometimes that may make it feel harsh and like it is unloading. Just my thoughts. Good luck with the tuning:thumbsup:
    zackbremer[QUOTED] likes this.
  2. Feb 19, 2018 at 7:45 PM
    #302
    Tacotundra
    Vegas
    2022 Tundra
    Yes sir I will let you know:thumbsup:
  3. Feb 19, 2018 at 8:10 PM
    #303
    zackbremer
    zackbremer New Member
    Da Z
    ive been lazy cus its hard to adjust the bypass tubes with the tire on lol also with the lack of ride height i got from my deavers my shock piston p sits right below the bypass bump zone tube ..basically at ride height i have like 4in uptravel and 10 of droop so im not really in the middle of the bypass to utilize it like i should...increasing the ride height this week with reworking the leafs then going out this weekend to mess with the tubes and makes so improvments
    Tacotundra[QUOTED] likes this.
  4. Feb 19, 2018 at 8:15 PM
    #304
    zackbremer
    Da Z
    zcarpenter92 and Tacotundra like this.
  5. Feb 19, 2018 at 8:15 PM
    #305
    Tacotundra
    Vegas
    2022 Tundra
    Oh ok I see. Yea taking the wheels off out there would get old real quick. Well hopefully some ride height will help. If you still can' get it dialed just off the tubes gonna need some different valving. You run kings correct? Maybe contact @jberry813 he is big on kings and has revalved his couple times.
  6. Feb 19, 2018 at 8:19 PM
    #306
    zackbremer
    Da Z
    i can adjust em with the wheels on, its jsut a bitch cus i can only move the wrench like 1/8in to loosen the lock nuts on the bypass adjustments lol it came with 12/10 compression stack, and i was on the bumps all the time...i had em revalved to a 18/10 stack which is very stiff, but u lose some dampening ability cus the shock is angled not straight up and down..which is why i skipped the 15/10 stack...my bump zone tube is all the way in(super stiff) so im going to try and back that out a lil and see if i can keep the ass from bouncing...also mess with the rebound to
    but rebound should push the axle down not the bed up...for example if u run no rebound dampening it doesnt increase your ride height, so while my wheels should push to the ground faster it shouldnt cause as much bucking as im having in those vids..obviously rebound contributes some what to it, cus well physics but only time will tell im just excited to go mash dirt and mess with it...i actually enjoy this kind of stuff and when you finally get it right, man is it fuckin sweeeet
    831Tun and Tacotundra[QUOTED] like this.
  7. Feb 19, 2018 at 8:29 PM
    #307
    Tacotundra
    Vegas
    2022 Tundra
    True on both points. But with the compression set all the way stiff you are not letting the shock do it's job it can't get into the stroke to let the valving work. Thats what i meant by packing out makes it harsh. And if rebound is to fast will make rear feel bouncy and make it unload. Will be fun out there either way. You will get it figured out.
  8. Feb 20, 2018 at 9:57 AM
    #308
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    It is a 600lb spring, not a 650. If you need a 700lb, it would be switching to an Eibach spring but I haven't had someone need to switch yet. Sorry about the delayed response as I am not on my personal account much anymore with the influx of messages through the business account.
  9. Feb 20, 2018 at 10:05 AM
    #309
    olsin6
    Joey
    Mesa, AZ
    Here is a picture of our shop Tundra that we did custom long travel air bags on. Did not hinder any ride quality nor any suspension travel. We used this to tow our shop flat bed with a can am on it. It puts my truck with stock leafs on the bumps pretty much, shop Tundra towed it with ease with 30 pounds in the bags on option #1 on the leaf pack.
    Jrocker, FirstGenTundra and TRON like this.
  10. Feb 22, 2018 at 6:53 AM
    #310
    PLC721
    PLC721 [OP] New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Well thats pretty cool! Generally speaking I have No weight in my truck, but 5-7x a year it gets loaded down, and tows a heavy bass boat to Lake Powell so thats my only concern. Honestly Icon RXT or Deaver U748 would probably work very well for me.
    dcsleeper408 and zackbremer like this.
  11. Feb 24, 2018 at 6:02 AM
    #311
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    signalbobby and dcsleeper408 like this.
  12. Feb 25, 2018 at 10:44 PM
    #312
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
  13. Mar 1, 2018 at 6:26 AM
    #313
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    Shockingly Uncle Sam is kind enough to help me with some mods it appears :eek:
    Rextinkleton93 and signalbobby like this.
  14. Mar 1, 2018 at 7:05 AM
    #314
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
  15. Mar 1, 2018 at 7:05 AM
    #315
    signalbobby
    Robert
    AZ
    Glad he was for you. Society owes me now....
    Eclipsed & Floating likes this.
  16. Mar 1, 2018 at 7:06 AM
    #316
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    I would assume so, Jamie runs a very similar set up and it sounds good to me.
  17. Mar 2, 2018 at 7:34 PM
    #317
    signalbobby
    Robert
    AZ
    Well now you say that, i have to do the opposite. that guy................
  18. Mar 2, 2018 at 10:54 PM
    #318
    Johnathand
    Johnathand New Member
    Johnathan
    16 Platinum
    I just installed a Kenwood multimedia radio today. And man... the stock speakers are actually pretty decent with the extra power from an aftermarket. I honestly think the stock radio just sends crappy signal
  19. Mar 3, 2018 at 2:03 AM
    #319
    YTThao530
    YTThao530 New Member
    Got same issues here I talk to Jiff at Deaver spring that I want a custom 3” off lift with my 5.5 BDS lift and want the ride like K37 and 400-500 preloaded he said okay they have done a lot like that take about 8-10 week to made it but only 3 week later they just send me U748 with 800 preloaded over stocks! After install with TC shackles my truck sit crazy lower then front about 2” wtf. I called Deaver the next day and he said this is what you get 800lb spring u can’t get both! (Wtf what I doing wrong he not lesson what I want?) my truck ride like shit too stiff even I’m set up my ICON Piggyback cdc to soft still stiff. Maybe ICON RXT For me next.
  20. Mar 3, 2018 at 4:00 AM
    #320
    zackbremer
    Da Z
    yah youre not the only one, sounds like deaver is getting lazy and just shipping these out to anyone who wants preload...i brought mine to a local leaf spring shop and had them re arch to give me 2in more lift, took one of the flat overload leafs out and arched the other one down so it only activates if you are towing or hauling a heavy load ...what state are you in?
  21. Mar 3, 2018 at 12:23 PM
    #321
    YTThao530
    I told him that 90% highways don’t want heavy load... paid $1200 for But...
    I live in CA.
  22. Mar 3, 2018 at 12:29 PM
    #322
    TheBeast The Beach
    how far are you from them ? they are in Orange County. I would take a drive there if I were you.
  23. Mar 3, 2018 at 12:31 PM
    #323
    TheBeast The Beach
    do you have a permanent load in the bed to go with the U748 ? I have the K37 and they ride great. Got about 1" lift with MCM shackles.
  24. Mar 3, 2018 at 12:47 PM
    #324
    YTThao530
    No permanent loads. I have K37 with Icon stage 4 before going to BDS lifted and love it but K37 not lift enough for my rear that’s why I have to call them to made a custom leaf spring 3”-3.5” but..make me crazy! lol
    U can till not looking right with my truck even I adjusted my Coilover down to 4.5 the back still lower with TC shackles too.
  25. Mar 3, 2018 at 6:05 PM
    #325
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Nice truck. The white was the right choice!!!
    YTThao530 likes this.
  26. Mar 3, 2018 at 7:07 PM
    #326
    YTThao530
    8.5 hours drive between me Deaver spring they will make me a new spring to get 3” lift maybe will look better but I don’t think the ride will change
  27. Mar 18, 2018 at 10:24 AM
    #327
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
  28. Mar 18, 2018 at 10:33 AM
    #328
    TheBeast The Beach
  29. Mar 18, 2018 at 10:34 AM
    #329
    PLC721
    Patrick
    Chandler, AZ
    IG: PLC721
    YEah if they werent so new, my plan is to find a good used one, and modify it lol dont want to spend 25k then want to build it.
    TheBeast[QUOTED] likes this.
  30. Mar 18, 2018 at 10:35 AM
    #330
    TheBeast The Beach
    I hear you, a fully loaded one is like buying a new tacoma..crazy
