Plastidip question
Discussion in 'General Tundra Discussion' started by joonbug, Feb 26, 2016.
  1. Feb 26, 2016 at 8:29 AM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm thinking about plastidipping my wheels black but haven't decided on flat black or glossy. How long do I have to apply the glossifier? Can I wait like a week or does it need to be applied immediately after the black? Also, people are saying to stick index cards between the rims and tires for the overspray but I can't get the cards to stay. And I've heard tape doesn't stick to the tires too well neither. Any suggestions? I've seen YouTube videos of people just spraying onto the tire and peeling it off afterwards but I can't imagine that peeling off cleanly.
  2. Feb 26, 2016 at 9:36 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I wouldn't stress too much about the Glossifier because it really doesn't leave much of a gloss. I used to couple coats of Glossifier after I sprayed mine and it made a difference but not a big difference. I am glad I used it though. As for the overspray on the tires, it does peel off just fine. I taped a plastic drop cloth to my truck and then cut a circle out in the shape of the wheel and then taped the drop cloth to the tire. There was a decent gap between the drop cloth and the rim. As long as you have enough coats, like more than 5 total, it will peel just fine. Check dipyourcar.com for their videos, they explain it well.
  3. Feb 26, 2016 at 10:26 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Just pull the wheels off the the truck and them plastidip. I will be doing this soon as a test :spy:
    TruckLife900 likes this.
  4. Feb 26, 2016 at 11:23 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    I may do this on a friends set of wheels.
  5. Feb 26, 2016 at 1:22 PM
    TxTundra
    TxTundra New Member
    2014 CM SR5 TX Edition
    Post some pics of the process, or at least the finished product. I'm curious to see how it turns out. I've been thinking about doing the same.
  6. Feb 26, 2016 at 2:18 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Here's a picture of Boozer's. With the TRD centercaps. I was thinking about powdercoating mine and then I ran across this. I think I'm gonna try dipping first.
  7. Feb 26, 2016 at 3:08 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Tape your lugs, take off your center caps and spray them separate. Much less work to keep the wheels on, just move the truck forward a few feet after 3 coats to get any missed spots under.
  8. Feb 26, 2016 at 3:12 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    This is how I did mine...
    Cubanchem and Medic like this.
