Plasti Dipped wheels 2018 CM TRD Sport
Discussion in '2.5 Gen Tundras (2014-2021)' started by SteyrM40A1, May 5, 2019.
  1. May 5, 2019 at 3:58 PM
    SteyrM40A1
    SteyrM40A1 [OP] New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Finally got around to dipping my wheels. I used the Luxury Metal series in Black Sapphire. I used a full can plus about 2 or 3 coats from another can per wheel. I really like the way it turned out. Trying to decide if I should paint the brake calipers...
  2. May 5, 2019 at 4:03 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    How many coats per wheel? How long did they dry between coats.
  3. May 5, 2019 at 4:06 PM
    SteyrM40A1
    Gregg
    I didnt really count the coats, I used a full can per wheel plus about 2 coats from another can. About 15 minutes or so in between coats.
  4. May 5, 2019 at 4:07 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Looks really good!
    SteyrM40A1[OP] likes this.
  5. May 5, 2019 at 4:11 PM
    SteyrM40A1
    Gregg
    Thank you!
  6. May 5, 2019 at 4:11 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Turned out great!
  7. May 6, 2019 at 7:34 PM
    RocSteadyNy
    RocSteadyNy New Member
    Dale
    Rochester
    2019 Calvary Blue Tundra SR5 TRD Offroad CM
    I want to do that to my stock OR wheels... looks good!
    Celt and SteyrM40A1[OP] like this.
  8. May 7, 2019 at 2:53 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    That's how they should have come from the factory. Transforms the whole look of the truck. Nice.
    SteyrM40A1[OP] and Celt like this.
  9. May 7, 2019 at 6:05 AM
    Celt
    Celt New Member
    NY
    2019 Crewmax TRD/OR Cement
    I cant figure out why they dont offer all black wheels on more than the trd pro, i cant stand silver wheels.
    With that said, what prep did you do? And in general how well does this hold up? I was thinking of powder coating my wheels, but its pricey, although i dont want to have peeling paint on my wheels that require constant touch up.
  10. May 8, 2019 at 5:03 PM
    SteyrM40A1
    Gregg
    There are several ways to do this, including leaving the wheels on. But I took mine off( mainly cause I didnt want my lug nuts black) and cleaned with a de greaser (super clean) applied some tire shine to the tires, popped the center caps off and applied the plasti dip in several light coats. I used an entire can plus a few coats from another can per wheel. Its to early to say how well its going to hold up. I did wash my truck the other day and I use a pressure washer and it held up fine. I thought about powder coating also, but it was going to be $400-$500. I spent about $60 on plasti dip.
    Celt[QUOTED] and mattyd170 like this.
  11. May 8, 2019 at 5:04 PM
    SteyrM40A1
    Gregg
    Thank you. I agree. Looks completely different.
  12. May 8, 2019 at 5:28 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looks great. I have a kit in the mail from dip your car. I'm going brass money gloss. They were running a 20% off sale so I got 4 cans of brass monkey, 3 cans of glossifier, spray tip, prep spray, and brake bags, maybe other stuff too, whatever is in the wheel kits. I'm pretty excited. I may dip my platinum badge to match too.
  13. May 8, 2019 at 5:32 PM
    SteyrM40A1
    Gregg
    Awesome! Make sure you post some pics on here so we can check it out!!
    Pudge[QUOTED] likes this.
  14. May 10, 2019 at 12:20 PM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Noice! Looks factory.
  15. Jan 22, 2020 at 4:53 PM
    Dragon36
    Dragon36 New Member
    2019 TRD Sport
    Looks really good. What’s the difference between using plastidip and spray paint meant for wheels? Is one more durable than the other?
  16. Jan 23, 2020 at 12:39 AM
    SteyrM40A1
    Gregg
    Plasti dip is a sprayable rubber coating. Not sure which is more durable but plastidip is easier to touch up and also easier to remove if you apply correctly.
  17. Jan 23, 2020 at 3:34 AM
    bryand
    bryand New Member
    Alabama
    2010 4.6L 2wd DC Black
    Bilstein 5100
    I had Plastidip on mine from April until a week ago, it got ripped up around the edges when new tires were put on, but was otherwise perfect. It peeled off in just about a single pull on all of them. Pressure washer knocked the rest off easily. When I did it, I did about 7 coats on each.
  18. Jan 24, 2020 at 6:29 AM
    KFed
    KFed New Member
    East Tennessee
    2018 Tundra Crewmax TRD Sport
    Tinted windows, Black badge overlays, ProZ hard bed cover, 32" grille light, 30" lower bumper light,...
    I've done mine too. I like the satin black look.
  19. Jan 25, 2020 at 1:25 PM
    SteyrM40A1
    Gregg
    Looks awesome!
  20. Jan 25, 2020 at 2:10 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Looks good, I plastidipped a wheels on a few different vehicles, I will say though that recently when trading in my last car I wanted to take the dip off before trading and it was a pain to get off I had to use acetone, is was after being on for 6 years. It came off easy on a wheel that I had replaced that was on there for less than a year. So I will say I have rethought putting dip on anything long term that's going to be out in the elements that I may want to remove at some point.
