Plasti Dip OEM Steelies Question
Discussion in 'General Tundra Discussion' started by lehminh, Mar 26, 2017.
  1. Mar 26, 2017 at 9:58 AM
    lehminh
    lehminh [OP] New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    I'm going to Plast Dip my steel wheels but trying to do it without removing the wheels. Want black wheel with steel lug nut look.
    Question: how would I keep the lug nuts from getting dipped? I've YouTube videos where they just seem to spray over it (which I think would rip when wheels are taken off), also would the removing the cap after it's been dipped also peel the dip on the wheels? other videos had the car on the ground with the wheel on with the lug nut off! Is this safe?
  2. Mar 26, 2017 at 10:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ya know, I had the same concern. Everything I saw just dipped over the lugs. Not really sure what happens but I wasn't going to find out. I just wrapped with Seran wrap and taped it.
    Also, make sure you you put nice thick coats where the wheel meets the tire and don't peel it off too early. And always warm up the cans in hot water if it's cold outside.
    Law323 and MotoTundra like this.
  3. Mar 26, 2017 at 11:05 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I covered the same areas @joonbug did with masking tape. Worked like a charm, otherwise it would be a pain to peel it off your lug nuts...
    As far as the center cap, I did mine separately to make sure I didn't miss any hard to reach areas, but as long as there is a gap between the cap and the wheel you will be fine. If the cap is flush with the wheel or the gap is paper thin, then the dip will bond to both and peel if the cap is taken off.
    The more coats you do, the thicker the dip, the easier it is to peel off. I did a bunch.
    joonbug likes this.
  4. Mar 26, 2017 at 11:21 AM
    lehminh
    Thanks guys! So looks I should remove the cap and spray it separately while the wheels are sprayed on the car with the lugs?
    040Tundra likes this.
  5. Mar 26, 2017 at 11:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes definitely do caps separately. Or just buy new wheels. :D I got tired of my dipped wheels real fast.
    rons23 and Law323 like this.
  6. Mar 26, 2017 at 11:39 AM
    lehminh
    Really? Was thinking about getting wheels then found out about TPMS comparability, so will give dipping a try first. Did u guys go with just the matte black or also added the metal shine layer on top?
  7. Mar 26, 2017 at 12:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think I did 4 coats of black and 2 coats of glossifier. If I were to do it again, which I never will, I would do a couple more coats of glossifier or none at all. 2 coats wasn't enough to make a difference.
  8. Mar 26, 2017 at 12:30 PM
    lehminh
    One more Question: how are you suppose to turn the wheel 180 degree if the brakes and calipers are covered in plastic? Is it ok to creep the truck forward a little?
  9. Mar 26, 2017 at 12:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    As long as it's not taped to the wheel you'll be ok. Just go slow
  10. Mar 26, 2017 at 1:08 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yup, and I masked the lugs. I used garbage bags around the rotors/calipers and removed them, then creeped forward and reset them.
    I used regular black then I believe three coats of glossier, which I do believe is a waste of money. There is no gloss to my wheels, ever.
  11. Mar 26, 2017 at 2:22 PM
    lehminh
    Has anyone dipped just the steel wheel and not the cap or lug nuts? Interested seeing how that would look. Might be the easiest/laziest method! Lol
    I think I'll start with that and see how it looks before deciding wether to dip the caps too.
  12. Mar 26, 2017 at 2:33 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @lehminh , I platidipped the a set of wheels back in November of last year. They are still holding up very well. I left on the center caps but if I were to do again today knowing what I know now I would have removed the caps and done them separately. Also on rotating the wheels, I never did and it came out a-ok. The tire was far enough from the ground that I just held the can upside-down for a quick second while spraying the bottoms of the wheel.
    For the first couple of coats, I wouldn't put it on too thick until you get a good 2-3 coats of plastidip on them. Otherwise it''ll run faster. Good luck and show us the results when finished.
  13. Mar 26, 2017 at 2:36 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You have pics of your wheels? Can't remember what the caps look like on the steelies. Or are you talking about the OR wheels? I left my Pro caps alone. It was glossy and didn't match the wheels but didn't look bad. IMG_0146.jpg
    NC_Nole and 040Tundra like this.
  14. Mar 26, 2017 at 2:44 PM
    lehminh
    The stock caps look just like your blacks but are plastic it seems. Was thinking of getting the black caps but they're like $40 each!
  15. Mar 26, 2017 at 2:45 PM
    lehminh
    The stock are light grey plastic
  16. Mar 26, 2017 at 2:49 PM
    lehminh
    How about dipped wheels but not cap or lug nuts but with a black center cap.? Anyone know the size of the center Toyota cap ?image.jpg
  17. Mar 26, 2017 at 2:52 PM
    lehminh
  18. Mar 26, 2017 at 2:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    These, right? Just remove caps, tape up the lugs, and spray caps separately. If you work the caps onto the rotation, it'll be easy. Spray each wheel then all 4 caps. Most of the time is waiting between coats.
  19. Mar 26, 2017 at 2:56 PM
    lehminh
    Yup, thanks Joonbug
    joonbug likes this.
  20. Mar 26, 2017 at 5:54 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    You can also check out www.dipyourcar.com for some good instructional videos and tips.
  21. Mar 27, 2017 at 3:38 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    lehminh, go to dollar store and buy ya a bag of med size balloons. Put them over your lugs. You can cut to fit and tape end. It worked for me, but decided to just spray lugs along with wheels. Good luck.
    joonbug likes this.
