Plan to replace radiator
Discussion in '2nd Gen Tundras (2007-2013)' started by MarcoD, Apr 16, 2024.
  1. Apr 16, 2024 at 3:46 AM
    MarcoD
    MarcoD [OP] New Member
    Dallas, TX
    2010 Silver Tundra SR5 5.7L 4x4 CM
    So I will be replacing the radiator on my truck due to it having a slow leak. Mechanic and I both saw dried coolant near bottom of radiator. I will also be replacing thermostat, fan clutch, upper and lower radiator hoses. The thing that’s a little confusing to me is the part description for the thermostat. The only thermostat I see that would fit is “16031-0S010” which is the pn for the thermostat. However it has “without tow package” in the description but it does fit tundra, sequoia, land cruiser 5.7L/4.6L. My truck has the tow package and I can’t seem to find a different part number that has “with tow package”. Is the thermostat the same for tundras with tow package?
  2. Apr 16, 2024 at 7:19 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Seems there is a cast housing or water inlet that is different depending if tow package or not.
    The thermostat part number that you show appears to be the same for all trucks. I am getting this from ToyoDIY.com. Your part number is the newest version of the old part number 16031-38010, which is still shown on ToyoDIY.
    Another point of reference: AISIN THT005 on Rockauto.com, which could very well be identical to the Toyota part, does not specify tow package or not in its listing.
    MarcoD[OP] likes this.
  3. Apr 16, 2024 at 9:36 AM
    MarcoD
    Dallas, TX
    Thanks! I really like that ToyoDIY website. It helps a lot.
  4. Apr 16, 2024 at 9:57 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    While everything is apart, also the check the belt idlers and tensioners. I ended up replacing both of mine while it was apart for the waterpump.
