Piped in, fake engine sound
Discussion in '3rd Gen Tundras (2022+)' started by Donas, Feb 24, 2022.
  1. Feb 8, 2023 at 2:23 PM
    #121
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    I think they should at least give a mud tire whine noise too So you could have mud tires and a V8 At the flip of a switch
  2. Feb 8, 2023 at 2:34 PM
    #122
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Correct. JBL isn't an option on any SR5, so no fake engine noise. Yes, a Limited without the JBL system would not have the fake engine noise. The fake engine noise is specific only to Tundras that have the upgraded JBL system.
    Hella Krusty likes this.
  3. Feb 8, 2023 at 8:52 PM
    #123
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Also note that JBL DC Limited does not have the SES (fake engine noise). Although, not truly fake as the sound is picked up from within the motor, then manipulated and pumped out the JBL system.
    PNW Tundra Mike, GODZILLA and ChiefG like this.
  4. Feb 9, 2023 at 5:13 AM
    #124
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    So it’s not a created noise that mimics an engine. Its the actual sound coming from your motor and amplified by the JBL audio even when the audio is turned off ? Or just acoustically piped in to the speakers directly from the motor…? Electronic or mechanical..? Very curious
    ChiefG likes this.
  5. Feb 9, 2023 at 5:20 AM
    #125
    4genRunner
    Southwestern MO
    Fair enough, not truly fake, just “enhanced”. And good point about the JBL equipped DC’s. I forgot they do not have the SES.
  6. Feb 9, 2023 at 6:30 AM
    #126
    chastings1954
    chastings1954 New Member
    charles
    capstone
    I never bought in to the "V8" sound other have called it because when I cut mine off it sounded near as before only alot softer. The sound is there at the same sound level when on no matter where the volume level is set on the radio if that's what you are asking.
  7. Feb 9, 2023 at 6:33 AM
    #127
    Tom976
    Tom976 New Member
    Tom
    What an annoying feature, maybe a software update someday will allow users to enable or disable it.
    Tom
  8. Jul 10, 2023 at 2:03 PM
    #128
    JDMB20TDA
    JDMB20TDA 2023 magnetic gray trd pro
    were you able to disable the engine sound via the carista?
    I contacted them and they only have partial support for the 2022+ tundra.
    hoping to disable the belt chime and fake noise on my 2023 pro. any idea if there will be an option for tire size? i know they come with different tires so it must be possible to some degree....
    either way thanks in advance.
  9. Jul 10, 2023 at 2:09 PM
    #129
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Yes, it's just a click on the custom tab to turn it off. However, it doesn't make the truck silent. I think it sounds like what it should sound like with it off. A little whistle but not much.
  10. Jul 10, 2023 at 2:35 PM
    #130
    Gasman1962
    Gasman1962 New Member
    ‘23 iForce Max Hybrid
    I think the fake sound is actually pretty cool, it would be nice to give us control of the sound though for a long road trip when you want it quieter.
    PikesPeakTRD likes this.
  11. Jul 10, 2023 at 3:07 PM
    #131
    PikesPeakTRD
    PikesPeakTRD New Member
    23 Hybrid Limited TRD OR MGM
    I don’t mind the fake noise. IMHO it’s surprising to see so many strong emotions coming out on the forum about it lol.
    Tom and Texan-1794 like this.
  12. Jul 10, 2023 at 10:33 PM
    #132
    Tom976
    Tom976 New Member
    Tom
    This is a feature toyota should have had some fun with....
    They could have made the interior sound like a whole host of Toyota engines.
  13. Jul 11, 2023 at 2:33 AM
    #133
    Gasman1962
    I totally agree! I wouldn’t mind it a little more loud, and/or the addition of some back pressure popping during downshifting. What a cheap way if modifying your exhaust!
  14. Jul 11, 2023 at 8:29 AM
    #134
    Dos Cylindros
    Dos Cylindros New Member
    2022 1794 Edition Smoked Mesquite
    I chose to leave the engine noise as it does not bother me. It was an option to delete it and I tried it out but decided to turn the engine noise back on. There was no option for tire size that I recall but I have stock size tires and don't plan on changing from that size in the near future. The seatbelt chime was easy to get ride of an I don't miss it one bit. I also used the device to disable the chime in my wife's Rav4.
  15. Jul 11, 2023 at 8:37 AM
    #135
    chastings1954
    charles
    capstone
    I think a option for "noise on" in sport mode only would be a cool option. Easy to turn off and on when wanted. I do agree that it is a enhancement of the actual engine. Not a V8 sound.
    CappyKD likes this.
  16. Jul 11, 2023 at 9:20 AM
    #136
    JDMB20TDA
    any idea if the carista obd2 software supports tire/wheel diameter for a larger tire size? Ive heard they are able to do it from the dealer but, are reluctant for whatever reason (odo manipulation through downsizing diameter maybe?).
    I feel like an accurate speedo/odo reading is safer and gives a more accurate depiction of mileage .
  17. Jul 11, 2023 at 9:27 AM
    #137
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    carista cant adjust tire size
    ryanwgregg likes this.
  18. Jul 11, 2023 at 10:10 AM
    #138
    JDMB20TDA
    have any of you guys ever messed with the Toyota TIS Techstream
  19. Jul 12, 2023 at 8:40 AM
    #139
    smileytn1
    smileytn1 New Member
    No but the dealer here in the service dept said there was no fake v8 noise but saw trd jon show it and cut it off .
  20. Aug 23, 2023 at 6:18 AM
    #140
    David713
    David713 New Member
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    Has anyone looked into changing the fake Lexus V8 engine sound file? I'm thinking Lexus LFA V10 sound!
  21. Aug 23, 2023 at 6:48 AM
    #141
    Maharisc
    Maharisc w/Patty
    Karl
    If you do the research, the 'fake' sound is not a sound file but an actual microphone like diaphragm in the motor and the augmented sound is then enhanced and played over the JBL sound system.
  22. Aug 23, 2023 at 7:59 AM
    #142
    Hella Krusty
    Hella Krusty New Member
    Wait until you tow something heavy. Fake Engine sounds will make you want to blow your brains out it is so irritating.
    Soupbean77 likes this.
  23. Mar 18, 2025 at 2:39 PM
    #143
    Dantundra2025
    Dantundra2025 New Member
    Yes.
  24. Mar 18, 2025 at 2:50 PM
    #144
    Dantundra2025
    On the 2025 limited without the JBL system it will have the fake engine noise noise. Trouble is it can not be shutoff because it doesn’t have the JBL system
  25. Mar 18, 2025 at 3:10 PM
    #145
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Nope. No JBL, no fake ESE, hence nothing to switch off.
  26. Mar 18, 2025 at 3:17 PM
    #146
    eddiefromcali
    Eddie
    100% Stock
    Easy way to tell...Fire up the truck with your door closed. Open the door and you can clearly hear the fake noise turn off....close the door and you clearly hear it come back. No change in noise, no fakeness in your configuration
  27. Mar 19, 2025 at 4:33 AM
    #147
    Rat Fink
    Rat Fink New Member
    Alabama
    25 Silver 1794
    Dealer turned it off at no charge. Will not have it turned back on either. I like the quiet ride. Use to clothespin playing cards to my bicycle spokes too, grew out of that also. Strange, pretend just ain't tha same as real.
    Tom976, Soupbean77 and Raven67 like this.
  28. Mar 19, 2025 at 5:12 AM
    #148
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    Meme of the day!
  29. Mar 19, 2025 at 8:16 AM
    #149
    Starman2112
    Starman2112 New Member
    What? In 2025 people don't realize manufacturers have been piping in engine noise for years lol...
    Jesus people, Ford even did it in my old 2017 Mustang 5.0 GT Performance/convertible model.
    I also don't get why 2nd gen Tundra owners are always talking about the 5.7 liter V8 sound. We owned a 2010 iForce Sequoia Platinum for 8 years and I don't remember even hearing that engine, wasn't that special what so ever, kind the usual Toyota bland conformity of the 90's-2010's. I think some of you need experiences on more cars. Sorry man, you want a good sounding engine in their time periods you should listen to a 2.0 liter DOCH VTEC in a Honda S2000 doing 140mphh revving 9000RPM on a race track with the top off. You actually *hear* that.
    75tranzam likes this.
  30. Mar 19, 2025 at 8:28 AM
    #150
    DRP
    DRP Old Member
    Dave
