Pics of your lifts with stats!
Discussion in 'Suspension' started by GratefulDean, Aug 27, 2020.
  1. Sep 26, 2020 at 5:24 AM
    #121
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Do you think 4.88 is too much with 33" tires?
    Double Badass and brown1794 like this.
  2. Sep 26, 2020 at 9:42 AM
    #122
    brown1794
    brown1794 New Member
    Joey
    Windsor, Va
    2015 sunset bronze mica 1794
    Touchy throttle....and 33s....sounds great!
  3. Sep 26, 2020 at 10:01 AM
    #123
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    You're in the wrong section but what are SPC cam adjusters?
  4. Sep 28, 2020 at 12:39 PM
    #124
    jDaGr8
    jDaGr8 New Member
    how high does your tundra sit? I have a leveling kit on already and was looking at either a 4 inch or 3 inch readylift kit and was wondering if I'd notice a difference with just the 3 inch?
  5. Sep 29, 2020 at 10:08 AM
    #125
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Honestly I think 3" is about max you can go without it looking "super" lifted... and without having driveline issues.
    I like that I can still get in my garage (barely) and can get under a McDonalds drive-thru.
    Im still dealing with a minor pinion angle related 0-20mph vibration... and need to get my upper control arms installed so the caster can be fixed.
    ...and this is only on 3" of total front/rear lift.
    As a daily driver, I really dont want it any higher.
    toyofan87 and J's 4x4 like this.
  6. Sep 29, 2020 at 10:32 AM
    #126
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    I was actually told by the shop that did my lift that you shouldn't go higher than a 3" lift because it starts messing with the front sensors for Collision & some other safety concern. I know my neighbor has a Tundra with a 6" lift and my detailer tells me ever since he did his lift his check engine light is always on. I'm sure there's more to it and I'm sure it depends on who does your lift.
  7. Sep 30, 2020 at 1:41 PM
    #127
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    I overpaid to have the dealer do the lift and program the sensors. It has worked well ever since (2 years). I believe Toyota also had a recall on the radar but asked the dealer to leave mine alone as everything is working fine. Truth is, if you do a lift you would be wise to let the dealer reprogram the sensor. Some people have been ok but others have not.
  8. Sep 30, 2020 at 7:07 PM
    #128
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I have a 2018 Platinum with a 6" Pro Comp lift and have had ZERO issues with parking and/or Collision sensors.
    toyofan87 likes this.
  9. Oct 1, 2020 at 2:25 AM
    #129
    RocknRoll
    RocknRoll I’ll make you famous
    DFW, TX
    2019 MGM TRD Sport 4x4
    5” lift, 37” Toyo R/T’s 20” Fuel AMP steps, Ceramic 20% Tint
    Yea I guess I've been lucky as well, 6" lift w/35's on a 2019 and no issues...
  10. Oct 1, 2020 at 10:16 AM
    #130
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    Here's mine.
    Toytec Boss coilovers in the front, adjusted for 3.5" lift.
    AAL in the rear, with a 1" block for 2.5" total.
    20" TSS Wheels w/ 295/65 R20 Nitto Ridge Grapplers (35s)
    Installed myself.
  11. Oct 1, 2020 at 10:40 AM
    #131
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    4" Pro Comp lift
  12. Oct 1, 2020 at 9:16 PM
    #132
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    3/1.5 lift
    35x12.50R17 Nitto Ridge grapplers
    BMC
    JPB_VT, jsteph89, toyofan87 and 5 others like this.
  13. Oct 1, 2020 at 9:48 PM
    #133
    anquaman
    anquaman New Member
    Damn this is a beaut!
  14. Oct 2, 2020 at 4:04 AM
    #134
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Always like Fabtech. How has this lift performed for you?
  15. Oct 2, 2020 at 5:11 AM
    #135
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Toytec/Eibach complete front coil overs (claims 2.5” lift), Eibach pro sport rear shocks and 1” block. Coach builder 1/2” shim on driver side (that doesn’t appear to have done anything?) factory 20” TSS wheels, 275/60R20 continental Terrain contact AT. Thinking I’ll goto 275/65 next go around. These continentals are awesome in rain though, and have done great at super muddy job sites.
    Prostar 190 likes this.
  16. Oct 2, 2020 at 5:12 AM
    #136
    t4r2tundra
    See sig for mods...
    Prostar 190 and drobb like this.
  17. Oct 3, 2020 at 5:45 AM
    #137
    Bluedevils4life
    Bluedevils4life New Member
    Jeff
    2020 Toyota Tundra
    RBP Running Boards, 20% Window Tint, TRD Exhaust
    Been really impressed with the ride quality! I was supposed to get the Bilstein coilovers but glad I got the Fabtech Dirtlogic!
  18. Oct 21, 2020 at 10:33 PM
    #138
    Bigboitundra
    Bigboitundra New Member
    2018 tundra crewmax
    7 inch lift
    [​IMG] 7inch pro comp with toyo open county r/t 35/12.50/20
  19. Dec 4, 2020 at 5:07 PM
    #139
    johnsmsith6073
    johnsmsith6073 New Member
    2015 Limited
    Eibach/ToyTec 3'ish" front 2 rear via shackles. 35 inch Milestars, Mamba M27 wheels (12mm). Rubs at the body mount.
    Right brake caliper also rubs the inside of the wheel slightly, doesn't happen on drivers side (WTF). I didn't expect to have clearance issues with 18 inch wheels, but I do. Wheel weights are a no go on either side. The $45 worth of black lug nuts turned out to be chrome.... Not the best experience with Custom Offsets on this one.
    Prostar 190 and tdiantonio like this.
  20. Dec 4, 2020 at 5:32 PM
    #140
    Toytec Aluma 2.5 coilovers
    SPC UCA's
    Toytec Boss rear with remote resis
    Toytec shackles at 1.5 along with 1/2 axle shims
    Fuel Maverick 18x9, 0 offset with 285/70/18 Ridge Grapplers
  21. Jan 5, 2021 at 9:31 PM
    #141
    Solace_In_My_Tundra
    Solace_In_My_Tundra New Member
    Out there somewhere
    2020 MGM CrewMax
    Tonneau Cover TRD Pro Grille Bumper Shells Color matched Bulge Bilstein 5100 Ceramic Tint Black Tundra Inlay
    How are you liking the continentals? I’m considering these myself in 275/60/20. Any issues with vibrations etc?
  22. Jan 5, 2021 at 11:18 PM
    #142
    rflinn0
    rflinn0 New Member
    Maui
    2019 MGM Tundra TRD Sport
    6112/5160 Top Setting, Shims, 35x12.5r18 KO2, METHOD NV305
    6112 Fronts w/ CB shims 2L, 1R & 5160 Rear/TOYTEC 1.5" Shackles
    JBA UCAs
    BFG KO2 35x12.5r18 on 18x9 NV 305 +25 Offset
    Did it myself with hand tools and lots of loud expletives. About 8-10 hours for everything.
    No BMC Needed, Skid plate trim, Trimmed fender liners back and used CB Bumper shims.
    JPB_VT, COTundra23, Skew12 and 4 others like this.
  23. Jan 6, 2021 at 4:11 AM
    #143
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  24. Jan 6, 2021 at 7:40 AM
    #144
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  25. Jan 16, 2021 at 4:47 PM
    #145
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Icon Stage 6 @3”, 18x9 Method MR306 with +18 offset, Nitto Trail Grapplers in 35x12.5r18, BMC.
  26. Jan 18, 2021 at 8:12 AM
    #146
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    They were great until recently, starting to wear very fast. I already had Discount Tire look at them and they said in 1-2 more 32nd of wear they will submit the claim. They are great in the rain though, plow through water with no problem and i have never felt any kind of slipping. I've also been on some of our yards at work at were a complete swamp and had no issue with getting stuck. Pretty impressive in the mud for a less aggressive tire.
    On the treadwear though..they were rated to 60K miles, i have exactly 30K on them now and i've gone from 13/32 to 6/32 and closer to 5/32 on the fronts
  27. Apr 23, 2021 at 4:37 AM
    #147
    GaFFLe
    GaFFLe New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
    What wheels are these?
  28. Apr 28, 2021 at 12:59 PM
    #148
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Look like Fuel Crush.
  29. Apr 29, 2021 at 8:54 PM
    #149
    JJ_TNDRA20
    JJ_TNDRA20 JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
    ReadyLIFT Plus 2
    Method MR701 18 x 8 +25 / BFG KO2 305/70/18
    4WP
    MaxYota and Prostar 190 like this.
  30. May 3, 2021 at 12:42 AM
    #150
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Yup he is right, i just modified the center cap to fit the factory TRD logo.
