Pics of plus sized tires on Pros
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ProTundra8806, Mar 26, 2017.
  1. Mar 16, 2023 at 4:04 PM
    #61
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    295-70-18 ridge grappler with wescott designs preload front lift about 1.5 inches and 1 inch wescott in the back
  2. May 16, 2023 at 9:17 AM
    #62
    TRDren
    TRDren New Member
    2020 MGM Tundra TRD Pro
    CoachBuilder TRD Pro Lift Kit 1.25” BORA Wheel spacers Chassis Unlimited Front Bumper
    Here’s the new setup.
    Method 705, 17x8.5, 0 offset
    Mickey Thompson Baja Boss M/T 35”x12.5”
    ackthresher, TRDPro21, Crady and 5 others like this.
  3. May 16, 2023 at 10:36 AM
    #63
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :benchpress:
  4. May 16, 2023 at 9:51 PM
    #64
    TRD_Ghost
    TRD_Ghost New Member
    17 Superwhite TRD Pro
    Running 295/70/18 Nitto Terra Grappler 2 tires on Method 305s
    Y0TA PR0 and Tripleconpanna like this.
  5. Jul 13, 2023 at 5:19 AM
    #65
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    What does the acronym UCA mean ? I keep seeing that
  6. Jul 26, 2023 at 9:08 PM
    #66
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thank you
    It was one of those things that I went through the day thinking about after my post and then the eureka moment happened.
    Thank you for your help.
  7. Jul 27, 2023 at 4:23 PM
    #67
    Cfife
    Cfife New Member
    Looking at ready lift SST 2” leveling kit and putting 17x9.5 with 35x12.5x17 tires. Anyone have experience with this set up for a 2019 Tundra TRD Pro? Not sure if I have to BMC to avoid rubbing. Any feedback would be appreciated.
  8. Aug 14, 2023 at 9:12 AM
    #68
    ejsc17
    ejsc17 New Member
    I have a 2020 Pro with the Readylift 2"sst. Running a 33x12.5 20 on Fuel 20x10 -18 offset. Mine does rub BM full lock and i removed lower front inner fender well.
  9. Aug 14, 2023 at 5:29 PM
    #69
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    I have a 2019 TRD Pro with that lift and 35x12.5x20. No BMC but did remove mud flaps and play with the inner plastic a little. No rubbing.
  10. Aug 15, 2023 at 7:55 PM
    #70
    Gass_Passer
    Gass_Passer New Member
    Rich
    2021 Lunar Rock Tundra TRD
    Put some new Nittos on today. Front mud flaps off to allow clearance for 295/70/18. Looks damn acceptable!
  11. Aug 16, 2023 at 6:09 AM
    #71
    MIDan19PRO
    MIDan19PRO New Member
    19 PRO White
    285/65R18 Duratracs. No mods
    SRQRUSTY, woofhauler and Gass_Passer like this.
  12. Aug 22, 2023 at 9:59 AM
    #72
    Mcdqpr
    Mcdqpr New Member
    3/1 or 3/2? Any pics?
  13. Aug 27, 2023 at 9:20 AM
    #73
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Nice, mind giving details on your shell?
  14. Aug 27, 2023 at 9:59 AM
    #74
    Gass_Passer
    Rich
    ARE Z series, color matched, carpeted interior with LED lights and top runners for on cap gear. Ceramic tinted windows done after install.
  15. Aug 27, 2023 at 10:09 AM
    #75
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Very nice!
    Gass_Passer[QUOTED] likes this.
  16. Aug 27, 2023 at 11:48 AM
    #76
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Also noticing the badge you added to your grille. Where did you find that?
  17. Sep 11, 2023 at 4:12 AM
    #77
    ejsc17
    ejsc17 New Member
    The kit says 2" front and rear. I did have driveshaft shudder on takeoff. The shop added a spacer kit to the carrier bearing and now all is well. I wouldn't recommend that wheel setup. I made a mistake getting 10" wide wheels with that much -offset. I'm stuck with them for a while.
  18. Apr 28, 2024 at 5:54 PM
    #78
    AllAmerican1
    AllAmerican1 New Member
    NC
    19 TRD PRO Super White CM
    Falken Wildpeak 295/70
    IMG_0133.jpgFalken Wildpeak AT3W 295/70/18 no rubbing; removed short mud flaps
    bulldog93 likes this.
  19. Apr 28, 2024 at 9:15 PM
    #79
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Too bad these aren't available anymore and the AT4W in this size is quite a bit larger, on paper.
    Flavier likes this.
