Phone messaging
Discussion in 'Audio & Video' started by Spitfire, Jan 16, 2018.
  1. Jan 16, 2018 at 7:27 AM
    Spitfire
    Spitfire [OP] New Member
    Long Island
    2018 Cement Limited Trd off road
    My truck doesn't allow my incoming texts to be read by the truck.. everythi g is switched on in the settings.. any ideas.. it worked for the first day now message just pops up with only an option to ignore. Trying to dive through the manual but can't find anything.. thx
  2. Jan 16, 2018 at 7:37 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    It’s probably in your phone settings. I’m not sure how to properly set them, but I bet it happened during an “update”
    I’m trying to mess with my settings to attempt to help, as mine is the same way.
  3. Jan 16, 2018 at 7:42 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Same issue here, i just press ignore. I sure would like to know also.
    Max Power and 1UPPER like this.
  4. Jan 16, 2018 at 7:43 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I had this happen for the first month or so. Sometimes it would work sometimes it wouldn't. I ended up deleting the phone off the head unit and re-connecting them, between that and giving it time, it works perfectly now.
    edit:
    Nevermind, i was not getting messages at all. No notifications. Still give it a shot unpairing and re-pairing.
  5. Jan 16, 2018 at 7:47 AM
    Eclipsed & Floating
    Voluptuous Whitey
    What kind of phones do you guys have?
  6. Jan 16, 2018 at 7:51 AM
    Ely010606
    SPARKS, NV
    Iphone 6S
  7. Jan 16, 2018 at 7:53 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    I will have to try that.
    I've had the same issue since the truck was new.
    Personally I think there's something wrong with my software. Sometimes songs via Bluetooth will play as if I were holding down the skip/fast forward button.
    I also configured my door locks to open when I open the driver door and have issues with the doors not unlocking as they should.
  8. Jan 16, 2018 at 8:03 AM
    Spitfire
    Long Island
    S8
  9. Jan 16, 2018 at 8:08 AM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    I have an iPhone 6S. I am getting incoming texts. If I am stopped I can hit ignore or display the message. If I'm moving I either ignore or let it read it. Just took the Tundra into the body repair shop so won't be able to look at the truck side settings for a week. Hope you figure it out.
  10. Jan 26, 2018 at 8:17 AM
    mr_souc
    mr_souc New Member
    Joel
    Maine
    2014 Tundra TRD Off-Road CrewMax
    - 3/2" Leveling/Lift - TRD Dual Exhaust - TRD Pro Grill - 32 Inch Light Bar - N Fab Step Rails - Color Match Bumpers - 285/75-18 Terra Grappler G2s
    Same issue here with an iPhone 8 on my 2014 non-JBL non-nav head unit. I have everything set up correctly, both call & contacts work, yet I get nothing with texts or emails...
  11. Jan 26, 2018 at 8:35 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    My truck literally just started reading me my messages a day or so ago after I updated to iOS 11.2.5 or whatever the latest is. I didn’t change any settings at all, they just started popping up on my screen when a text comes thru.
    Weirdest thing. And mildly annoying because it won’t read the messages unless the vehicle is stopped. I thought the point was to read them while in motion so you don’t have to look at your phone...
    wtf, Toyota.
  12. Jan 26, 2018 at 8:47 AM
    Lowrange
    Lowrange I’m your Huckleberry
    Joe
    2019 Limited
    iPhone guys, make sure your notifications are turned on in Bluetooth settings.
    Go to settings
    Bluetooth
    Toyota Tundra
    Hit the circle “I”
    Turn on “show notifications”
    This fixed my issue and all text message now notify.
    Buse and BHarry like this.
  13. Jan 26, 2018 at 8:55 AM
    mr_souc
    mr_souc New Member
    Joel
    Maine
    Thanks @Lowrange I checked my settings and it all looks good. It's gotta be the damn head unit...
    Lowrange likes this.
  14. Jan 26, 2018 at 8:58 AM
    Spitfire
    Long Island
    i deleted my phone then reconnected and now seems to be working for now.. reading them as well.. love the feature. hopefully it continues to work as intended
    mr_souc and Lowrange like this.
  15. Jan 26, 2018 at 10:02 AM
    Viper3G
    Rick
    Hmmm. Mine reads the texts to me if I'm moving and if I'm stopped will display the text. I've got the JBL head unit and an iPhone 6S with iOS 11.2.5, but it did this with older iOS versions too.
    TundraTss[QUOTED] likes this.
  16. Jan 26, 2018 at 12:42 PM
    TundraTss
    Brandon
    2019 TRD SR5
    My buddy’s taco is the same way..
    I don’t know. Maybe that will magically fix itself as well.
  17. Jan 26, 2018 at 1:38 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    iPhone 7plus here same problem all of the sudden it stopped beeping and displaying texts. Prob about the time of the last iOS update. But my phone isn’t showing the show notifications option on that screen when I’m paired to the truck. Kind of annoying works then doesn’t?
  18. Jan 26, 2018 at 2:00 PM
    Lowrange
    Joe
    2019 Limited
    That’s the way it’s suppose to work isn’t it?
  19. Jan 26, 2018 at 2:11 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    Awesome, this fixed mine! Thank you
    Lowrange[QUOTED] likes this.
  20. Jan 26, 2018 at 2:56 PM
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I think I give up with mine (Droid Maxx, KitKat 4.4). MAP is enabled in the bluetooth config for the device. It hasn't alerted/read messages since I got the truck over a year ago. Deleted, re-paired several times. Cleared all messages from the phone, re-paired. Notta.
    One day last month out of the blue it alerted to two messages but wouldn't read them. That tells me it works.. sort of..
    Other than that it's been mute.
    Messages only though, all the phone functions are fine.
    pfffttt.
  21. Jan 26, 2018 at 3:57 PM
    Viper3G
    Rick
    Yup!
  22. Jan 27, 2018 at 5:05 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    With an iPhone you have full access to Siri through the Bluetooth connection as well. You can also press and hold (3 seconds) the Call Answer button on the steering wheel and ask Siri to read your texts to you. By doing it this way you get the option to dictate a response through Siri.
    Press and Hold the Call Answer button for 3 seconds, it will activate Siri. Wait for the beep then say "Read my last text message." Siri will read it through the car stereo then ask if you would like to respond.
    I changed the message settings on my entune to only beep for incoming texts, then I use Siri to read and respond while driving.
    mr_souc, Viper3G and zlaneb like this.
  23. Feb 3, 2018 at 2:51 PM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    With mine I couldn't have any "Favorites" entered. As soon as I removed those mine started allowing my text to be read.
  24. Jul 15, 2018 at 6:07 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I have never been able to send or receive texts since I bought the truck new in Feb.
    When I ask Siri to do it, she says my phone is not setup for it.
    I text all day long - out of the truck.
    I have it paired - the phone works for calls, but nothing as far as texts.
    It’s driving me nuts. I’m about ready to replace the radio unit.
  25. Jul 15, 2018 at 6:12 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I have an iPhone 8; I previously had an iPhone 6 that this same issue was happening with. Happened in my 16 Tacoma, and now in my 18 Tundra, it gives me the cryptic message that I may have to operate my phone while setup is occurring to get messaging to work. So I gave up. The phone rings through and I guess that's the most important thing. I figured it was an issue with Entune and Apple.
  26. Jul 15, 2018 at 7:13 PM
    Spitfire
    Long Island
    Mines been working great now no issues.. dont want to touch anything
  27. Jul 15, 2018 at 8:02 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I have an iPhone 6
    What do you have?
  28. Jul 15, 2018 at 8:07 PM
    Spitfire
    Long Island
    S8
  29. Dec 4, 2018 at 10:52 AM
    mr_souc
    mr_souc New Member
    Joel
    Maine
    The message function still does not work on my head unit...
    Has anyone ever tried to update the software?
  30. Dec 4, 2018 at 3:18 PM
    Spitfire
    Long Island
    Mine has been working without issue now for a while... didnt do anything besides connecting and disconnecting
