PEX vs copper
Discussion in 'Home Improvement' started by L_S_SHOE, Jan 9, 2022.
  1. Jan 10, 2022 at 3:11 PM
    #61
    Jchetty
    Jchetty New Member
    NJ, Middlesex County
    Other than stub-outs, shower-valves, or water heater connections- pex a all the way.
    Ppl that sneer at pex users talk about sweating copper like it is an art. Please- a child could sweat copper.
    Years ago- the same debate was made when lead pipe aficionados started to see pvc. The skill needed to connect pex is the same required to sweat copper is the same skill needed to glue pvc is the same skill needed to connect electrical receptacles.
    Do it enough times and you get good at it. I have it all- I can sweat, I can Propex fit, and I can use ProPress with Viega fittings. They all have their place.
    Cock-A-Doddle-Do likes this.
  2. Jan 10, 2022 at 3:32 PM
    #62
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I'm not a plumber but i've pretended to be one. I also live in an area where freezing is not a factor. I used CPVC when I repiped my house from that poly butyl crap.
    At work I see alot of plumbers using PEX, but I think its mostly for speed and flexibility when repiping in an old house. CPVC is still popular in new construction.
    There's no way you can convince me that some plastic is going to last longer than about 25 years though.
    Prostar 190 and FrenchToasty like this.
  3. Jan 10, 2022 at 3:49 PM
    #63
    Not saying it is some hard art but I bet you there's a lot of damn homeowners that couldn't sweat their own copper without screwing up a joint not all but a lot. You can pick up a guy making french fries at McDonald's at noon and have him putting PEX together by 12:30. Once again I'm not saying sweating copper is impossible but it is nothing like gluing together two pieces of PVC. Lol
    But like anything in life there's a lot of people that can do stuff doesn't mean you're good at it. Just because I can pick up a paintbrush doesn't make me a painter.
    Darkness and FrenchToasty like this.
  4. Jan 10, 2022 at 3:53 PM
    #64
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You can be anything you want, don’t sell yourself short!!
    it took me a while to be professional at most of these, even longer to be proficient. I still don’t flow with nitro when I’m braising……….
  5. Jan 10, 2022 at 4:03 PM
    #65
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    You can pick up a guy making french fries at McDonald's at noon and have him sweating copper by 12:20!!
    FrenchToasty and Jchetty like this.
  6. Jan 10, 2022 at 4:07 PM
    #66
    FrenchToasty
    Mo
    Bone stock
    Also worked at McDowells, that shit ain’t happening. I’ve got stories of people putting a wet mop head into a hot fryer……..
    Prostar 190 likes this.
  7. Jan 10, 2022 at 4:11 PM
    #67
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    "Home of the BigMick"...better than McDonalds -
    You can pick up a guy making french fries at McDowells at noon and have him sweating copper by 12:15!!
  8. Jan 10, 2022 at 4:14 PM
    #68
    Jchetty
    Jchetty New Member
    You can also take the same fry guy and have him competent in sweating residential pipes in less than a week and an artisan in a month- so I fail to see your point.
    There are also a lot of vehicle owners who can’t change their own oil or tire.
    Just because connecting pex is easy doesn’t make sweating copper hard. No skill to either task. With enough practice, both can be mastered in no time. The true skill is the trade in its entirety.
    Sweating copper doesn’t mean you are good at plumbing. Being able to hook up a main breaker panel doesn’t mean you are good at electrical. Laying floor tile doesn’t mean you are good at masonry. Hanging a door doesn’t mean you are good at carpentry. Changing oil doesn’t mean your are a good mechanic.
    All the above has one thing in common- with basic tools, some ambition, YouTube and a few books, and practice- they can all be completed to a high level while being self-taught.
    Go to a new house build. The individuals doing most of the work are not pros by any sense. They are regular joes that picked up skills. Electrical, plumbing, hvac contractor working under someone’s license.
    They actual licensed guys come in to do finish work, fix a mistake, or to rough-ins that if messed up could be catastrophic.
  9. Jan 10, 2022 at 4:16 PM
    #69
  10. Jan 10, 2022 at 4:22 PM
    #70
    bflooks
    bflooks New Member
    Metrowest MA
    I'm in central MA. We have hard water. Our 38 year old copper was all pitted, tinted green, and showing signs of leaking. We just replaced it all with a Manibloc and home runs in PEX.
    I like not having joints in the wall for no other reason than being a big believer in the KISS method. Plus it's been around for almost 40 years at this point. I'm not sure there is a right or wrong between the two products.
    Find a reputable business in your area, hire them, and you manage your budget while they manage the plumbing. I think total cost of ownership is a wash after all things considered.
  11. Jan 10, 2022 at 4:33 PM
    #71
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    The first time you are jackhammering (our first house) up your house looking for the pin hole copper leaks you'll go pex or CPVC and gladdly put all the pipes in the attic if on a slab. Not in a freezing area mayself.
    WAtundra4x4, Jchetty and FrenchToasty like this.
  12. Jan 10, 2022 at 4:34 PM
    #72
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    ^^^Expansion tool ^^^
    @L_S_SHOE …Consider adding a poll.
  13. Jan 10, 2022 at 4:34 PM
    #73
    FrenchToasty
    Mo
    Bone stock
    This guy has seen a few things…..
    TomC843[QUOTED] likes this.
  14. Jan 10, 2022 at 4:37 PM
    #74
    Jchetty
    Jchetty New Member
    That is the press tool. Below is the expansion (Pro-Pex). Pro-Pex is much easier, faster, and more fool-proof.
  15. Jan 10, 2022 at 4:38 PM
    #75
    TomC843
    Tom
    Charleston, SC
    no one warms first time buyers to look for that, copper in concrete. Every house since then I have looked for any thing buried in the slab when built. Funny, 3 houses later all craw spaces.
  16. Jan 10, 2022 at 4:39 PM
    #76
    Dalandshark
    Northwest
    Yes, as pictured in thread post I quoted…below the crimper.
  17. Jan 10, 2022 at 4:43 PM
    #77
    Jchetty
    Jchetty New Member
    Sorry, hard to see on my phone. I failed to see both pictures. You are correct. Both are bad ass tools. I’m lucky enough to own both. The copper crimp fittings do take more finesse.
    if you get the M18, you can get jaws that allow you to do black pipe. Just have to make sure your inspector allows it. If black pipe gets any poorer in quality, I may have to pick one up.
    Dalandshark[QUOTED] likes this.
  18. Jan 10, 2022 at 4:43 PM
    #78
    bflooks
    bflooks New Member
    Metrowest MA
    We actually had the "heated slab" in our raised ranch described as a feature. 3 months after purchase, walked downstairs and one room was a puddle. Copper heat pipe had spring a leak and was coming up through the slab. Never again. Everything else was abandoned and rerouted.
  19. Jan 10, 2022 at 4:49 PM
    #79
    Dupey
    Dupey I love chips and salsa!
    Northern Colorado
    2014 tundra platinum
    TRD PRO GRILL TRD PRO HEADLIGHTS W/I hacker ADAPTER WIRING WEATHER TECH FLOOR LINERS C4 FRONT BUMPER WITH 30 inch LIGHT BAR RCI ROCK SLIDERS RCI SKID PLATE RCI LOW PROFILE BED RACK ARB TOURING ROOF TOP TENT TOYTECH 2.0 FRONT COILOVERS TOYTECH REAR SHOCKS TOYTECH 1.75 SHACKLES
    Not even close to true! I've had pex underground and non protected for close to thirty years and if this was copper it would be destroyed. There is a small amount of electricity in water that slowly causes corrosion in metal pipe. After about 30 years you'll be replacing copper piping. There's a reason why utility services are replacing all of their metal underground piping with some form of plastics. The one place copper should be used in place of pex is anything that is exposed because it is easily damaged and is sensitive to extended periods of sunlight exposure.
  20. Jan 10, 2022 at 5:36 PM
    #80
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I vote copper. I named my dog Copper. I carry a knife with copper scales. Yeah I love copper.
    Prostar 190 and Darkness like this.
  21. Jan 10, 2022 at 5:47 PM
    #81
    FrenchToasty
    Mo
    Bone stock
    Chester copperpot?
    Darkness likes this.
  22. Jan 10, 2022 at 5:58 PM
    #82
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't agree with any of that. Maybe in new production but I was a service plumber and sweating is the harder of these three, PEX is the easier. I knew guys who got hired right out of McDonald's and they were using PEX and shark bites to repair pipes. Those guys couldn't sweat.
    Sweating isn't "hard" and isn't a black magic skill if you're working with dry lines. Sweating in a tight spot with water in the lines is different. That takes some experience to get away with. Pex doesn't matter if its dry or full of water, its essentially like putting a rubber band on a wad of cash.
    Now I'm gonna end this debate for all of you. You can't make plumbchucks out of PEX.
  23. Jan 10, 2022 at 6:00 PM
    #83
    FrenchToasty
    Mo
    Bone stock
    Winner!
    Darkness[QUOTED] likes this.
  24. Jan 10, 2022 at 6:03 PM
    #84
    :rofl::transformer:
    FrenchToasty likes this.
  25. Jan 11, 2022 at 3:39 AM
    #85
    YorkT
    YorkT New Member
    It took me hours to replace the water heater. T-3616717738942611967.jpg he expansion tank was shot. I could have easily hung the new one the same way as the old one. Most tanks are not made to be hung horizontally. My daughter is probably going to be in the house for three more years so I could have done a half a$$ job, but still wanted to do it right. I rerouted all the pipe just to clean things up. Here is a before picture. I don't have an after.
    WILLINH likes this.
  26. Jan 11, 2022 at 6:00 AM
    #86
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    What makes a good welder? A good painter.
    Prostar 190[QUOTED] and Darkness like this.
  27. Jan 11, 2022 at 7:41 AM
    #87
    A gynecologist! :D
    Darkness and WILLINH like this.
  28. Jan 11, 2022 at 10:37 AM
    #88
    DEboater
    DEboater New Member
    2021 DC SR5
    Yeah my in-laws haven’t been able to find a carpenter either. We drove down there hauled 10k lbs of metal roofing materials and put two new metal roofs on their house that first weekend after. Place is a real mess. Good luck on fixing it up.
    L_S_SHOE[QUOTED][OP] likes this.
  29. Feb 25, 2022 at 9:55 AM
    #89
    BlueLighting
    BlueLighting New Member
    Rick
    California
    2015 Platinum
    4.5 RC Lift, fuel wheels, RC front bumper & front struts
    Copper will last longer than pex. I know several people with pex and after about 5 years the the fittings start leaking.
  30. Feb 25, 2022 at 10:07 AM
    #90
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    My parents have a house that was built in the 1960’s - started developing pinhole leaks and failed joints. We ended up taking it room but room and replaced it all with pex. I found it much easier to use. I never mastered the art of sweating copper and got nervous even attempting it. We had our hot water heater replaced by a “professional” and he turned the water back on and left. By the time he made it out of the neighborhood we have an inch and a half of water pouring out of one of the joints he forgot to sweat and a joint that wasn’t sweat properly.
    We had no problem installing the led ourselves and it is much easier (in my opinion) to work with. It’s flexible so you have to cut less drywall and access holes because you can manipulate the pipe and it flexibility makes it more versatile. Used hangers on long runs to reduce sag. YMMV
